Dynamic memory runs out
Q1) I am facing an issue with the heap memory. I am using the Cjson_Parse function which uses quit a lot of memory. So I am wondering if there is a way to increase the dynamic memory. I already reduced the  CONFIG_MAIN_STACK_SIZE=4096 and increased the CONFIG_HEAP_MEM_POOL_SIZE = 16384 (Max) it helped a bit but not enough.
Q2) https://devzone.nordicsemi.com/nordic/cellular-iot-guides/b/hardware-design/posts/getting-started-with-current-measurements-on-the-nrf9160 I am trying to measure the current using a multi meter but every time I remove the nRF current measurement pin as explained in the link the led turn on and the program bugs out till I put the pin back(During this the board is powered with an external battery).
  • Not sure if this is the log file you meant. So as you can from the log the program restart after receiving that many data or sometime it will just fail to parse the message and continue running. Let me know if you meant a different log file or I need to enable logs from the proj.conf.
    2021-09-01T13:13:42.224Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:42.243Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-01T13:13:42.245Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:42.247Z DEBUG modem << message-id : f426bc36-3424-4ce7-9741-b7895c9ade95
    2021-09-01T13:13:42.249Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-01T13:13:42.251Z DEBUG modem << created    : 1630502011
    2021-09-01T13:13:42.257Z DEBUG modem << ttl        : 1630502071
    2021-09-01T13:13:42.259Z DEBUG modem << frame      : 1
    2021-09-01T13:13:42.262Z DEBUG modem << frames     : 22
    2021-09-01T13:13:42.278Z DEBUG modem << length     : 256
    2021-09-01T13:13:42.281Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:42.282Z DEBUG modem << date_converted 1630502020
    2021-09-01T13:13:42.283Z DEBUG modem << date_ttl 1630502071
    2021-09-01T13:13:42.397Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:42.400Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-01T13:13:42.405Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:42.408Z DEBUG modem << message-id : f426bc36-3424-4ce7-9741-b7895c9ade95
    2021-09-01T13:13:42.413Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-01T13:13:42.423Z DEBUG modem << created    : 1630502011
    2021-09-01T13:13:42.426Z DEBUG modem << ttl        : 1630502071
    2021-09-01T13:13:42.428Z DEBUG modem << frame      : 2
    2021-09-01T13:13:42.430Z DEBUG modem << frames     : 22
    2021-09-01T13:13:42.431Z DEBUG modem << length     : 256
    2021-09-01T13:13:42.432Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:42.443Z DEBUG modem << date_converted 1630502021
    2021-09-01T13:13:42.446Z DEBUG modem << date_ttl 1630502071
    2021-09-01T13:13:42.581Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:42.584Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-01T13:13:42.587Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:42.592Z DEBUG modem << message-id : f426bc36-3424-4ce7-9741-b7895c9ade95
    2021-09-01T13:13:42.613Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-01T13:13:42.617Z DEBUG modem << created    : 1630502011
    2021-09-01T13:13:42.619Z DEBUG modem << ttl        : 1630502071
    2021-09-01T13:13:42.621Z DEBUG modem << frame      : 3
    2021-09-01T13:13:42.623Z DEBUG modem << frames     : 22
    2021-09-01T13:13:42.627Z DEBUG modem << length     : 256
    2021-09-01T13:13:42.630Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:42.633Z DEBUG modem << date_converted 1630502021
    2021-09-01T13:13:42.634Z DEBUG modem << date_ttl 1630502071
    2021-09-01T13:13:42.799Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:42.804Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-01T13:13:42.807Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:42.828Z DEBUG modem << message-id : f426bc36-3424-4ce7-9741-b7895c9ade95
    2021-09-01T13:13:42.848Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-01T13:13:42.850Z DEBUG modem << created    : 1630502011
    2021-09-01T13:13:42.852Z DEBUG modem << ttl        : 1630502071
    2021-09-01T13:13:42.853Z DEBUG modem << frame      : 4
    2021-09-01T13:13:42.855Z DEBUG modem << frames     : 22
    2021-09-01T13:13:42.856Z DEBUG modem << length     : 256
    2021-09-01T13:13:42.857Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:42.860Z DEBUG modem << date_converted 1630502021
    2021-09-01T13:13:42.862Z DEBUG modem << date_ttl 1630502071
    2021-09-01T13:13:42.949Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:42.951Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-01T13:13:42.955Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:42.972Z DEBUG modem << message-id : f426bc36-3424-4ce7-9741-b7895c9ade95
    2021-09-01T13:13:42.974Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-01T13:13:42.976Z DEBUG modem << created    : 1630502011
    2021-09-01T13:13:42.979Z DEBUG modem << ttl        : 1630502071
    2021-09-01T13:13:42.980Z DEBUG modem << frame      : 5
    2021-09-01T13:13:42.982Z DEBUG modem << frames     : 22
    2021-09-01T13:13:42.983Z DEBUG modem << length     : 256
    2021-09-01T13:13:43.002Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:43.004Z DEBUG modem << date_converted 1630502021
    2021-09-01T13:13:43.006Z DEBUG modem << date_ttl 1630502071
    2021-09-01T13:13:43.112Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:43.114Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-01T13:13:43.116Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:43.120Z DEBUG modem << message-id : f426bc36-3424-4ce7-9741-b7895c9ade95
    2021-09-01T13:13:43.122Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-01T13:13:43.125Z DEBUG modem << created    : 1630502011
    2021-09-01T13:13:43.163Z DEBUG modem << ttl        : 1630502071
    2021-09-01T13:13:43.166Z DEBUG modem << frame      : 6
    2021-09-01T13:13:43.167Z DEBUG modem << frames     : 22
    2021-09-01T13:13:43.168Z DEBUG modem << length     : 256
    2021-09-01T13:13:43.170Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:43.171Z DEBUG modem << date_converted 1630502021
    2021-09-01T13:13:43.172Z DEBUG modem << date_ttl 1630502071
    2021-09-01T13:13:43.269Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:43.272Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-01T13:13:43.275Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:43.297Z DEBUG modem << message-id : f426bc36-3424-4ce7-9741-b7895c9ade95
    2021-09-01T13:13:43.300Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-01T13:13:43.301Z DEBUG modem << created    : 1630502011
    2021-09-01T13:13:43.303Z DEBUG modem << ttl        : 1630502071
    2021-09-01T13:13:43.304Z DEBUG modem << frame      : 7
    2021-09-01T13:13:43.305Z DEBUG modem << frames     : 22
    2021-09-01T13:13:43.306Z DEBUG modem << length     : 256
    2021-09-01T13:13:43.307Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:43.309Z DEBUG modem << date_converted 1630502021
    2021-09-01T13:13:43.312Z DEBUG modem << date_ttl 1630502071
    2021-09-01T13:13:43.429Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:43.431Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-01T13:13:43.435Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:43.439Z DEBUG modem << message-id : f426bc36-3424-4ce7-9741-b7895c9ade95
    2021-09-01T13:13:43.455Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-01T13:13:43.457Z DEBUG modem << created    : 1630502011
    2021-09-01T13:13:43.459Z DEBUG modem << ttl        : 1630502071
    2021-09-01T13:13:43.460Z DEBUG modem << frame      : 8
    2021-09-01T13:13:43.462Z DEBUG modem << frames     : 22
    2021-09-01T13:13:43.464Z DEBUG modem << length     : 256
    2021-09-01T13:13:43.465Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:43.481Z DEBUG modem << date_converted 1630502022
    2021-09-01T13:13:43.484Z DEBUG modem << date_ttl 1630502071
    2021-09-01T13:13:43.589Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:43.592Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-01T13:13:43.636Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:43.639Z DEBUG modem << message-id : f426bc36-3424-4ce7-9741-b7895c9ade95
    2021-09-01T13:13:43.640Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-01T13:13:43.641Z DEBUG modem << created    : 1630502012
    2021-09-01T13:13:43.642Z DEBUG modem << ttl        : 1630502072
    2021-09-01T13:13:43.643Z DEBUG modem << frame      : 9
    2021-09-01T13:13:43.644Z DEBUG modem << frames     : 22
    2021-09-01T13:13:43.646Z DEBUG modem << length     : 256
    2021-09-01T13:13:43.647Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:43.648Z DEBUG modem << date_converted 1630502022
    2021-09-01T13:13:43.649Z DEBUG modem << date_ttl 1630502072
    2021-09-01T13:13:43.749Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:43.754Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-01T13:13:43.756Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:43.781Z DEBUG modem << message-id : f426bc36-3424-4ce7-9741-b7895c9ade95
    2021-09-01T13:13:43.785Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-01T13:13:43.787Z DEBUG modem << created    : 1630502012
    2021-09-01T13:13:43.789Z DEBUG modem << ttl        : 1630502072
    2021-09-01T13:13:43.790Z DEBUG modem << frame      : 10
    2021-09-01T13:13:43.792Z DEBUG modem << frames     : 22
    2021-09-01T13:13:43.795Z DEBUG modem << length     : 256
    2021-09-01T13:13:43.796Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:43.798Z DEBUG modem << date_converted 1630502022
    2021-09-01T13:13:43.818Z DEBUG modem << date_ttl 1630502072
    2021-09-01T13:13:43.909Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:43.912Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-01T13:13:43.915Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:43.920Z DEBUG modem << message-id : f426bc36-3424-4ce7-9741-b7895c9ade95
    2021-09-01T13:13:43.922Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-01T13:13:43.924Z DEBUG modem << created    : 1630502012
    2021-09-01T13:13:43.943Z DEBUG modem << ttl        : 1630502072
    2021-09-01T13:13:43.945Z DEBUG modem << frame      : 11
    2021-09-01T13:13:43.946Z DEBUG modem << frames     : 22
    2021-09-01T13:13:43.947Z DEBUG modem << length     : 256
    2021-09-01T13:13:43.949Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:43.950Z DEBUG modem << date_converted 1630502022
    2021-09-01T13:13:43.951Z DEBUG modem << date_ttl 1630502072
    2021-09-01T13:13:44.071Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:44.076Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-01T13:13:44.104Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:44.106Z DEBUG modem << message-id : f426bc36-3424-4ce7-9741-b7895c9ade95
    2021-09-01T13:13:44.108Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-01T13:13:44.110Z DEBUG modem << created    : 1630502012
    2021-09-01T13:13:44.112Z DEBUG modem << ttl        : 1630502072
    2021-09-01T13:13:44.114Z DEBUG modem << frame      : 12
    2021-09-01T13:13:44.115Z DEBUG modem << frames     : 22
    2021-09-01T13:13:44.117Z DEBUG modem << length     : 256
    2021-09-01T13:13:44.118Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:44.119Z DEBUG modem << date_converted 1630502022
    2021-09-01T13:13:44.138Z DEBUG modem << date_ttl 1630502072
    2021-09-01T13:13:44.229Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:44.234Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-01T13:13:44.236Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:44.240Z DEBUG modem << message-id : f426bc36-3424-4ce7-9741-b7895c9ade95
    2021-09-01T13:13:44.265Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-01T13:13:44.267Z DEBUG modem << created    : 1630502012
    2021-09-01T13:13:44.269Z DEBUG modem << ttl        : 1630502072
    2021-09-01T13:13:44.271Z DEBUG modem << frame      : 13
    2021-09-01T13:13:44.272Z DEBUG modem << frames     : 22
    2021-09-01T13:13:44.272Z DEBUG modem << length     : 256
    2021-09-01T13:13:44.273Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:44.273Z DEBUG modem << date_converted 1630502022
    2021-09-01T13:13:44.274Z DEBUG modem << date_ttl 1630502072
    2021-09-01T13:13:44.429Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:44.430Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-01T13:13:44.433Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:44.438Z DEBUG modem << message-id : f426bc36-3424-4ce7-9741-b7895c9ade95
    2021-09-01T13:13:44.440Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-01T13:13:44.456Z DEBUG modem << created    : 1630502012
    2021-09-01T13:13:44.458Z DEBUG modem << ttl        : 1630502072
    2021-09-01T13:13:44.460Z DEBUG modem << frame      : 14
    2021-09-01T13:13:44.462Z DEBUG modem << frames     : 22
    2021-09-01T13:13:44.463Z DEBUG modem << length     : 256
    2021-09-01T13:13:44.464Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:44.480Z DEBUG modem << date_converted 1630502023
    2021-09-01T13:13:44.483Z DEBUG modem << date_ttl 1630502072
    2021-09-01T13:13:44.655Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:44.658Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-01T13:13:44.685Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:44.711Z DEBUG modem << message-id : f426bc36-3424-4ce7-9741-b7895c9ade95
    2021-09-01T13:13:44.714Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-01T13:13:44.715Z DEBUG modem << created    : 1630502012
    2021-09-01T13:13:44.717Z DEBUG modem << ttl        : 1630502072
    2021-09-01T13:13:44.718Z DEBUG modem << frame      : 15
    2021-09-01T13:13:44.719Z DEBUG modem << frames     : 22
    2021-09-01T13:13:44.720Z DEBUG modem << length     : 256
    2021-09-01T13:13:44.722Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:44.723Z DEBUG modem << date_converted 1630502023
    2021-09-01T13:13:44.724Z DEBUG modem << date_ttl 1630502072
    2021-09-01T13:13:44.871Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:44.874Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-01T13:13:44.900Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:44.902Z DEBUG modem << message-id : f426bc36-3424-4ce7-9741-b7895c9ade95
    2021-09-01T13:13:44.903Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-01T13:13:44.905Z DEBUG modem << created    : 1630502012
    2021-09-01T13:13:44.907Z DEBUG modem << ttl        : 1630502072
    2021-09-01T13:13:44.909Z DEBUG modem << frame      : 16
    2021-09-01T13:13:44.910Z DEBUG modem << frames     : 22
    2021-09-01T13:13:44.912Z DEBUG modem << length     : 256
    2021-09-01T13:13:44.913Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:44.933Z DEBUG modem << date_converted 1630502023
    2021-09-01T13:13:44.935Z DEBUG modem << date_ttl 1630502072
    2021-09-01T13:13:45.029Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:45.034Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-01T13:13:45.036Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:45.040Z DEBUG modem << message-id : f426bc36-3424-4ce7-9741-b7895c9ade95
    2021-09-01T13:13:45.082Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-01T13:13:45.103Z DEBUG modem << created    : 1630502013
    2021-09-01T13:13:45.104Z DEBUG modem << ttl        : 1630502073
    2021-09-01T13:13:45.105Z DEBUG modem << frame      : 17
    2021-09-01T13:13:45.107Z DEBUG modem << frames     : 22
    2021-09-01T13:13:45.108Z DEBUG modem << length     : 256
    2021-09-01T13:13:45.109Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:45.111Z DEBUG modem << date_converted 1630502023
    2021-09-01T13:13:45.112Z DEBUG modem << date_ttl 1630502073
    2021-09-01T13:13:45.213Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:45.216Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-01T13:13:45.219Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:45.222Z DEBUG modem << message-id : f426bc36-3424-4ce7-9741-b7895c9ade95
    2021-09-01T13:13:45.224Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-01T13:13:45.251Z DEBUG modem << created    : 1630502013
    2021-09-01T13:13:45.274Z DEBUG modem << ttl        : 1630502073
    2021-09-01T13:13:45.276Z DEBUG modem << frame      : 18
    2021-09-01T13:13:45.278Z DEBUG modem << frames     : 22
    2021-09-01T13:13:45.279Z DEBUG modem << length     : 256
    2021-09-01T13:13:45.281Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:45.283Z DEBUG modem << date_converted 1630502023
    2021-09-01T13:13:45.284Z DEBUG modem << date_ttl 1630502073
    2021-09-01T13:13:45.354Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:45.356Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-01T13:13:45.375Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:45.378Z DEBUG modem << message-id : f426bc36-3424-4ce7-9741-b7895c9ade95
    2021-09-01T13:13:45.379Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-01T13:13:45.380Z DEBUG modem << created    : 1630502013
    2021-09-01T13:13:45.382Z DEBUG modem << ttl        : 1630502073
    2021-09-01T13:13:45.383Z DEBUG modem << frame      : 19
    2021-09-01T13:13:45.384Z DEBUG modem << frames     : 22
    2021-09-01T13:13:45.404Z DEBUG modem >> AT+CESQ
    2021-09-01T13:13:45.406Z DEBUG modem << length     : 256
    2021-09-01T13:13:45.407Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:45.409Z DEBUG modem << date_converted 1630502024
    2021-09-01T13:13:45.410Z DEBUG modem << date_ttl 1630502073
    2021-09-01T13:13:45.431Z DEBUG modem << +CESQ: 99,99,255,255,8,42
    2021-09-01T13:13:45.433Z DEBUG modem << OK
    2021-09-01T13:13:45.554Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:45.556Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-01T13:13:45.558Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:45.560Z DEBUG modem << message-id : f426bc36-3424-4ce7-9741-b7895c9ade95
    2021-09-01T13:13:45.562Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-01T13:13:45.564Z DEBUG modem << created    : 1630502013
    2021-09-01T13:13:45.565Z DEBUG modem << ttl        : 1630502073
    2021-09-01T13:13:45.565Z DEBUG modem << frame      : 20
    2021-09-01T13:13:45.566Z DEBUG modem << frames     : 22
    2021-09-01T13:13:45.567Z DEBUG modem << length     : 256
    2021-09-01T13:13:45.586Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:45.588Z DEBUG modem << date_converted 1630502024
    2021-09-01T13:13:45.590Z DEBUG modem << date_ttl 1630502073
    2021-09-01T13:13:45.729Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:45.734Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-01T13:13:45.737Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:45.741Z DEBUG modem << message-id : f426bc36-3424-4ce7-9741-b7895c9ade95
    2021-09-01T13:13:45.797Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-01T13:13:45.819Z DEBUG modem << created    : 1630502013
    2021-09-01T13:13:45.821Z DEBUG modem << ttl        : 1630502073
    2021-09-01T13:13:45.822Z DEBUG modem << frame      : 21
    2021-09-01T13:13:45.823Z DEBUG modem << frames     : 22
    2021-09-01T13:13:45.824Z DEBUG modem << length     : 256
    2021-09-01T13:13:45.825Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:45.827Z DEBUG modem << date_converted 1630502024
    2021-09-01T13:13:45.830Z DEBUG modem << date_ttl 1630502073
    2021-09-01T13:13:45.945Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:45.949Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-01T13:13:45.952Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:45.956Z DEBUG modem << message-id : f426bc36-3424-4ce7-9741-b7895c9ade95
    2021-09-01T13:13:45.959Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-01T13:13:45.990Z DEBUG modem << created    : 1630502013
    2021-09-01T13:13:46.041Z DEBUG modem << ttl        : 1630502073
    2021-09-01T13:13:46.043Z DEBUG modem << frame      : 22
    2021-09-01T13:13:46.044Z DEBUG modem << frames     : 22
    2021-09-01T13:13:46.045Z DEBUG modem << length     : 117
    2021-09-01T13:13:46.046Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:46.047Z DEBUG modem << date_converted 1630502024
    2021-09-01T13:13:46.048Z DEBUG modem << date_ttl 1630502073
    2021-09-01T13:13:46.050Z DEBUG modem <<  **** Message is within time constrain ****
    2021-09-01T13:13:46.051Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:46.052Z DEBUG modem << PAYLOAD TO MESSAGE->CONTENT
    2021-09-01T13:13:46.071Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:46.073Z DEBUG modem << object: 2
    2021-09-01T13:13:46.074Z DEBUG modem << method: 1
    2021-09-01T13:13:46.075Z DEBUG modem << -----------------------------------------------
    2021-09-01T13:13:46.076Z DEBUG modem << INIT DISPlAY
    2021-09-01T13:13:46.098Z DEBUG modem << upperleft =[null, null]
    2021-09-01T13:13:46.099Z DEBUG modem << Upperleft element = 0
    2021-09-01T13:13:46.101Z DEBUG modem << Upperleft element = 0
    2021-09-01T13:13:46.102Z DEBUG modem << lowerright =[null, null]
    2021-09-01T13:13:46.103Z DEBUG modem << Lowerright element = 0
    2021-09-01T13:13:46.104Z DEBUG modem << Lowerright element = 0
    2021-09-01T13:13:46.105Z DEBUG modem << dimensions =[110, 110]
    2021-09-01T13:13:46.274Z DEBUG modem << *** Booting Zephyr OS build v2.4.99-ncs2  ***
    2021-09-01T13:13:46.276Z DEBUG modem << Flash regionsDomainPermissions
    2021-09-01T13:13:46.277Z DEBUG modem << 00 00 0x00000 0x08000 Securerwxl
    2021-09-01T13:13:46.280Z DEBUG modem << 01 31 0x08000 0x100000 Non-Securerwxl
    2021-09-01T13:13:46.300Z DEBUG modem << Non-secure callable region 0 placed in flash region 0 with size 32.
    2021-09-01T13:13:46.447Z DEBUG modem << SRAM regionDomainPermissions
    2021-09-01T13:13:46.451Z DEBUG modem << 00 07 0x00000 0x10000 Securerwxl
    2021-09-01T13:13:46.454Z DEBUG modem << 08 31 0x10000 0x40000 Non-Securerwxl
    2021-09-01T13:13:46.457Z DEBUG modem << PeripheralDomainStatus
    2021-09-01T13:13:46.510Z DEBUG modem << 00 NRF_P0               Non-SecureOK
    2021-09-01T13:13:46.531Z DEBUG modem << 01 NRF_CLOCK            Non-SecureOK
    2021-09-01T13:13:46.533Z DEBUG modem << 02 NRF_RTC0             Non-SecureOK
    2021-09-01T13:13:46.534Z DEBUG modem << 03 NRF_RTC1             Non-SecureOK
    2021-09-01T13:13:46.535Z DEBUG modem << 04 NRF_NVMC             Non-SecureOK
    2021-09-01T13:13:46.536Z DEBUG modem << 05 NRF_UARTE1           Non-SecureOK
    2021-09-01T13:13:46.537Z DEBUG modem << 06 NRF_UARTE2           SecureSKIP
    2021-09-01T13:13:46.538Z DEBUG modem << 07 NRF_TWIM2            Non-SecureOK
    2021-09-01T13:13:46.538Z DEBUG modem << 08 NRF_SPIM3            Non-SecureOK
    2021-09-01T13:13:46.539Z DEBUG modem << 09 NRF_TIMER0           Non-SecureOK
    2021-09-01T13:13:46.540Z DEBUG modem << 10 NRF_TIMER1           Non-SecureOK
    2021-09-01T13:13:46.541Z DEBUG modem << 11 NRF_TIMER2           Non-SecureOK
    2021-09-01T13:13:46.542Z DEBUG modem << 12 NRF_SAADC            Non-SecureOK
    2021-09-01T13:13:46.545Z DEBUG modem << 13 NRF_PWM0             Non-SecureOK
    2021-09-01T13:13:46.547Z DEBUG modem << 14 NRF_PWM1             Non-SecureOK
    2021-09-01T13:13:46.548Z DEBUG modem << 15 NRF_PWM2             Non-SecureOK
    For some reason, the error message isn't printed at your end.
    Could you try to add the following to your prj.conf:
    CONFIG_LOG_MINIMAL=y
    CONFIG_RESET_ON_FATAL_ERROR=n
    And also to your secure image (spm), by creating the file <your-application-folder>/child_image/spm.conf containing:
    This would require a re-configuration of your project (delete the build folder and re-generate the project)
    Håkon
    Still no change in the log except for the reset not occurring anymore.
    2021-09-02T10:59:00.500Z DEBUG modem << +CSCON: 0
    2021-09-02T10:59:00.575Z DEBUG modem << +CSCON: 1
    2021-09-02T10:59:00.833Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:00.838Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:00.841Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:00.861Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:00.867Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:00.869Z DEBUG modem << created    : 1630580329
    2021-09-02T10:59:00.875Z DEBUG modem << ttl        : 1630580389
    2021-09-02T10:59:00.878Z DEBUG modem << frame      : 1
    2021-09-02T10:59:00.882Z DEBUG modem << frames     : 25
    2021-09-02T10:59:00.884Z DEBUG modem << length     : 256
    2021-09-02T10:59:00.886Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:00.888Z DEBUG modem << date_converted 1630580339
    2021-09-02T10:59:00.890Z DEBUG modem << date_ttl 1630580389
    2021-09-02T10:59:00.987Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:00.991Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:01.010Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:01.014Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:01.017Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:01.019Z DEBUG modem << created    : 1630580329
    2021-09-02T10:59:01.024Z DEBUG modem << ttl        : 1630580389
    2021-09-02T10:59:01.026Z DEBUG modem << frame      : 2
    2021-09-02T10:59:01.028Z DEBUG modem << frames     : 25
    2021-09-02T10:59:01.031Z DEBUG modem << length     : 256
    2021-09-02T10:59:01.033Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:01.051Z DEBUG modem << date_converted 1630580339
    2021-09-02T10:59:01.054Z DEBUG modem << date_ttl 1630580389
    2021-09-02T10:59:01.157Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:01.186Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:01.190Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:01.216Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:01.218Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:01.221Z DEBUG modem << created    : 1630580329
    2021-09-02T10:59:01.223Z DEBUG modem << ttl        : 1630580389
    2021-09-02T10:59:01.225Z DEBUG modem << frame      : 3
    2021-09-02T10:59:01.227Z DEBUG modem << frames     : 25
    2021-09-02T10:59:01.229Z DEBUG modem << length     : 256
    2021-09-02T10:59:01.231Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:01.233Z DEBUG modem << date_converted 1630580339
    2021-09-02T10:59:01.235Z DEBUG modem << date_ttl 1630580389
    2021-09-02T10:59:01.307Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:01.325Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:01.342Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:01.345Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:01.347Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:01.349Z DEBUG modem << created    : 1630580329
    2021-09-02T10:59:01.350Z DEBUG modem << ttl        : 1630580389
    2021-09-02T10:59:01.351Z DEBUG modem << frame      : 4
    2021-09-02T10:59:01.352Z DEBUG modem << frames     : 25
    2021-09-02T10:59:01.368Z DEBUG modem << length     : 256
    2021-09-02T10:59:01.370Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:01.371Z DEBUG modem << date_converted 1630580340
    2021-09-02T10:59:01.372Z DEBUG modem << date_ttl 1630580389
    2021-09-02T10:59:01.468Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:01.472Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:01.497Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:01.519Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:01.522Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:01.524Z DEBUG modem << created    : 1630580329
    2021-09-02T10:59:01.526Z DEBUG modem << ttl        : 1630580389
    2021-09-02T10:59:01.528Z DEBUG modem << frame      : 5
    2021-09-02T10:59:01.530Z DEBUG modem << frames     : 25
    2021-09-02T10:59:01.531Z DEBUG modem << length     : 256
    2021-09-02T10:59:01.533Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:01.534Z DEBUG modem << date_converted 1630580340
    2021-09-02T10:59:01.536Z DEBUG modem << date_ttl 1630580389
    2021-09-02T10:59:01.619Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:01.623Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:01.647Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:01.666Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:01.668Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:01.670Z DEBUG modem << created    : 1630580330
    2021-09-02T10:59:01.671Z DEBUG modem << ttl        : 1630580390
    2021-09-02T10:59:01.673Z DEBUG modem << frame      : 6
    2021-09-02T10:59:01.675Z DEBUG modem << frames     : 25
    2021-09-02T10:59:01.676Z DEBUG modem << length     : 256
    2021-09-02T10:59:01.678Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:01.679Z DEBUG modem << date_converted 1630580340
    2021-09-02T10:59:01.699Z DEBUG modem << date_ttl 1630580390
    2021-09-02T10:59:01.779Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:01.783Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:01.786Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:01.790Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:01.813Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:01.837Z DEBUG modem << created    : 1630580330
    2021-09-02T10:59:01.839Z DEBUG modem << ttl        : 1630580390
    2021-09-02T10:59:01.841Z DEBUG modem << frame      : 7
    2021-09-02T10:59:01.843Z DEBUG modem << frames     : 25
    2021-09-02T10:59:01.844Z DEBUG modem << length     : 256
    2021-09-02T10:59:01.846Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:01.848Z DEBUG modem << date_converted 1630580340
    2021-09-02T10:59:01.850Z DEBUG modem << date_ttl 1630580390
    2021-09-02T10:59:01.939Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:01.956Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:01.975Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:01.978Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:01.980Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:01.981Z DEBUG modem << created    : 1630580330
    2021-09-02T10:59:01.982Z DEBUG modem << ttl        : 1630580390
    2021-09-02T10:59:01.983Z DEBUG modem << frame      : 8
    2021-09-02T10:59:01.986Z DEBUG modem << frames     : 25
    2021-09-02T10:59:02.003Z DEBUG modem << length     : 256
    2021-09-02T10:59:02.005Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:02.006Z DEBUG modem << date_converted 1630580340
    2021-09-02T10:59:02.008Z DEBUG modem << date_ttl 1630580390
    2021-09-02T10:59:02.111Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:02.115Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:02.120Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:02.123Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:02.146Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:02.148Z DEBUG modem << created    : 1630580330
    2021-09-02T10:59:02.171Z DEBUG modem << ttl        : 1630580390
    2021-09-02T10:59:02.172Z DEBUG modem << frame      : 9
    2021-09-02T10:59:02.174Z DEBUG modem << frames     : 25
    2021-09-02T10:59:02.176Z DEBUG modem << length     : 256
    2021-09-02T10:59:02.177Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:02.179Z DEBUG modem << date_converted 1630580340
    2021-09-02T10:59:02.180Z DEBUG modem << date_ttl 1630580390
    2021-09-02T10:59:02.260Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:02.262Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:02.265Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:02.270Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:02.272Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:02.288Z DEBUG modem << created    : 1630580330
    2021-09-02T10:59:02.304Z DEBUG modem << ttl        : 1630580390
    2021-09-02T10:59:02.307Z DEBUG modem << frame      : 10
    2021-09-02T10:59:02.309Z DEBUG modem << frames     : 25
    2021-09-02T10:59:02.311Z DEBUG modem << length     : 256
    2021-09-02T10:59:02.312Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:02.313Z DEBUG modem << date_converted 1630580341
    2021-09-02T10:59:02.314Z DEBUG modem << date_ttl 1630580390
    2021-09-02T10:59:02.421Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:02.448Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:02.472Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:02.475Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:02.477Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:02.479Z DEBUG modem << created    : 1630580330
    2021-09-02T10:59:02.481Z DEBUG modem << ttl        : 1630580390
    2021-09-02T10:59:02.482Z DEBUG modem << frame      : 11
    2021-09-02T10:59:02.483Z DEBUG modem << frames     : 25
    2021-09-02T10:59:02.484Z DEBUG modem << length     : 256
    2021-09-02T10:59:02.485Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:02.486Z DEBUG modem << date_converted 1630580341
    2021-09-02T10:59:02.487Z DEBUG modem << date_ttl 1630580390
    2021-09-02T10:59:02.578Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:02.582Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:02.584Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:02.589Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:02.615Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:02.617Z DEBUG modem << created    : 1630580330
    2021-09-02T10:59:02.619Z DEBUG modem << ttl        : 1630580390
    2021-09-02T10:59:02.620Z DEBUG modem << frame      : 12
    2021-09-02T10:59:02.622Z DEBUG modem << frames     : 25
    2021-09-02T10:59:02.625Z DEBUG modem << length     : 256
    2021-09-02T10:59:02.626Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:02.628Z DEBUG modem << date_converted 1630580341
    2021-09-02T10:59:02.630Z DEBUG modem << date_ttl 1630580390
    2021-09-02T10:59:02.655Z DEBUG modem >> AT+CESQ
    2021-09-02T10:59:02.672Z DEBUG modem << +CESQ: 99,99,255,255,22,44
    2021-09-02T10:59:02.675Z DEBUG modem << OK
    2021-09-02T10:59:02.738Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:02.760Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:02.762Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:02.764Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:02.765Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:02.766Z DEBUG modem << created    : 1630580330
    2021-09-02T10:59:02.768Z DEBUG modem << ttl        : 1630580390
    2021-09-02T10:59:02.770Z DEBUG modem << frame      : 13
    2021-09-02T10:59:02.771Z DEBUG modem << frames     : 25
    2021-09-02T10:59:02.772Z DEBUG modem << length     : 256
    2021-09-02T10:59:02.774Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:02.776Z DEBUG modem << date_converted 1630580341
    2021-09-02T10:59:02.794Z DEBUG modem << date_ttl 1630580390
    2021-09-02T10:59:02.908Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:02.912Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:02.915Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:02.919Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:02.946Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:02.968Z DEBUG modem << created    : 1630580331
    2021-09-02T10:59:02.970Z DEBUG modem << ttl        : 1630580391
    2021-09-02T10:59:02.973Z DEBUG modem << frame      : 14
    2021-09-02T10:59:02.975Z DEBUG modem << frames     : 25
    2021-09-02T10:59:02.977Z DEBUG modem << length     : 256
    2021-09-02T10:59:02.979Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:02.981Z DEBUG modem << date_converted 1630580341
    2021-09-02T10:59:02.982Z DEBUG modem << date_ttl 1630580391
    2021-09-02T10:59:03.058Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:03.060Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:03.064Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:03.069Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:03.089Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:03.091Z DEBUG modem << created    : 1630580331
    2021-09-02T10:59:03.092Z DEBUG modem << ttl        : 1630580391
    2021-09-02T10:59:03.093Z DEBUG modem << frame      : 15
    2021-09-02T10:59:03.095Z DEBUG modem << frames     : 25
    2021-09-02T10:59:03.096Z DEBUG modem << length     : 256
    2021-09-02T10:59:03.097Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:03.098Z DEBUG modem << date_converted 1630580341
    2021-09-02T10:59:03.099Z DEBUG modem << date_ttl 1630580391
    2021-09-02T10:59:03.218Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:03.220Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:03.236Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:03.238Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:03.240Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:03.242Z DEBUG modem << created    : 1630580331
    2021-09-02T10:59:03.243Z DEBUG modem << ttl        : 1630580391
    2021-09-02T10:59:03.261Z DEBUG modem << frame      : 16
    2021-09-02T10:59:03.263Z DEBUG modem << frames     : 25
    2021-09-02T10:59:03.265Z DEBUG modem << length     : 256
    2021-09-02T10:59:03.266Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:03.286Z DEBUG modem << date_converted 1630580341
    2021-09-02T10:59:03.288Z DEBUG modem << date_ttl 1630580391
    2021-09-02T10:59:03.378Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:03.380Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:03.384Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:03.407Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:03.410Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:03.411Z DEBUG modem << created    : 1630580331
    2021-09-02T10:59:03.412Z DEBUG modem << ttl        : 1630580391
    2021-09-02T10:59:03.413Z DEBUG modem << frame      : 17
    2021-09-02T10:59:03.415Z DEBUG modem << frames     : 25
    2021-09-02T10:59:03.416Z DEBUG modem << length     : 256
    2021-09-02T10:59:03.417Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:03.439Z DEBUG modem << date_converted 1630580342
    2021-09-02T10:59:03.442Z DEBUG modem << date_ttl 1630580391
    2021-09-02T10:59:03.542Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:03.544Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:03.546Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:03.549Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:03.551Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:03.581Z DEBUG modem << created    : 1630580331
    2021-09-02T10:59:03.583Z DEBUG modem << ttl        : 1630580391
    2021-09-02T10:59:03.585Z DEBUG modem << frame      : 18
    2021-09-02T10:59:03.587Z DEBUG modem << frames     : 25
    2021-09-02T10:59:03.589Z DEBUG modem << length     : 256
    2021-09-02T10:59:03.591Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:03.593Z DEBUG modem << date_converted 1630580342
    2021-09-02T10:59:03.595Z DEBUG modem << date_ttl 1630580391
    2021-09-02T10:59:03.698Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:03.700Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:03.725Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:03.727Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:03.728Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:03.730Z DEBUG modem << created    : 1630580331
    2021-09-02T10:59:03.731Z DEBUG modem << ttl        : 1630580391
    2021-09-02T10:59:03.732Z DEBUG modem << frame      : 19
    2021-09-02T10:59:03.733Z DEBUG modem << frames     : 25
    2021-09-02T10:59:03.734Z DEBUG modem << length     : 256
    2021-09-02T10:59:03.735Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:03.736Z DEBUG modem << date_converted 1630580342
    2021-09-02T10:59:03.739Z DEBUG modem << date_ttl 1630580391
    2021-09-02T10:59:03.873Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:03.876Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:03.878Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:03.880Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:03.882Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:03.885Z DEBUG modem << created    : 1630580331
    2021-09-02T10:59:03.909Z DEBUG modem << ttl        : 1630580391
    2021-09-02T10:59:03.934Z DEBUG modem << frame      : 20
    2021-09-02T10:59:03.936Z DEBUG modem << frames     : 25
    2021-09-02T10:59:03.937Z DEBUG modem << length     : 256
    2021-09-02T10:59:03.939Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:03.940Z DEBUG modem << date_converted 1630580342
    2021-09-02T10:59:03.942Z DEBUG modem << date_ttl 1630580391
    2021-09-02T10:59:04.028Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:04.031Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:04.034Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:04.062Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:04.064Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:04.065Z DEBUG modem << created    : 1630580331
    2021-09-02T10:59:04.067Z DEBUG modem << ttl        : 1630580391
    2021-09-02T10:59:04.068Z DEBUG modem << frame      : 21
    2021-09-02T10:59:04.070Z DEBUG modem << frames     : 25
    2021-09-02T10:59:04.071Z DEBUG modem << length     : 256
    2021-09-02T10:59:04.073Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:04.074Z DEBUG modem << date_converted 1630580342
    2021-09-02T10:59:04.095Z DEBUG modem << date_ttl 1630580391
    2021-09-02T10:59:04.178Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:04.180Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:04.184Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:04.211Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:04.213Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:04.215Z DEBUG modem << created    : 1630580331
    2021-09-02T10:59:04.216Z DEBUG modem << ttl        : 1630580391
    2021-09-02T10:59:04.218Z DEBUG modem << frame      : 22
    2021-09-02T10:59:04.220Z DEBUG modem << frames     : 25
    2021-09-02T10:59:04.221Z DEBUG modem << length     : 256
    2021-09-02T10:59:04.223Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:04.224Z DEBUG modem << date_converted 1630580342
    2021-09-02T10:59:04.244Z DEBUG modem << date_ttl 1630580391
    2021-09-02T10:59:04.339Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:04.342Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:04.344Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:04.349Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:04.378Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:04.380Z DEBUG modem << created    : 1630580332
    2021-09-02T10:59:04.381Z DEBUG modem << ttl        : 1630580392
    2021-09-02T10:59:04.383Z DEBUG modem << frame      : 23
    2021-09-02T10:59:04.384Z DEBUG modem << frames     : 25
    2021-09-02T10:59:04.387Z DEBUG modem << length     : 256
    2021-09-02T10:59:04.388Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:04.390Z DEBUG modem << date_converted 1630580343
    2021-09-02T10:59:04.391Z DEBUG modem << date_ttl 1630580392
    2021-09-02T10:59:04.498Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:04.528Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:04.554Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:04.555Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:04.557Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:04.558Z DEBUG modem << created    : 1630580332
    2021-09-02T10:59:04.560Z DEBUG modem << ttl        : 1630580392
    2021-09-02T10:59:04.560Z DEBUG modem << frame      : 24
    2021-09-02T10:59:04.561Z DEBUG modem << frames     : 25
    2021-09-02T10:59:04.562Z DEBUG modem << length     : 256
    2021-09-02T10:59:04.563Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:04.563Z DEBUG modem << date_converted 1630580343
    2021-09-02T10:59:04.564Z DEBUG modem << date_ttl 1630580392
    2021-09-02T10:59:04.680Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:04.683Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T10:59:04.717Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:04.746Z DEBUG modem << message-id : 537c3870-668e-43d1-8c99-8c79fefb774f
    2021-09-02T10:59:04.748Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T10:59:04.749Z DEBUG modem << created    : 1630580332
    2021-09-02T10:59:04.751Z DEBUG modem << ttl        : 1630580392
    2021-09-02T10:59:04.754Z DEBUG modem << frame      : 25
    2021-09-02T10:59:04.756Z DEBUG modem << frames     : 25
    2021-09-02T10:59:04.757Z DEBUG modem << length     : 82
    2021-09-02T10:59:04.758Z DEBUG modem << -----------------------------------------------
    2021-09-02T10:59:04.759Z DEBUG modem << date_converted 1630580343
    2021-09-02T10:59:04.760Z DEBUG modem << date_ttl 1630580392
    2021-09-02T10:59:05.190Z DEBUG modem << +CEREG: 1,"76C1","014AAE00",7,,,"00100001","10111110"
    2021-09-02T10:59:05.237Z DEBUG modem >> AT+COPS=3,2
    2021-09-02T10:59:05.273Z DEBUG modem << OK
    2021-09-02T10:59:05.277Z DEBUG modem >> AT+COPS?
    2021-09-02T10:59:05.311Z DEBUG modem << +COPS: 0,2,"24201",7
    2021-09-02T10:59:05.314Z DEBUG modem << OK
    2021-09-02T10:59:05.344Z DEBUG modem >> AT%XCBAND
    2021-09-02T10:59:05.380Z DEBUG modem << %XCBAND: 20
    When it should be parsing like that with smaller message.
    021-09-02T11:00:04.662Z DEBUG modem << -----------------------------------------------
    2021-09-02T11:00:04.667Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T11:00:04.672Z DEBUG modem << -----------------------------------------------
    2021-09-02T11:00:04.722Z DEBUG modem << message-id : fdcb9a63-8a8a-42d4-a48b-9d5a8f9d6434
    2021-09-02T11:00:04.725Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T11:00:04.727Z DEBUG modem << created    : 1630580396
    2021-09-02T11:00:04.729Z DEBUG modem << ttl        : 1630580456
    2021-09-02T11:00:04.732Z DEBUG modem << frame      : 1
    2021-09-02T11:00:04.734Z DEBUG modem << frames     : 6
    2021-09-02T11:00:04.735Z DEBUG modem << length     : 256
    2021-09-02T11:00:04.736Z DEBUG modem << -----------------------------------------------
    2021-09-02T11:00:04.738Z DEBUG modem << date_converted 1630580403
    2021-09-02T11:00:04.739Z DEBUG modem << date_ttl 1630580456
    2021-09-02T11:00:04.835Z DEBUG modem << -----------------------------------------------
    2021-09-02T11:00:04.837Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T11:00:04.869Z DEBUG modem << -----------------------------------------------
    2021-09-02T11:00:04.872Z DEBUG modem << message-id : fdcb9a63-8a8a-42d4-a48b-9d5a8f9d6434
    2021-09-02T11:00:04.874Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T11:00:04.875Z DEBUG modem << created    : 1630580396
    2021-09-02T11:00:04.877Z DEBUG modem << ttl        : 1630580456
    2021-09-02T11:00:04.878Z DEBUG modem << frame      : 2
    2021-09-02T11:00:04.880Z DEBUG modem << frames     : 6
    2021-09-02T11:00:04.881Z DEBUG modem << length     : 256
    2021-09-02T11:00:04.882Z DEBUG modem << -----------------------------------------------
    2021-09-02T11:00:04.884Z DEBUG modem << date_converted 1630580403
    2021-09-02T11:00:04.885Z DEBUG modem << date_ttl 1630580456
    2021-09-02T11:00:04.987Z DEBUG modem << -----------------------------------------------
    2021-09-02T11:00:05.031Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T11:00:05.034Z DEBUG modem << -----------------------------------------------
    2021-09-02T11:00:05.036Z DEBUG modem << message-id : fdcb9a63-8a8a-42d4-a48b-9d5a8f9d6434
    2021-09-02T11:00:05.039Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T11:00:05.041Z DEBUG modem << created    : 1630580396
    2021-09-02T11:00:05.043Z DEBUG modem << ttl        : 1630580456
    2021-09-02T11:00:05.045Z DEBUG modem << frame      : 3
    2021-09-02T11:00:05.048Z DEBUG modem << frames     : 6
    2021-09-02T11:00:05.050Z DEBUG modem << length     : 256
    2021-09-02T11:00:05.050Z DEBUG modem << -----------------------------------------------
    2021-09-02T11:00:05.051Z DEBUG modem << date_converted 1630580403
    2021-09-02T11:00:05.052Z DEBUG modem << date_ttl 1630580456
    2021-09-02T11:00:05.149Z DEBUG modem << -----------------------------------------------
    2021-09-02T11:00:05.153Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T11:00:05.193Z DEBUG modem << -----------------------------------------------
    2021-09-02T11:00:05.229Z DEBUG modem << message-id : fdcb9a63-8a8a-42d4-a48b-9d5a8f9d6434
    2021-09-02T11:00:05.231Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T11:00:05.233Z DEBUG modem << created    : 1630580396
    2021-09-02T11:00:05.235Z DEBUG modem << ttl        : 1630580456
    2021-09-02T11:00:05.236Z DEBUG modem << frame      : 4
    2021-09-02T11:00:05.237Z DEBUG modem << frames     : 6
    2021-09-02T11:00:05.239Z DEBUG modem << length     : 256
    2021-09-02T11:00:05.241Z DEBUG modem << -----------------------------------------------
    2021-09-02T11:00:05.243Z DEBUG modem << date_converted 1630580403
    2021-09-02T11:00:05.245Z DEBUG modem << date_ttl 1630580456
    2021-09-02T11:00:05.309Z DEBUG modem << -----------------------------------------------
    2021-09-02T11:00:05.311Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T11:00:05.313Z DEBUG modem << -----------------------------------------------
    2021-09-02T11:00:05.318Z DEBUG modem << message-id : fdcb9a63-8a8a-42d4-a48b-9d5a8f9d6434
    2021-09-02T11:00:05.320Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T11:00:05.354Z DEBUG modem << created    : 1630580397
    2021-09-02T11:00:05.356Z DEBUG modem << ttl        : 1630580457
    2021-09-02T11:00:05.358Z DEBUG modem << frame      : 5
    2021-09-02T11:00:05.360Z DEBUG modem << frames     : 6
    2021-09-02T11:00:05.361Z DEBUG modem << length     : 256
    2021-09-02T11:00:05.363Z DEBUG modem << -----------------------------------------------
    2021-09-02T11:00:05.364Z DEBUG modem << date_converted 1630580404
    2021-09-02T11:00:05.365Z DEBUG modem << date_ttl 1630580457
    2021-09-02T11:00:05.448Z DEBUG modem << -----------------------------------------------
    2021-09-02T11:00:05.451Z DEBUG modem << PAYLOAD TO MESSAGE
    2021-09-02T11:00:05.453Z DEBUG modem << -----------------------------------------------
    2021-09-02T11:00:05.491Z DEBUG modem << message-id : fdcb9a63-8a8a-42d4-a48b-9d5a8f9d6434
    2021-09-02T11:00:05.493Z DEBUG modem << device-to  : 17dk8ab4jelm5h
    2021-09-02T11:00:05.495Z DEBUG modem << created    : 1630580397
    2021-09-02T11:00:05.497Z DEBUG modem << ttl        : 1630580457
    2021-09-02T11:00:05.498Z DEBUG modem << frame      : 6
    2021-09-02T11:00:05.499Z DEBUG modem << frames     : 6
    2021-09-02T11:00:05.500Z DEBUG modem << length     : 64
    2021-09-02T11:00:05.501Z DEBUG modem << -----------------------------------------------
    2021-09-02T11:00:05.502Z DEBUG modem << date_converted 1630580404
    2021-09-02T11:00:05.503Z DEBUG modem << date_ttl 1630580457
    2021-09-02T11:00:05.504Z DEBUG modem <<  **** Message is within time constrain ****
    2021-09-02T11:00:05.507Z DEBUG modem << -----------------------------------------------
    2021-09-02T11:00:05.509Z DEBUG modem << PAYLOAD TO MESSAGE->CONTENT
    2021-09-02T11:00:05.543Z DEBUG modem << -----------------------------------------------
    2021-09-02T11:00:05.545Z DEBUG modem << object: 2
    2021-09-02T11:00:05.547Z DEBUG modem << method: 1
    2021-09-02T11:00:05.549Z DEBUG modem << -----------------------------------------------
    2021-09-02T11:00:05.550Z DEBUG modem << INIT DISPlAY
    2021-09-02T11:00:05.550Z DEBUG modem << upperleft =[null, null]
    2021-09-02T11:00:05.551Z DEBUG modem << Upperleft element = 0
    2021-09-02T11:00:05.552Z DEBUG modem << Upperleft element = 0
    2021-09-02T11:00:05.552Z DEBUG modem << lowerright =[null, null]
    2021-09-02T11:00:05.553Z DEBUG modem << Lowerright element = 0
    2021-09-02T11:00:05.554Z DEBUG modem << Lowerright element = 0
    2021-09-02T11:00:05.556Z DEBUG modem << dimensions =[50, 50]
    2021-09-02T11:00:05.752Z DEBUG modem << Main =[255, 255, 252, 97, 255, 255, 192, 255, 255, 248, 33, 159, 255, 192, 255, 255, 248, 33, 15, 255, 192, 255, 255, 248, 33, 15, 255, 192, 255, 255, 248, 33, 9, 255, 192, 255, 255, 248, 33, 9, 255, 192, 255, 255, 248, 33, 0, 255, 192, 255, 255, 248, 33, 0, 255, 192, 255, 255, 248, 51, 144, 255, 192, 255, 255, 252, 63, 240, 255, 192, 255, 255, 252, 127, 249, 255, 192, 255, 255, 255, 255, 255, 255, 192, 255, 255, 255, 255, 255, 255, 192, 255, 255, 255, 255, 254, 127, 192, 255, 255, 255, 255, 248, 31, 192, 255, 255, 255, 255, 240, 15, 192, 255, 255, 255, 255, 224, 7, 192, 255, 255, 255, 255, 224, 7, 192, 255, 255, 255, 255, 192, 3, 192, 224, 63, 255, 255, 192, 3, 192, 224, 63, 255, 255, 192, 3, 192, 224, 63, 255, 255, 128, 1, 192, 224, 63, 255, 255, 128, 1, 192, 227, 255, 255, 255, 128, 1, 192, 227, 255, 255, 255, 128, 1, 192, 227, 240, 230, 32, 0, 0, 192, 227, 224, 70, 32, 0, 0, 192, 227, 224, 70, 32, 0, 0, 192, 227, 192, 70, 32, 0, 0, 192, 227, 196, 70, 32, 0, 0, 192, 224, 70, 6, 35, 0, 0, 192, 224, 70, 6, 35, 0, 0, 192, 224, 78, 6, 39, 0, 0, 192, 224, 78, 6, 39, 0, 0, 192, 227, 142, 6, 39, 0, 0, 192, 227, 142, 6, 39, 0, 0, 192, 227, 142, 6, 39, 0, 0, 192, 227, 206, 6, 39, 0, 0, 192, 227, 206, 6, 39, 0, 0, 192, 227, 196, 4, 39, 128, 1, 192, 227, 196, 96, 39, 128, 1, 192, 227, 192, 96, 39, 128, 1, 192, 227, 192, 96, 39, 128, 1, 192, 227, 224, 224, 39, 192, 3, 192, 227, 240, 240, 39, 192, 3, 192, 255, 255, 255, 255, 192, 3, 192, 255, 255, 255, 255, 224, 7, 192, 255, 255, 255, 255, 240, 7, 192, 255, 255, 255, 255, 240, 15, 192, 255, 255, 255, 255, 248, 31, 192]https://devzone.nordicsemi.com/tinymce//apis/embeddables/configure?typeId=dc8ab71f-3b98-42d9-b0f6-e21e02a0f8e2&id=undefined#
    Thanks for he help. If you have more ideas do let me know.
    Kind regards
  • Could you enter debug mode and see where its stuck?
    And please share the call stack (with the content of variable "esf_copy")
    Håkon
