Getting ERROR: getaddrinfo failed -11 in MQTT connection
Hi Dev team,
I have been working with the MQTT example and building up my application. I establish a successful connection with the broker and everything runs fine for 5-6 days. Then I get the (ERROR: getaddrinfo failed -11 ) error and the MQTT connection does not happen. I looked into the code and found that this error is because the broker's address is not obtained.
I looked into the errno and found that -11 refers to "No more processes".
I could not understand why this error comes up suddenly and how could I solve this issue.
Its strange because it comes up after things have been running smoothly.
Adeel.
  • Hi Oyvind,
    It would be hard to provide it now as I had to make the device working again. The issue does not have a periodic trend so to say. I have observed it happen after every 6-7 days of deployment, and I have observed it happen twice.
    The error occurs when I try to connect to MQTT and it goes into the broker_init() function in mqtt library.
      err = getaddrinfo(hostname, NULL, &hints, &result);
      if (err) {
        printk("ERROR: getaddrinfo failed %d\n", err);
        return;
    Normally it directly fetches the IP and MQTT connects, but when this errors occurs- I believe its unable to fetch the IP or so. Issue is when this error occurs, it never resolves itself later on till I reset it. I was hoping for a clean workaround for this (right now I do a soft reboot when I get this).
    Adeel.
  • Hi Adeel,
    Have you verified that the connection is not lost, or that the broker is online? That is what our developers are asking.
    Thanks.
    -Øyvind
  • Hi Oyvind,
    Yes the broker is online. I verified that as I could connect to it through MQTT.fx . Also, out of the 5 devices that I have, 3 had this getaddrinfo failed issue while the other 2 were working perfectly. I had started all 5 of them at the same time.
    Could it be due to the SIM ? I have sim from 1NCE in all my Thingys.
    Adeel.
  • Adeel,
    Are you using PSM/eDRX? If you are not able to provide modem trace, are you able to provide log output?
    Thanks.
    -Øyvind
  • Hi Oyvind,
    Yes, I am using PSM in my application.
    I will keep this ticket on hold and provide you with the log output once I face the same issue again, as I do not have the log output as of now.
    Adeel.
