softdevice: Hard Fault / Advertising flash contents on extended advertising
On the latest master of https://github.com/nrfconnect/sdk-nrf (v1.7.0-rc1), swapping between extended and standard advertising will result in reads/ attempted writes to address 0x00.
Depending on the application configuration, this will result in either a hard fault, or advertising the contents of flash at 0x00 instead of the expected AD structures.
I have attached a modification of the standard scan_adv Zephyr sample which demonstrates this issue consistently on a Particle Argon board within the first few seconds.
With CONFIG_MPU_ALLOW_FLASH_WRITE enabled, the sample will advertise flash contents, if it is disabled it will hard fault inside the softdevice with:
[00:00:02.017,028] <err> os: ***** MPU FAULT *****
[00:00:02.017,059] <err> os:   Data Access Violation
[00:00:02.017,059] <err> os:   MMFAR Address: 0x0
[00:00:02.017,059] <err> os: r0/a1:  0x00000000  r1/a2:  0x20008ec1  r2/a3:  0x0000000d
[00:00:02.017,059] <err> os: r3/a4:  0xffffffff r12/ip:  0x00000002 r14/lr:  0x0001a955
[00:00:02.017,059] <err> os:  xpsr:  0x01000000
[00:00:02.017,059] <err> os: Faulting instruction address (r15/pc): 0x000166f2
[00:00:02.017,089] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0
[00:00:02.017,089] <err> os: Current thread: 0x20001f38 (unknown)
Softdevice version information:
[00:00:00.006,347] <inf> sdc_hci_driver: SoftDevice Controller build revision:
                                         3f 47 70 8e 81 95 4e 86  9d d3 a2 95 88 f6 30 0a |?Gp...N. ......0.
                                         7f 53 49 fd                                      |.SI.
[00:00:00.007,751] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.007,751] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
[00:00:00.007,781] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 63.28743 Build 1318420878
[00:00:00.008,483] <inf> bt_hci_core: Identity: DA:04:3D:69:EA:9B (random)
[00:00:00.008,483] <inf> bt_hci_core: HCI: version 5.2 (0x0b) revision 0x125b, manufacturer 0x0059
[00:00:00.008,483] <inf> bt_hci_core: LMP: version 5.2 (0x0b) subver 0x125b
This issue can be worked around by destroying and recreating the advertising set each time advertising is started, however I cannot validate if this simply makes the error less frequent.
As an example of received packets on a remote device of the sample application, where the 05 FF packets are valid and 28 64 00 20 packets are the flash contents at 0x00 (Stack pointer):
[02:48:22.000,061] <inf> app: 01/01/2020 02:48:59.00002
[02:48:23.000,061] <inf> app: 01/01/2020 02:49:00.00002
[02:48:23.717,254] <wrn> uc_bt_adv: ADV PKT
                                    28 64 00 20 11 ac                                |(d. ..
[02:48:24.000,061] <inf> app: 01/01/2020 02:49:01.00000
[02:48:24.722,106] <wrn> uc_bt_adv: ADV PKT
                                    05 ff ff ff d5 00                                |......
[02:48:25.000,030] <inf> app: 01/01/2020 02:49:02.00000
[02:48:25.720,336] <wrn> uc_bt_adv: ADV PKT
                                    05 ff ff ff d7 00                                |......
[02:48:26.000,030] <inf> app: 01/01/2020 02:49:03.00000
[02:48:26.723,693] <wrn> uc_bt_adv: ADV PKT
scan_adv.zip
