FreeRTOS timers may fire earlier than expected when configUSE_TICKLESS_IDLE == 1
Hi all,
I am using nrf52 with Softdevice 113 v7.0.1 and SDKv16 and FreeRTOS v10.0.1 and I am experiencing some issues with FreeRTOS timers expiring earlier than expected when configUSE_TICKLESS_IDLE == 1.
The problems started occurring when I applied fix in vTaskStepTick() proposed in the FreeRTOS forum: https://forums.freertos.org/t/assert-in-tasks-c-2611-on-xtickcount-wrap-around/9984
There were two solutions proposed, one in the Nordic port and the seconds in generic FreeRTOS code, but both of them cause the same problem.
I also created the corresponding post in the FreeRTOS forum: forums.freertos.org/.../13416
So is there any solution that fixes the original problem with assert on xTickCount wrap around that will not cause timers to expire too early?
  • Hi KarRej,
    I need to be able understand the underlying activity that is making this happen. If the critical section (disabling interrupts) was the problem, then i would have expected that the jitter is in only one direction, but you are seeing difference in both directions of the set delay. I have no theories anymore and need to reproduce this on my end to be able to crack it.
    I cannot reproduce it editing freertos examples on the DK, So it might be that i need your setup to be able to reproduce this. Can you help me get your setup?
    other way is that you try to recreate this on the Nordic DK and share me the project and i will debug to see the underlying activity that makes this happen.
    Sorry for the late reply but I was figuring out how can I share the setup with you, and unfortunately I can't do it.
    So in the meantime, I will try to reproduce it by myself on the freeRTOS examples and when I do it, I will share the code with you.
    I will get back to you when I reproduce this issue on the freeRTOS example.
  • Hi
    I think I have reproduced the issue with slightly modified nrf example.
    As a base I've used ble_app_hrs_freertos example from sdk 16.
    Additional RTOS timer was created with period 20ms. LED 2 pin is set on timer's callback entrance and cleared on exit.
    Modified min.c file of the example:
     * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    // Board/nrf6310/ble/ble_app_hrs_rtx/main.c
     * @brief Heart Rate Service Sample Application with RTX main file.
     * This file contains the source code for a sample application using RTX and the
     * Heart Rate service (and also Battery and Device Information services).
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "bsp.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_bas.h"
    #include "ble_hrs.h"
    #include "ble_dis.h"
    #include "ble_conn_params.h"
    #include "sensorsim.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_freertos.h"
    #include "app_timer.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "bsp_btn_ble.h"
    #include "FreeRTOS.h"
    #include "task.h"
    #include "timers.h"
    #include "semphr.h"
    #include "fds.h"
    #include "ble_conn_state.h"
    #include "nrf_drv_clock.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define DEVICE_NAME                         "Nordic_HRM"                            /**< Name of device. Will be included in the advertising data. */
    #define MANUFACTURER_NAME                   "NordicSemiconductor"                   /**< Manufacturer. Will be passed to Device Information Service. */
    #define APP_BLE_OBSERVER_PRIO               3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG                1                                       /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_ADV_INTERVAL                    300                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
    #define APP_ADV_DURATION                    60000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define BATTERY_LEVEL_MEAS_INTERVAL         200                                    /**< Battery level measurement interval (ms). */
    #define MIN_BATTERY_LEVEL                   81                                      /**< Minimum simulated battery level. */
    #define MAX_BATTERY_LEVEL                   100                                     /**< Maximum simulated battery level. */
    #define BATTERY_LEVEL_INCREMENT             1                                       /**< Increment between each simulated battery level measurement. */
    #define HEART_RATE_MEAS_INTERVAL            100                                    /**< Heart rate measurement interval (ms). */
    #define MIN_HEART_RATE                      140                                     /**< Minimum heart rate as returned by the simulated measurement function. */
    #define MAX_HEART_RATE                      300                                     /**< Maximum heart rate as returned by the simulated measurement function. */
    #define HEART_RATE_INCREMENT                10                                      /**< Value by which the heart rate is incremented/decremented for each call to the simulated measurement function. */
    #define RR_INTERVAL_INTERVAL                300                                     /**< RR interval interval (ms). */
    #define MIN_RR_INTERVAL                     100                                     /**< Minimum RR interval as returned by the simulated measurement function. */
    #define MAX_RR_INTERVAL                     500                                     /**< Maximum RR interval as returned by the simulated measurement function. */
    #define RR_INTERVAL_INCREMENT               1                                       /**< Value by which the RR interval is incremented/decremented for each call to the simulated measurement function. */
    #define SENSOR_CONTACT_DETECTED_INTERVAL    5000                                    /**< Sensor Contact Detected toggle interval (ms). */
    #define MIN_CONN_INTERVAL                   MSEC_TO_UNITS(400, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.4 seconds). */
    #define MAX_CONN_INTERVAL                   MSEC_TO_UNITS(650, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.65 second). */
    #define SLAVE_LATENCY                       0                                       /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                    MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY      5000                                    /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY       30000                                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT        3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define SEC_PARAM_BOND                      1                                       /**< Perform bonding. */
    #define SEC_PARAM_MITM                      0                                       /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC                      0                                       /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS                  0                                       /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
    #define SEC_PARAM_OOB                       0                                       /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE              7                                       /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE              16                                      /**< Maximum encryption key size. */
    #define DEAD_BEEF                           0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define OSTIMER_WAIT_FOR_QUEUE              2                                       /**< Number of ticks to wait for the timer queue to be ready */
    TaskHandle_t  led_toggle_task_handle;   /**< Reference to LED0 toggling FreeRTOS task. */
    TimerHandle_t led_toggle_timer_handle;  /**< Reference to LED1 toggling FreeRTOS timer. */
    #define TASK_DELAY        10           /**< Task delay. Delays a LED0 task for 200 ms */
    #define TIMER_PERIOD      20          /**< Timer period. LED1 timer will expire after 1000 ms */
    BLE_BAS_DEF(m_bas);                                                 /**< Battery service instance. */
    BLE_HRS_DEF(m_hrs);                                                 /**< Heart rate service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                 /**< Advertising module instance. */
    static uint16_t m_conn_handle         = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
    static bool     m_rr_interval_enabled = true;                       /**< Flag for enabling and disabling the registration of new RR interval measurements (the purpose of disabling this is just to test sending HRM without RR interval data. */
    static sensorsim_cfg_t   m_battery_sim_cfg;                         /**< Battery Level sensor simulator configuration. */
    static sensorsim_state_t m_battery_sim_state;                       /**< Battery Level sensor simulator state. */
    static sensorsim_cfg_t   m_heart_rate_sim_cfg;                      /**< Heart Rate sensor simulator configuration. */
    static sensorsim_state_t m_heart_rate_sim_state;                    /**< Heart Rate sensor simulator state. */
    static sensorsim_cfg_t   m_rr_interval_sim_cfg;                     /**< RR Interval sensor simulator configuration. */
    static sensorsim_state_t m_rr_interval_sim_state;                   /**< RR Interval sensor simulator state. */
    static ble_uuid_t m_adv_uuids[] =                                   /**< Universally unique service identifiers. */
        {BLE_UUID_HEART_RATE_SERVICE, BLE_UUID_TYPE_BLE},
        {BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
        {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
    static TimerHandle_t m_battery_timer;                               /**< Definition of battery timer. */
    static TimerHandle_t m_heart_rate_timer;                            /**< Definition of heart rate timer. */
    static TimerHandle_t m_rr_interval_timer;                           /**< Definition of RR interval timer. */
    static TimerHandle_t m_sensor_contact_timer;                        /**< Definition of sensor contact detected timer. */
    // #if NRF_LOG_ENABLED
    // static TaskHandle_t m_logger_thread;                                /**< Definition of Logger thread. */
    // #endif
    static TaskHandle_t m_blinker_thread;                                /**< Definition of Logger thread. */
    static void led_toggle_timer_callback (void * pvParameter)
        bsp_board_led_off(BSP_BOARD_LED_1);
        UNUSED_PARAMETER(pvParameter);
        UNUSED_VARIABLE(xTimerStart(led_toggle_timer_handle, 0));
        bsp_board_led_on(BSP_BOARD_LED_1);
        // bsp_board_led_invert(BSP_BOARD_LED_1);
    static void advertising_start(void * p_erase_bonds);
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in]   line_num   Line number of the failing ASSERT call.
     * @param[in]   file_name  File name of the failing ASSERT call.
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        bool delete_bonds = false;
        pm_handler_on_pm_evt(p_evt);
        pm_handler_flash_clean(p_evt);
        switch (p_evt->evt_id)
                advertising_start(&delete_bonds);
    /**@brief Function for performing battery measurement and updating the Battery Level characteristic
     *        in Battery Service.
    static void battery_level_update(void)
        ret_code_t err_code;
        uint8_t  battery_level;
        battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
        err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
        if ((err_code != NRF_SUCCESS) &&
            (err_code != NRF_ERROR_INVALID_STATE) &&
            (err_code != NRF_ERROR_BUSY) &&
            (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
            APP_ERROR_HANDLER(err_code);
    /**@brief Function for handling the Battery measurement timer time-out.
     * @details This function will be called each time the battery level measurement timer expires.
     * @param[in] xTimer Handler to the timer that called this function.
     *                   You may get identifier given to the function xTimerCreate using pvTimerGetTimerID.
    static void battery_level_meas_timeout_handler(TimerHandle_t xTimer)
        UNUSED_PARAMETER(xTimer);
        battery_level_update();
    /**@brief Function for handling the Heart rate measurement timer time-out.
     * @details This function will be called each time the heart rate measurement timer expires.
     *          It will exclude RR Interval data from every third measurement.
    static void heart_rate_meas_timeout_handler(TimerHandle_t xTimer)
        static uint32_t cnt = 0;
        uint16_t        heart_rate;
        heart_rate = (uint16_t)sensorsim_measure(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
        cnt++;
        err_code = ble_hrs_heart_rate_measurement_send(&m_hrs, heart_rate);
        // Disable RR Interval recording every third heart rate measurement.
        // NOTE: An application will normally not do this. It is done here just for testing generation
        // of messages without RR Interval measurements.
        m_rr_interval_enabled = ((cnt % 3) != 0);
    /**@brief Function for handling the RR interval timer time-out.
     * @details This function will be called each time the RR interval timer expires.
    static void rr_interval_timeout_handler(TimerHandle_t xTimer)
        if (m_rr_interval_enabled)
            uint16_t rr_interval;
            rr_interval = (uint16_t)sensorsim_measure(&m_rr_interval_sim_state,
                                                      &m_rr_interval_sim_cfg);
            ble_hrs_rr_interval_add(&m_hrs, rr_interval);
    /**@brief Function for handling the Sensor Contact Detected timer time-out.
     * @details This function will be called each time the Sensor Contact Detected timer expires.
    static void sensor_contact_detected_timeout_handler(TimerHandle_t xTimer)
        static bool sensor_contact_detected = false;
        sensor_contact_detected = !sensor_contact_detected;
        ble_hrs_sensor_contact_detected_update(&m_hrs, sensor_contact_detected);
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module. This creates and starts application timers.
    static void timers_init(void)
        // Initialize timer module.
        // Create timers.
        m_battery_timer = xTimerCreate("BATT",
                                       BATTERY_LEVEL_MEAS_INTERVAL,
                                       pdTRUE,
                                       NULL,
                                       battery_level_meas_timeout_handler);
        m_heart_rate_timer = xTimerCreate("HRT",
                                          HEART_RATE_MEAS_INTERVAL,
                                          pdTRUE,
                                          NULL,
                                          heart_rate_meas_timeout_handler);
        m_rr_interval_timer = xTimerCreate("RRT",
                                           RR_INTERVAL_INTERVAL,
                                           pdTRUE,
                                           NULL,
                                           rr_interval_timeout_handler);
        m_sensor_contact_timer = xTimerCreate("SCT",
                                              SENSOR_CONTACT_DETECTED_INTERVAL,
                                              pdTRUE,
                                              NULL,
                                              sensor_contact_detected_timeout_handler);
        /* Error checking */
        if ( (NULL == m_battery_timer)
             || (NULL == m_heart_rate_timer)
             || (NULL == m_rr_interval_timer)
             || (NULL == m_sensor_contact_timer) )
            APP_ERROR_HANDLER(NRF_ERROR_NO_MEM);
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
        err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HEART_RATE_SENSOR_HEART_RATE_BELT);
    /**@brief Function for initializing the GATT module. */
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
        APP_ERROR_HANDLER(nrf_error);
     * @details Initialize the Heart Rate, Battery and Device Information services.
        ble_hrs_init_t     hrs_init;
        ble_bas_init_t     bas_init;
        ble_dis_init_t     dis_init;
        uint8_t            body_sensor_location;
        // Initialize Heart Rate Service.
        body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_FINGER;
        memset(&hrs_init, 0, sizeof(hrs_init));
        hrs_init.evt_handler                 = NULL;
        hrs_init.is_sensor_contact_supported = true;
        hrs_init.p_body_sensor_location      = &body_sensor_location;
        // Here the sec level for the Heart Rate Service can be changed/increased.
        hrs_init.hrm_cccd_wr_sec = SEC_OPEN;
        hrs_init.bsl_rd_sec      = SEC_OPEN;
        err_code = ble_hrs_init(&m_hrs, &hrs_init);
        // Initialize Battery Service.
        memset(&bas_init, 0, sizeof(bas_init));
        // Here the sec level for the Battery Service can be changed/increased.
        bas_init.bl_rd_sec        = SEC_OPEN;
        bas_init.bl_cccd_wr_sec   = SEC_OPEN;
        bas_init.bl_report_rd_sec = SEC_OPEN;
        bas_init.evt_handler          = NULL;
        bas_init.support_notification = true;
        bas_init.p_report_ref         = NULL;
        bas_init.initial_batt_level   = 100;
        err_code = ble_bas_init(&m_bas, &bas_init);
        // Initialize Device Information Service.
        memset(&dis_init, 0, sizeof(dis_init));
        ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
        dis_init.dis_char_rd_sec = SEC_OPEN;
        err_code = ble_dis_init(&dis_init);
    /**@brief Function for initializing the sensor simulators. */
    static void sensor_simulator_init(void)
        m_battery_sim_cfg.min          = MIN_BATTERY_LEVEL;
        m_battery_sim_cfg.max          = MAX_BATTERY_LEVEL;
        m_battery_sim_cfg.incr         = BATTERY_LEVEL_INCREMENT;
        m_battery_sim_cfg.start_at_max = true;
        sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
        m_heart_rate_sim_cfg.min          = MIN_HEART_RATE;
        m_heart_rate_sim_cfg.max          = MAX_HEART_RATE;
        m_heart_rate_sim_cfg.incr         = HEART_RATE_INCREMENT;
        m_heart_rate_sim_cfg.start_at_max = false;
        sensorsim_init(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
        m_rr_interval_sim_cfg.min          = MIN_RR_INTERVAL;
        m_rr_interval_sim_cfg.max          = MAX_RR_INTERVAL;
        m_rr_interval_sim_cfg.incr         = RR_INTERVAL_INCREMENT;
        m_rr_interval_sim_cfg.start_at_max = false;
        sensorsim_init(&m_rr_interval_sim_state, &m_rr_interval_sim_cfg);
    /**@brief   Function for starting application timers.
     * @details Timers are run after the scheduler has started.
    static void application_timers_start(void)
        // Start application timers.
        if (pdPASS != xTimerStart(m_battery_timer, OSTIMER_WAIT_FOR_QUEUE))
        if (pdPASS != xTimerStart(m_heart_rate_timer, OSTIMER_WAIT_FOR_QUEUE))
        if (pdPASS != xTimerStart(m_rr_interval_timer, OSTIMER_WAIT_FOR_QUEUE))
        if (pdPASS != xTimerStart(m_sensor_contact_timer, OSTIMER_WAIT_FOR_QUEUE))
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module which
     *          are passed to the application.
     *          @note All this function does is to disconnect. This could have been done by simply
     *                setting the disconnect_on_fail config parameter, but instead we use the event
     *                handler mechanism to demonstrate its use.
     * @param[in]   p_evt   Event received from the Connection Parameters Module.
    /**@brief Function for handling a Connection Parameters error.
    /**@brief Function for initializing the Connection Parameters module. */
        cp_init.start_on_notify_cccd_handle    = m_hrs.hrm_handles.cccd_handle;
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("Fast advertising.");
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
        uint32_t ram_start = 0;
        // Enable BLE stack.
     * @param[in]   event   Event generated by button press.
    static void bsp_event_handler(bsp_event_t event)
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
            case BSP_EVENT_WHITELIST_OFF:
    /**@brief Function for the Peer Manager initialization. */
    static void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
    /**@brief Clear bond information from persistent storage. */
    static void delete_bonds(void)
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
    /**@brief Function for initializing the Advertising functionality. */
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = true;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    static void log_init(void)
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    /**@brief Function for starting advertising. */
        bool erase_bonds = *(bool*)p_erase_bonds;
        if (erase_bonds)
            delete_bonds();
            // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
            ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    /**@brief A function which is hooked to idle task.
     * @note Idle hook must be enabled in FreeRTOS configuration (configUSE_IDLE_HOOK).
    void vApplicationIdleHook( void )
    //      vTaskResume(m_logger_thread);
    // #endif
    void vApplicationTickHook( void )
        bsp_board_led_invert(BSP_BOARD_LED_0);
    /**@brief Function for initializing the clock.
    static void clock_init(void)
        ret_code_t err_code = nrf_drv_clock_init();
    static void blinker_thread (void * pvParameter)
        while (true)
            bsp_board_led_invert(BSP_BOARD_LED_3);
            /* Delay a task for a given number of ticks */
            vTaskDelay(TASK_DELAY);
            /* Tasks must be implemented to never return... */
    /**@brief Function for application main entry.
        bool erase_bonds;
        // Initialize modules.
        log_init();
        clock_init();
        // Do not start any interrupt that uses system functions before system initialisation.
        // The best solution is to start the OS before any other initalisation.
        // Activate deep sleep mode.
        SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
        // Configure and initialize the BLE stack.
        ble_stack_init();
        timers_init();
        gap_params_init();
        gatt_init();
        advertising_init();
        services_init();
        sensor_simulator_init();
        conn_params_init();
        peer_manager_init();
        application_timers_start();
        // Create a FreeRTOS task for the BLE stack.
        // The task will run advertising_start() before entering its loop.
        nrf_sdh_freertos_init(advertising_start, &erase_bonds);
        NRF_LOG_INFO("HRS FreeRTOS example started.");
        /* Create task for LED0 blinking with priority set to 2 */
        UNUSED_VARIABLE(xTaskCreate(blinker_thread, "blinker", 256, NULL, 1, &m_blinker_thread));
        /* Start timer for LED1 blinking */
        led_toggle_timer_handle = xTimerCreate( "LED1", TIMER_PERIOD, pdFALSE, NULL, led_toggle_timer_callback);
        // Start FreeRTOS scheduler.
        vTaskStartScheduler();
        for (;;)
            APP_ERROR_HANDLER(NRF_ERROR_FORBIDDEN);
    I've connected to the example device using NRFconnect and I've turned on heart rate and battery service notifications.
    Then I've observed LED2 pin for around 10 minutes with:
    1. Original fix in vPortSuppressTicksAndSleep()
    2. Original fix in tasks.c
    3. FIx proposed by Susheel Nuguru in one of the previous posts
    4. configUSE_TICKLESS_IDLE = 0
    5  configUSE_TICKLESS_IDLE = 1 no fix applied
    When any of fixes present (1,2,3) I got period in range 18 - 21ms
    When tickless idle disabled or without any fix (4,5) I got period in range 19,5 - 20,5ms
