nRF5340-DK Low Power Configuration Issues
I am performing some evaluation on the low power capabilities of the nRF5340 using the DK and the PPK v1.
I have written a really basic BLE Peripheral Application based loosely around the peripheral_lbs sample code as I want to test with a button handler eventually.
The problem I have is that after considerable configuration, I can only get the current floor down to ~200uA with an average current of ~215uA with a 1.2 second advertising interval. I've seen a lot of people on here talk about seeing much, much lower currents so wondered is there a configuration that I am missing perhaps?
I have been reading the documents and a few threads on here to understand how to configure the device and I have done the following.
  1. My main application, running on the NS partition, has been configured as follows:
    CONFIG_NCS_SAMPLES_DEFAULTS=y
    CONFIG_BT=y
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_DEVICE_NAME="MH_TEST"
    # Enable the LBS service
    CONFIG_BT_LBS=y
    CONFIG_BT_LBS_POLL_BUTTON=y
    CONFIG_DK_LIBRARY=y
    # Drivers and peripherals
    CONFIG_I2C=n
    CONFIG_WATCHDOG=n
    CONFIG_GPIO=n
    CONFIG_PINMUX=n
    CONFIG_SPI=n
    CONFIG_SERIAL=n
    # Power management
    CONFIG_DEVICE_POWER_MANAGEMENT=y
    CONFIG_PM=y
    # Interrupts
    CONFIG_DYNAMIC_INTERRUPTS=n
    CONFIG_IRQ_OFFLOAD=n
    # Memory protection
    CONFIG_THREAD_STACK_INFO=n
    CONFIG_THREAD_CUSTOM_DATA=n
    CONFIG_FPU=n
    # Boot
    CONFIG_BOOT_BANNER=n
    CONFIG_BOOT_DELAY=0
    # Console
    CONFIG_CONSOLE=n
    CONFIG_UART_CONSOLE=n
    CONFIG_STDOUT_CONSOLE=n
    CONFIG_PRINTK=n
    CONFIG_EARLY_CONSOLE=n
    # Build
    CONFIG_SIZE_OPTIMIZATIONS=y
  2. I have added an spm.conf
    CONFIG_IS_SPM=y
    CONFIG_FW_INFO=y
    CONFIG_GPIO=y
    CONFIG_SERIAL=n
    and added that to the CMakeLists.txt
    set(spm_CONF_FILE ${CMAKE_CURRENT_SOURCE_DIR}/spm.conf)
  3. I have also configured the hci_rpmsg via the menuconfig to turn off logging
  4. I also tried turning on Power Management via the SPM and HCI_RPMSG's menuconfig's as well but it did not seem to have any effect.
As for my source code, I have attached it. I simply setup the BLE and handlers and then call:
for (;;) {
    k_cpu_idle();
If we look at the PPK, I see this:
where my baseline current seems to be around 200uA - from what I had read around, I would have expected to be able to get it lower than this, so I imagine I must be configuring something incorrectly.
If you had any advice, it would be appreciated!
nRF Connect SDK: v1.6.1
 * Copyright (c) 2018 Nordic Semiconductor ASA
#include <zephyr/types.h>
#include <stddef.h>
#include <string.h>
#include <errno.h>
#include <sys/printk.h>
#include <sys/byteorder.h>
#include <zephyr.h>
#include <drivers/gpio.h>
#include <soc.h>
#include <bluetooth/bluetooth.h>
#include <bluetooth/hci.h>
#include <bluetooth/conn.h>
#include <bluetooth/uuid.h>
#include <bluetooth/gatt.h>
#include <bluetooth/services/lbs.h>
#include <settings/settings.h>
#include <dk_buttons_and_leds.h>
#include <device.h>
#include "power/power.h"
#define DEVICE_NAME             CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN         (sizeof(DEVICE_NAME) - 1)
#define RUN_STATUS_LED          DK_LED1
#define CON_STATUS_LED          DK_LED2
#define RUN_LED_BLINK_INTERVAL  1000
#define USER_LED                DK_LED3
#define USER_BUTTON             DK_BTN1_MSK
#define BT_LE_ADV_CONN_TEST BT_LE_ADV_PARAM(BT_LE_ADV_OPT_CONNECTABLE, \
				            BT_GAP_ADV_SLOW_INT_MAX, \
				            BT_GAP_ADV_SLOW_INT_MAX, NULL)
const struct device *console, *uart1;
static bool app_button_state;
static const struct bt_data ad[] = {
	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static const struct bt_data sd[] = {
	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_LBS_VAL),
static void connected(struct bt_conn *conn, uint8_t err)
	if (err) {
		printk("Connection failed (err %u)\n", err);
		return;
	printk("Connected\n");
	dk_set_led_on(CON_STATUS_LED);
	printk("Disconnected (reason %u)\n", reason);
	dk_set_led_off(CON_STATUS_LED);
#ifdef CONFIG_BT_LBS_SECURITY_ENABLED
static void security_changed(struct bt_conn *conn, bt_security_t level,
			     enum bt_security_err err)
	if (!err) {
		printk("Security changed: %s level %u\n", addr, level);
	} else {
		printk("Security failed: %s level %u err %d\n", addr, level,
			err);
static struct bt_conn_cb conn_callbacks = {
	.connected        = connected,
	.disconnected     = disconnected,
	.security_changed = security_changed,
#if defined(CONFIG_BT_LBS_SECURITY_ENABLED)
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
	printk("Passkey for %s: %06u\n", addr, passkey);
static void auth_cancel(struct bt_conn *conn)
	printk("Pairing cancelled: %s\n", addr);
static void pairing_confirm(struct bt_conn *conn)
	bt_conn_auth_pairing_confirm(conn);
	printk("Pairing confirmed: %s\n", addr);
static void pairing_complete(struct bt_conn *conn, bool bonded)
	printk("Pairing completed: %s, bonded: %d\n", addr, bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
	printk("Pairing failed conn: %s, reason %d\n", addr, reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
	.passkey_display = auth_passkey_display,
	.cancel = auth_cancel,
	.pairing_confirm = pairing_confirm,
	.pairing_complete = pairing_complete,
	.pairing_failed = pairing_failed
#else
static struct bt_conn_auth_cb conn_auth_callbacks;
static void app_led_cb(bool led_state)
	dk_set_led(USER_LED, led_state);
static bool app_button_cb(void)
	return app_button_state;
static struct bt_lbs_cb lbs_callbacs = {
	.led_cb    = app_led_cb,
	.button_cb = app_button_cb,
static void button_changed(uint32_t button_state, uint32_t has_changed)
	if (has_changed & USER_BUTTON) {
		bt_lbs_send_button_state(button_state);
		app_button_state = button_state ? true : false;
static int init_button(void)
	int err;
	err = dk_buttons_init(button_changed);
	if (err) {
		printk("Cannot init buttons (err: %d)\n", err);
	return err;
void main(void)
        int blink_status = 0;
	int err;
	printk("Starting Bluetooth Peripheral LBS example\n");
	err = dk_leds_init();
	if (err) {
		printk("LEDs init failed (err %d)\n", err);
		return;
	err = init_button();
	if (err) {
	    printk("Button init failed (err %d)\n", err);
	    return;
	bt_conn_cb_register(&conn_callbacks);
	if (IS_ENABLED(CONFIG_BT_LBS_SECURITY_ENABLED)) {
	    bt_conn_auth_cb_register(&conn_auth_callbacks);
	err = bt_enable(NULL);
	if (err) {
		printk("Bluetooth init failed (err %d)\n", err);
		return;
	printk("Bluetooth initialized\n");
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		settings_load();
	err = bt_lbs_init(&lbs_callbacs);
	if (err) {
		printk("Failed to init LBS (err:%d)\n", err);
		return;
	err = bt_le_adv_start(BT_LE_ADV_CONN_TEST, ad, ARRAY_SIZE(ad),
			      sd, ARRAY_SIZE(sd));
	if (err) {
		printk("Advertising failed to start (err %d)\n", err);
		return;
	printk("Advertising successfully started\n");
	for (;;) {
		//dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
                //dk_set_led(RUN_STATUS_LED, 0);
		//k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
                k_cpu_idle();
  • Thanks for discussing internally, I will try the hooks tomorrow and let you know.
  • Hi - I got this working.
    It was a problem with segger embedded studio, there might be a potential bug with it.
    It was not finding my .dtoverlay file - it had duplicated the path string behind the file so it could not find it.
    When I stopped using the IDE and went to West on the terminal, it found the dtoverlay fine:
    -- Found devicetree overlay: /Users/mhazley/src/nrf-low-power-investigation/application/boards/nrf5340dk_nrf5340_cpuappns.overlay
    The build from west gave me an average current of 8uA
