Why would I get two different current readings from two different PCs using the same PPKII, circuit, and supply voltage?
I was measuring the current of a circuit I made using a PPK II and noticed I am getting two different readings from the two PCs I used (a work and a home PC).
Both PCs have the same settings in the nRF Connect software and I am using the exact same circuit and LiPo battery to power it but my average current draw using the work PC is ~1.20mA and my home PC reads ~0.95mA.
My home PC is much faster than my work one, would that cause a disparity in the readings?
Thanks.
  • I believe the multimeter I have only goes up to a few μA and isn't very accurate, so of no use for this application. That was the reason I purchased/used the PPKII... to measure current readings in a wider range more accurately.
    I looked more into the graphs that nRF Connect Power Profiler output and I did notice that the work PC's period was 11.67s consistently and the home PC's period was 18.56s consistently. That ~7s increase would explain why the average power draw is brought down (the graph spikes, decreases, and levels off) but if the test circuit, usb cable, power supply, and settings are all the same, what would be changing the time period between the two PCs?
    This is an indication that the PC that is "off" is missing several samples from the usb bus. Which one is sampling incorrect? We have seen in the past that the one that samples slower is the one missing packets:
    https://github.com/NordicSemiconductor/pc-nrfconnect-ppk/issues/141
    The above issue is highly likely linked to recent AMD usb connectivity issues.
    Try different ports (2.0 and 3.0), and see if your BIOS/chipset drivers are up to date.
    Håkon
