smp_srv example works but my project gives: E: Image in the secondary slot is not valid!
I'm writing an application for the nrf5340 with nrfConnect v1.6.1,
I've been able to do the FOTA upgrade through BLE with the example smp_srv located inside zephyr/samples/subsys/mgmt/mcumgr/smp_svr
These were the step I've followed:
  1. Copy the smp_srv folder to my workspace folder (~/Documents/zephyr_projects/smp_srv)
  2. west build -b nrf5340dk_nrf5340_cpuappns -p -- -DOVERLAY_CONFIG=overlay-bt.conf (build pristine for non-secure app)
  3. west flash (as far as I know, the mcuboot is compiled as a child image, using the default debug key)
  4. Change code (adding some logs to see the changes)
  5. execute again  west build -b nrf5340dk_nrf5340_cpuappns -- -DOVERLAY_CONFIG=overlay-bt.conf to generate a new app_update.bin file with the modifications
  6. Upload the app_update.bin to my android
  7. Open nrfConnect application on my android
  8. connect to the board
  9. start DFU selecting the new app_update.bin file
  10. Transfer completes, Validate
  11. I can verify the new logs are applied
Everything works fine in this sample project
Important to notice that I've tested the smp_srv project with the following configuration:
# Enable mcumgr.
CONFIG_MCUMGR=y
# Some command handlers require a large stack.
# Ensure an MCUboot-compatible binary is generated.
CONFIG_BOOTLOADER_MCUBOOT=y
# Enable flash operations.
CONFIG_FLASH=y
# Required by the `taskstat` command.
CONFIG_THREAD_MONITOR=y
# Enable statistics and statistic names.
CONFIG_STATS=y
CONFIG_STATS_NAMES=y
# Enable most core commands.
CONFIG_MCUMGR_CMD_IMG_MGMT=y
CONFIG_MCUMGR_CMD_OS_MGMT=y
# CONFIG_MCUMGR_CMD_STAT_MGMT=y
# Enable logging
CONFIG_LOG=y
CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN=y
and the overlay-bt,conf I've stripped everyhing related to LITTLE_FS
# Allow for large Bluetooth data packets.
CONFIG_BT_L2CAP_TX_MTU=252
CONFIG_BT_BUF_ACL_RX_SIZE=256
# Enable the Bluetooth (unauthenticated) and shell mcumgr transports.
CONFIG_MCUMGR_SMP_BT=y
CONFIG_MCUMGR_SMP_BT_AUTHEN=n
CONFIG_MCUMGR_SMP_SHELL=y
# Enable the LittleFS file system.
# CONFIG_FILE_SYSTEM=y
# CONFIG_FILE_SYSTEM_LITTLEFS=y
# Add 256 bytes to accommodate upload command (lfs_stat overflows)
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2304
# Enable file system commands
CONFIG_MCUMGR_CMD_FS_MGMT=y
Then in my project, which I've added the same configuration located on the smp_srv prj.conf and overlay-bt.conf
# Incresed stack due to settings API usage
# CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048
CONFIG_BT=y
CONFIG_BT_DEBUG_LOG=y
CONFIG_BT_SMP=y
CONFIG_BT_SIGNING=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DIS=y
CONFIG_BT_ATT_PREPARE_COUNT=5
CONFIG_BT_BAS=y
CONFIG_BT_PRIVACY=y
CONFIG_BT_DEVICE_NAME="MyProject"
CONFIG_BT_DEVICE_APPEARANCE=833
CONFIG_BT_DEVICE_NAME_DYNAMIC=n
# CONFIG_BT_DEVICE_NAME_MAX=65
CONFIG_BT_USER_DATA_LEN_UPDATE=y
CONFIG_BT_BONDABLE=y
CONFIG_BT_KEYS_OVERWRITE_OLDEST=y
CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE=y
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
# CONFIG_FLASH_PAGE_LAYOUT=y
# CONFIG_FLASH_MAP=y
# CONFIG_NVS=y
# CONFIG_SETTINGS=y
CONFIG_SPI=y
CONFIG_SENSOR=y
CONFIG_LIS3DH=y
CONFIG_LIS3DH_ACCEL_RANGE_2G=y
CONFIG_LIS3DH_ODR_5=y
CONFIG_LIS3DH_TRIGGER_OWN_THREAD=y
CONFIG_CBPRINTF_FP_SUPPORT=y
CONFIG_LIS3DH_CLICK_THS=64
CONFIG_LIS3DH_TIME_LIMIT=50
CONFIG_LIS3DH_TIME_LATENCY=2
CONFIG_LIS3DH_TIME_WINDOW=100
CONFIG_PM=y
CONFIG_MAX30005=y
CONFIG_MAX30005_TRIGGER_OWN_THREAD=y
CONFIG_I2C=y
CONFIG_ADP5360=y
CONFIG_ADP5360_TRIGGER_OWN_THREAD=y
# Required to disable default behavior of deep sleep on timeout
CONFIG_PM_DEVICE=y
CONFIG_BT_L2CAP_TX_MTU=508
CONFIG_BT_BUF_ACL_RX_SIZE=512
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2560
# CONFIG_MCUMGR_CMD_FS_MGMT=y
# Enable mcumgr.
CONFIG_MCUMGR=y
# CONFIG_FLASH=y
# CONFIG_STATS=y
# CONFIG_STATS_NAMES=y
# Enable logging
CONFIG_LOG=y
# CONFIG_MCUBOOT_SIGNATURE_KEY_FILE="root-rsa-2048.pem"
I've also added the necesary code to be able to initialize the smp service:
Includes:
#ifdef CONFIG_MCUMGR_SMP_BT
#include <mgmt/mcumgr/smp_bt.h>
#ifdef CONFIG_MCUMGR_CMD_OS_MGMT
#include "os_mgmt/os_mgmt.h"
#ifdef CONFIG_MCUMGR_CMD_IMG_MGMT
#include "img_mgmt/img_mgmt.h"
#ifdef CONFIG_MCUMGR_CMD_STAT_MGMT
#include "stat_mgmt/stat_mgmt.h"
#ifdef CONFIG_MCUMGR_CMD_SHELL_MGMT
#include "shell_mgmt/shell_mgmt.h"
in the main function:
os_mgmt_register_group();
img_mgmt_register_group();
stat_mgmt_register_group();
shell_mgmt_register_group();
and after enabling ble and registering the callbacks:
smp_bt_register();
Then I execute the following steps:
  1. west build -b nrf5340dk_nrf5340_cpuappns -p (build pristine for non-secure app)
  2. west flash (as far as I know, the mcuboot is compiled as a child image, using the default debug key)
  3. Change code (adding some logs to see the changes)
  4. execute again  west build -b nrf5340dk_nrf5340_cpuappns to generate a new app_update.bin file with the modifications
  5. Upload the app_update.bin to my android
  6. Open nrfConnect application on my android
  7. connect to the board
  8. start DFU selecting the new app_update.bin file
  9. Transfer completes.
Then I can see the logs where the mcuboot says that:
*** Booting Zephyr OS build v2.6.0-rc1-ncs1 ***
I: Starting bootloader
I: Primary image: magic=bad, swap_type=0x1, copy_done=0x2, image_ok=0x2
I: Secondary image: magic=good, swap_type=0x2, copy_done=0x3, image_ok=0x3
I: Boot source: none
I: Swap type: test
I: Bootloader chainload address offset: 0xc000
and then it loads the old image
What can be wrong?
I've tried enabling and disabling configurations but nothing seems to work
  • Hi
    I am sorry for my late answer.
    Our expert at this topic have not been available for a few days.
    I expect him to return by the end of this week.
    Sigurd Hellesvik
  • Hi
    When I run the smp_srv sample with only one change it works:
    I created a folder smp_srv/child_image and a file smp_srv/child_image/mcuboot.conf
    CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=n
    CONFIG_BOOT_SIGNATURE_TYPE_RSA=y
    CONFIG_BOOT_SIGNATURE_KEY_FILE="/c/<full_path_to>/priv.pem"
    I build with only prj.conf and overlay-bt.conf.
    Can you try to run the sample with only these?
    If the sample works with custom certificates, then start adding the configurations you need to prj.conf one by one, until you find the config that crash the program.
    Sigurd Hellesvik
  • Actually what you just suggest solved another issue we were having when we waren't able to compile with the mcuboot.conf using the mcuboot_OVERLAY_CONFIG in the CMakeList.txt.
    list(APPEND mcuboot_OVERLAY_CONFIG
    "${CMAKE_CURRENT_SOURCE_DIR}/mcuboot.conf"
    we got an undefined reference when compiling mcuboot
    FAILED: zephyr/zephyr_prebuilt.elf zephyr/zephyr_prebuilt.map /home/nico/Documents/nico/otc/zephyr_projects/21191_elausa_alz/build_cpuapp/mcuboot/zephyr/zephyr_prebuilt.map
    : && ccache /home/nico/ncs/v1.6.1/toolchain/bin/arm-none-eabi-gcc   zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj -o zephyr/zephyr_prebuilt.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -Wl,-T  zephyr/linker_zephyr_prebuilt.cmd  -Wl,-Map=/home/nico/Documents/nico/otc/zephyr_projects/21191_elausa_alz/build_cpuapp/mcuboot/zephyr/zephyr_prebuilt.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a  zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/lib/posix/liblib__posix.a  zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/serial/libdrivers__serial.a  modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a  modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a  modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a  modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/mbedtls/libmodules__mbedtls.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L"/home/nico/ncs/v1.6.1/toolchain/bin/../lib/gcc/arm-none-eabi/9.2.1/thumb/v8-m.main/nofp"  -L/home/nico/Documents/nico/otc/zephyr_projects/21191_elausa_alz/build_cpuapp/mcuboot/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  /home/nico/ncs/v1.6.1/nrfxlib/crypto/nrf_cc312_platform/lib/cortex-m33/soft-float/no-interrupts/libnrf_cc312_platform_0.9.10.a  -mcpu=cortex-m33  -mthumb  -mabi=aapcs  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -no-pie  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn && cd /home/nico/Documents/nico/otc/zephyr_projects/21191_elausa_alz/build_cpuapp/mcuboot/zephyr && /usr/bin/cmake -E echo
    /home/nico/ncs/v1.6.1/toolchain/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: app/libapp.a(main.c.obj): in function `main':
    /home/nico/ncs/v1.6.1/bootloader/mcuboot/boot/zephyr/main.c:583: undefined reference to `pcd_lock_ram'
    /home/nico/ncs/v1.6.1/toolchain/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: app/libapp.a(loader.c.obj): in function `boot_validated_swap_type':
    /home/nico/ncs/v1.6.1/bootloader/mcuboot/boot/bootutil/src/loader.c:828: undefined reference to `pcd_network_core_update'
    collect2: error: ld returned 1 exit status
    [335/343] Completed 'hci_rpmsg_subimage'
    FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf /home/nico/Documents/nico/otc/zephyr_projects/21191_elausa_alz/build_cpuapp/modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build /home/nico/Documents/nico/otc/zephyr_projects/21191_elausa_alz/build_cpuapp/mcuboot/zephyr/zephyr.hex /home/nico/Documents/nico/otc/zephyr_projects/21191_elausa_alz/build_cpuapp/mcuboot/zephyr/zephyr.elf
    As soon as I commented the code in CMakeList.txt and move the mcuboot.conf to the child_image it solve the compilation issue.
    However, regarding the issue we believe we found the configuration that caused the issue:
    CONFIG_BT_L2CAP_TX_MTU=512
    When we change this to the original values:
    We were able to do the upgrade successfully (using the sample project), we're going to try in the whole project to see if that solve the issue.
    We would like to have have the MTU as big as we can, with 252 could work for now, but if this is the solution, can you eplain how to use the MTU in 512 bytes? is it possible?
  • Hi
    Try to increase the size of CONFIG_MCUMGR_BUF_SIZE.
    Sigurd Hellesvik
  • Should I put that in the child_image/mcuboot.conf or in my prj.conf?
    the config says:
    MCUMGR_BUF_SIZE >= transport-specific-MTU + transport-overhead
    how much is the transport-overhead for BLE?
