Setting value of GPIO Output
Hello all,
I am trying to do a simple task, yet I cannot manage to make it work. My goal is to use the GPIO 1.01 (defined as Digital I/O in the Data Sheet) as an output pin, set its logical value to High/Low and observe all changes in a Logic Analyzer.
The problem is that the pin stays always at High, no matter how many times I try to set it to Low.
Here is my implementation:
prj.conf
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="Nordic_LBS"
# Enable the LBS service
CONFIG_BT_LBS=y
CONFIG_BT_LBS_POLL_BUTTON=y
CONFIG_DK_LIBRARY=y
CONFIG_SPI=y
CONFIG_GPIO=y
CMakeLists.txt
cmake_minimum_required(VERSION 3.13.1)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(NONE)
target_sources(app PRIVATE
  src/main.c
zephyr_library_include_directories(.)
Code snippet in main.c where I configure the pin and try to modify its value.
  //Get GPIO_1 device
  struct device * trfEN;
  trfEN = device_get_binding("GPIO_1");
  if(trfEN == NULL) {
    printk("Could not get trfEN device\n");
  } else {
    printk("Found device trfEN\n");
  //Configure pin as output
  gpio_pin_configure(trfEN, 1, GPIO_OUTPUT_LOW);
  //Enable TRF by setting GPIO to HIGH
  int ret = gpio_pin_set(trfEN, 1, 1);  //Set pin 1.01 to 1
  if(ret != 0) {
    printk("Error setting pin to high\n");
  } else {
    printk("Pin set to high successfully\n");   //This line is printed -> No error setting pin
  //Try to set pin to low
  k_sleep(K_MSEC(1000));
  ret = gpio_pin_set(trfEN, 1, 0);      //Set pin 1.01 to 0
  if(ret != 0) {
  } else {
I attach also the output that I see with a logic analyzer:
Any idea where I am doing something wrong?
Many thanks in advance!
  • Hi Jared,
    I modified the file as you suggested, set the pins CPUNET_UARTE_PIN_RTS and CPUNET_UARTE_PIN_CTS to a different value and the issue is now gone Slight smile
    I wonder if there is any alternative to manually modifying the pins in the nrf5340_cpunet_reset.c file. Can I maybe do it from the overlay file?
    As far as I understand, this file is part of the Nordic toolchain. This means, that each developer building and running my project would have to manually edit the file. I do not really find this optimal..
    Best regards.
    As of right know, the edit should be done in the specific file. As you can read from the comment, the developers are aware of this non optimal solution, and I'm confident that this will change in a future release so that the pins assignment is done based on a overlay file instead of hardcoding values.
    I totally agree with you.
    regards
    Jared
