Resume the state of registers and memory
Hi There,
I try to develop an application in intermittent conditions,  it will off work frequently as for lacking the energy.
I try to resume the application from the last losing point rather than the starting point.
How should I do?
Gaosheng Liu
  • Which of the two requirements I detailed is the one you are referring to?
    In your reply you have quoted both, so I am not sure which of them is exactly what you mean.
    Hi Karl,
    Nice to see you again! According to your indications, I am reading the corresponding doc and try to see if can achieve the aim. It may need much time to do it. I will let you know the result then.
    Best,
    Gaosheng
    Likewise, Gaosheng!
    In my previous question I asked which of the two scenarios I detailed (SYSTEM_ON vs SYSTEM_OFF) that applied to your situation - because I have not fully understood which of the two you mean when you talk about sleep and the requirements of your system.
    Taking your last question about SYSTEM_ON sleep into account, I suppose I can assume you meant SYSTEM_ON sleep - in which case it should not take too long for you to try out / utilize, since you can make use of the power management module to configure and use the SYSTEM_ON sleep, like shown in the BLE peripheral examples I mentioned.
    Please do not hesitate to ask if you should have any questions about this, or if you encounter any issues!
    Karl
  • Taking your last question about SYSTEM_ON sleep into account, I suppose I can assume you meant SYSTEM_ON sleep - in which case it should not take too long for you to try out / utilize, since you can make use of the power management module to configure and use the SYSTEM_ON sleep, like shown in the BLE peripheral examples I mentioned.
    Hi Karl,
    I want to know which example you referred to in the BLE peripherals examples list.
    Best,
    Gaosheng
  • Hello Gaosheng,
    You could take a look at the BLE UART peripheral example to see SYSTEM_ON sleep demonstrated. Please see how the idle_state_handle function enters SYSTEM_ON sleep when no other jobs needs doing.
    Karl
  • Hi Karl,
    I am very grateful for your help! It is really kind of you!
    Gaosheng
