sprintf format issue
I am doing a simple thing with string formatting:
sprintf(tmp_str,"%d.%d.%3d", version.major, version.minor, version.patch);
The version structure has values { 0, 5, 1 } and char tmp_str[20]. I want to achieve string like "0.5.001". Instead of getting this format, I am getting "0.5.d".
For a curiosity I tried to change the format to "%3d.%d.%d" and I got "d.0.5". Format "%d.%d.%d" works as expected - 0.5.1.
I am using SDK 17.0.2 and SES 5.60.
Can somebody advise me how to brush sprintf to work as expected? I am not asking for workarounds how to get the expected string format rather to get sprintf working.
Thanx.
peter
  • Hi Torbjørn,
    I am based on ble_peripheral, ble_app_template.
    The version string I am cheking through DIS service. I now tried to use NRF_LOG_INFO this way (the structure values are 0, 5, 1):
    sprintf(tmp_str,"%d.%d%.3d", version.major, version.minor, version.patch);
    NRF_LOG_INFO("Firmware version: v%s", tmp_str);
    printf("Firmware version: v%s", tmp_str);
    I am getting output on the console:
    <info> app: Firmware version: v
    There is no version number in the output form NRF_LOG_INFO and nothing from the printf().
    peter
  • Hi Peter
    What is the type of the version.major, version.minor and version.patch fields?
    Could you try to cast them to int in the call to sprintf?
    sprintf(tmp_str,"%d.%d%.3d", (int)version.major, (int)version.minor, (int)version.patch);
    If it's still not working, could you check the value of the tmp_str buffer in the debugger?
    Best regards
    Torbjørn
  • Hi Torbjørn,
    the variables are of int type.
    I checked the tmp_str values just after calling the sprintf(). You can see the values on the screenshot:
    peter
  • Hi Peter
    Then I am running low on ideas, it works fine here ;)
    Are you able to zip your project folder (including project and source files) and share it with me, so I can test out your exact configuration?
    You might want to remove the build files first, to reduce the file size.
    Best regards
    Torbjørn
  • Hello Peter and Torbjørn,
    Peter I realize a few days have passed since your initial post.  Have you been able to solve your printf() formatting issue yet?  Today while working on a different project and problem I came across a new project dialog in Nordic's version of Segger (Nordic SES release 5.6), with extra support for nRF Connect SDK projects.  A "Common Project Settings" dialog there catches my eye.  There are references to several printf functionalities, most of which are disabled by default.
    One of the options is called "printf width/precision".  Here is a window capture of this dialog box:SES "Choose Common Project Settings"
    When I initially wrote and suggested to try "%03d" format specifier in place of "%3d" specifier, I first wrote a short C program to be sure this specifier worked.  Running the program on the host workstation confirmed this.  The version of C which I was able to test against is:
    $ /lib/x86_64-linux-gnu/libc.so.6
    GNU C Library (Ubuntu GLIBC 2.31-0ubuntu9.2) stable release version 2.31.
    Compiling C natively under Ubuntu 20.04, libc6 printf libraries are fully enabled by default.  Printf family functions however, as you likely know, can be too large for microcontrollers with limited flash and other memory, so significant parts (or all) of printf formatting are often disabled by default in firmware development settings.
    Perhaps in your project environment some of these printf functionalities are disabled right now, like the ones in the window capture above?
    - Ted
