Strange behavior upon device reset
I might be missing something obvious here, but when the device is flashed (via SES), the application works correctly. When the device is power cycled or reset due to the watch dog timer, it turns into what appears to be the blinky example, which is incredibly different than the application I am testing. Is there something I am overlooking regarding the bootloader or some other piece of the puzzle?
Using the nRF52840 DK with a LoRa shield attached, for reference.
    Everything below 0x27000 in flash is the SoftDevice, which is Nordic's BLE stack. This is binary only so you will not see anything useful by inspecting this part with a debugger.
    It would be interesting to know if the issue you see is related to it not being the first time the firmware runs (for instance because it corrupts it's own flash or something else), or if it is related to using a debugger or not. Could you try do do a full chip erase, then program the device using for instance nrfjprog but take care not to reset. Then power-cycle the device and see if it comes up normally or not? If it does, then this is probably related to difference between first run or not. If it does not come up, then perhaps it is related to the debugger being connected or not. In that case it would be interesting to see if you can recover also by attaching a debugger and starting to debug without programming again first?
    Lastly, It would be interesting to see your changes to the project. Perhaps you can share a diff showing all your changes?
  • Okay, so this got me to a position where the problem is fixed.However, I'm still not entirely sure what happened in the first place. Does the blinky example hex use a different SoftDevice? Ultimately, my fix was to just erase the chip and then reinstall SoftDevice 140 + the application. That 64 bytes being overwritten in that section (0xE200) doesn't seem to actually cause any issues (obviously we need to change the location of flash to write those 64 bytes at some point), because I didn't change the location of that flash write but it works fine now.
    At any rate, thank you for your help!
    The Blinky example in the SDK does not use the SoftDevice at all. Did you confirm that you used the Blinky example, or did you just see LED's blinking (which could be caused by any firmware)?
    Another possible possible reason for recovering with a full chip erase is for instance if you programmed a bootloader in the first run. The bootloader would then blink a LED to indicate it is advertising. And if you flashed an application but did not update the bootloader settings, the bootloader would see it as an invalid application and not start it. By doing a full chip erase you would erase the bootloader. I am not sure this is what happened as I have not seen clearly if you were using a bootloader or not. But it is a possible explanation.
  • Can you elaborate on the difference between what happens when you run "Debug > Go" from SES versus a cold power on? I'm still confused about what happens there. Why did the application run from "Debug > Go" but would go into a fail state if just simply powered on with that firmware already flashed? I assume there is somehow a different entry point, but that seems strange to me.
    As far as I know, there was no explicit bootloader. I've only flashed example projects from the SDK and the aforementioned application.
    I see. Then you are not using a bootloader so we can ignore that from now on.
    You execute the same code in both cases here, as SES will also start executing from 0. The debugger will cause clocks to run etc, but that should not matter on code execution. There is a quite common issue though, and that is if you use logging and that depends on the debugger (either as UART bridge or for RTT logging). Depending on configuration, you could end up in a dead-lock if logs are not processed and the buffer is full. It is worth disabling any logging and see if that has effect (if you use the logger module, set NRF_LOG_ENABLED to 0 in sdk_config.h). If you use other log mechanism, disable that.
