nRF5340 NVS and readback_protection
Hi Everybody,
We found little or no literature about readback_protection on the nRF5340 SOC. Our issue is that for development and debugging it is not practical to use nrfjprog -recover in order to re-flash as that completely erases the storage partition too. What is the right way to retain NVS data?
Thank you.
Milan
    That would work well.
    Have you been able to reproduce this (make it fail) with 1.7.0? I see you are using 1.7.99, which is master, and that changes more or less every day. That is not recommended for use unless you have a particular good reason for doing so.
  • Hi, I saw you created a sample app for zigbee and the nrf53. I will try that one. I changed to 1.7.0 and updated west. Its still the same. Will be back with some results on this.
  • Hi Einar,
    Looks like I found the issue. This is all triggered by calling
    wdt_setup(wdt, 0);
    The WDT init function has no effect. The second I took the function out, the lock did not appear again. Do you have any workaround that?
  • That is surprising. Can you show a bit more of your code, ad least where "wdt" comes from? Is it the same if the second parameter is 1?
  • It is. That is why I did not think about it before.
    Basically,
    CONFIG_WATCHDOG=y
    The module for watchdog handling:
    LOG_MODULE_REGISTER(watchdog, LOG_LEVEL_INF);
    #if DT_NODE_HAS_STATUS(DT_ALIAS(watchdog0), okay)
    #elif DT_HAS_COMPAT_STATUS_OKAY(nordic_nrf_watchdog)
    #define WDT_NODE DT_INST(0, nordic_nrf_watchdog)
     * If the devicetree has a watchdog node, get its label property.
    #ifdef WDT_NODE
    #define WDT_DEV_NAME DT_LABEL(WDT_NODE)
    #else
    #define WDT_DEV_NAME ""
    #error "Unsupported SoC and no watchdog0 alias in zephyr.dts"
    const struct device *wdt; /*There could only be one watchdog instance for nRF*/
    static void wdt_callback(const struct device *wdt_dev, int channel_id)
        static bool handled_event;
        if (handled_event)
            return;
        wdt_feed(wdt_dev, channel_id);
        LOG_ERR("Watchdog handled things..ready to reset");
        handled_event = true;
    void dd_wdt_init()
        LOG_WRN("Initialize Watchdog");
        wdt = device_get_binding(WDT_DEV_NAME);
        if (!wdt)
            LOG_ERR("Cannot get WDT device");
            return;
    int dd_wdt_add_channel()
        int wdt_channel_id;
        struct wdt_timeout_cfg wdt_config;
        /* Reset SoC when watchdog timer expires. */
        wdt_config.flags = WDT_FLAG_RESET_SOC;
        /* Expire watchdog after 1000 milliseconds. */
        wdt_config.window.min = 0U;
        wdt_config.window.max = WATCHDOG_TIMEOUT_MS;
        /* Set up watchdog callback. Jump into it when watchdog expired. */
        wdt_config.callback = wdt_callback;
        wdt_channel_id = wdt_install_timeout(wdt, &wdt_config);
        if (wdt_channel_id == -ENOTSUP)
            wdt_config.callback = NULL;
        if (wdt_channel_id < 0)
            LOG_ERR("Watchdog channel install error");
            return -1;
        LOG_WRN("Watchdog added to channel %i", wdt_channel_id);
        return wdt_channel_id;
    int dd_watchdog_start()
        int err = wdt_setup(wdt, 0);
        if (err < 0)
            LOG_ERR("Watchdog setup error");
            return err;
        return err;
    void dd_wdt_feed(int wdt_channel_id)
        wdt_feed(wdt, wdt_channel_id);
    when dd_watchdog_start() is called (just a wrapper for wdt_setup()) the write protection kicks in. The program runs without errors and watchdog resets.
