Watchdog event handler timeout
I want to write some values to flash before the watchdog resets. For this I have the watchdog event handler specified:
err_code = nrf_drv_wdt_init(&config, wdt_event_handler);
In the wft_event_handler function I write a struct to flash with the fds module. This struct conaints 16 bytes, so 4 words. If I'm right the watchdog event handler takes 2*32768khz clock cycles, so around 61uS. I read somehwere that 1 words takes about 46 us. Is there a way to increase this timeout somehow? I need to write all this data to flash before a watchdog timeout occurs.
  • I use the GCC toolchain with makefiles and linkerscript provided by Nordic.
    There such a section doesn't exist, but I tried to make one but doesn't retain memory.
    Therefore I tried this in SES, and there I can see that byte0 of the retained_buffer increases, but after a reset it gets a certain value, which implies it didn't initialize to 0. However, it doesn't contain the value it had before reset, so it's not retaining its RAM. Am I doing something wrong?
    And what would be the correct way to do it in GCC ?
    It is possible with GCC as well, for instance as discussed in this thread.
    Regarding SES it should normally work as long as the example project you use has ".non_init" in the flash_placement.xml file. Did you get a warning during building? (Also, the degree of which RAM content persists may depend on several other factors as well, and this is using the IC out of specification, so you can never be guaranteed that RAM data is retained after a reset.)
  • I use the app_template as a test for this. In the flash_placement.xml I can see a ".non-init" section.
    I added the code exactly as you described, and I tested as follows:
    On button 1 press, it add's 1 to the [0] of the retained buffer. I put this information in a log. See log below:
    00> <info> app_timer: RTC: initialized.
    00>
    00> <info> app: Template example started.
    00>
    00> <info> app: Fast advertising.
    00>
    00> <info> app: Data from previoius run:
    00>
    00> <info> app:  CA 0B 26 ED 61 FE 0B F9|..&.a...
    00>
    00> <info> app:  70 18 F6 89 BD FF 7D 9B|p.....}.
    00>
    00> <info> app: Updated data:
    00>
    00> <info> app:  CB 0B 26 ED 61 FE 0B F9|..&.a...
    00>
    00>
    00>
    00>
    00>
    00>
    00> <info> app:  CC 0B 26 ED 61 FE 0B F9|..&.a...
    00>
    00>
    00>
    00>
    00>
    00>
    00> <info> app:  C8 0B 06 ED 61 FE 0B D9|....a...
    00>
    00> <info> app:  70 08 D6 89 BD 7F 7D 93|p.....}.
    00>
    00>
    00> <info> app:  C9 0B 06 ED 61 FE 0B D9|....a...
    00>
    00>
    00>
    00>
    00>
    00>
    00> <info> app:  CA 0B 06 ED 61 FE 0B D9|....a...
    00>
    00>
    00>
    00>
    00>
    00>
    00> <info> app:  C8 03 26 ED 61 FE 0B F9|..&.a...
    00>
    00> <info> app:  68 08 D6 C9 AD 7F 7D 9B|h.....}.
    00>
    00>
    00> <info> app:  C9 03 26 ED 61 FE 0B F9|..&.a...
    00>
    00>
    So when flashed m_retained_buffer[0] is CA. After a press it get's CB after another press CC. Then I press the reset button on my devkit and then m_retained_buffer[0] becomes suddenly C8. After a couple presses and another reset it becomes C8 again.
    The data could be corrupted from time to time, but it is a bit odd that it happens so often, and even more odd that it seems to always be reset to 0xC8 when it does. Can you share the full project you tested with? Do you by any chance have anything else that could be suing the same RAM at some point, for instance a bootloader?
  • It's the app_template what I use for it. I've send it via PM to you to check it.
    In my own project I indeed have a bootloader, which makes it more complex. That's why I first want to get it working with the app_template.
