Debug session fails to run Zephyr blinky sample in VSCode with nRF Connect
I'm trying out nRF Connect running inside VS Code and I'm running into issues debuggin my code.  I followed the Nordic setup tutorial and installed the latest nRF Connect SDK, then nRF Command Line Tools with Segger Tools, Visual Studio Code and finally added the nRF Connect extension package (Cortex-Debug,  NRF Connect, nRF Kconfig etc.).  I then created an application as directed, and then a build configuration with debug options enabled.  I then built the application and flashed my board (Thingy:52) and saw the LED blink on my development board.  Up till this point everything worked great, then I tried hitting the debug button under the action menu and received the following error below:
I also tried building, downloading code and debugging in the Segger nRF Connect IDE and everything worked great!  So I assumed my base toolchain is good.  I'm not very experienced with setting up IDEs and based on the tutorial this step should just work without me editing any .jason files etc.  Any obvious things I'm missing?
Hardware/Software Setup:
OS:  Windows 10
VS Code Version:  1.60.2
nRF Connect SDK Version:  v1.7.0
J-Link Version:  7.54c
Debugger:  j-link segger EDU edtion
Development Board:  Thingy:52
Thanks!
Parker
  • Hi Parker,
    Thanks for your patience whilst we look into this. We'd like to gather a bit more information about your environment so that we can more easily reproduce this problem. To that end, we've created a build that more accurately detects the installed tools in the Generate Support Information command.
    Since this is a private build, I can't upload it directly to this issue, but I can do so if you create a new private ticket. You can do so by clicking the "Support +" button at the top of the page, and then selecting "Private Support Ticket". You might need to add some more information to your DevZone profile for this option to be available.
    Dee
    VS Code Team
  • Great!  I'm making a private ticket now.
    Cheers,
    Parker
  • I was able to fix the same problem on Windows 10 by adding the directory of the .exe (C:\Program Files\SEGGER\JLink for my system) to the system path and restarting VsCode.
    Maybe it will help others.
    Mark
  • Hi Mark,
    Thank you for sharing your solution so others can find it!
    It was found that this is a bug in the current version of the VS Code extension, where the extension is only looking for the JLink executable in the "Program Files (x85)" directory, and is therefore unable to find the executable when it is installed in "Program Files". This will be fixed in the next release of the extension.
    Another solution in the meantime is to create a symlink between the two directories:
    mklink /d "C:\Program Files (x86)\SEGGER\JLink" "C:\Program Files\SEGGER\JLink"
    Marte
