nRF52 TIMER PPI GPIOTE dropouts/pauses issue
Hi. I'm trying to output frequency (in the 1,250 Hz to 1,750 Hz range) on GPIO. Each frequency should be outputted for 5ms time. For that, I use 2 TIMERs: one for 5ms counter and one for frequency output + PPI + GPIOTE. I have a lookup array with "tones" for certain frequencies. When the 5ms timer fires up I pass the next value from the array to the frequency output timer as the CC value.
The problem is when frequency outputs I can see some dropouts in frequency with logic analyzer. These dropouts occur in different moments but in most cases, they last about 4ms.
I expect to frequency change without any dropouts and pauses. What I'm doing wrong?
Here is the code
(based on ...\nRF5_SDK_17.0.2_d674dde\examples\peripheral\timer)
#define GPIO_FREQ_OUT 4
static const nrf_drv_timer_t timer_inst_t5ms = NRF_DRV_TIMER_INSTANCE(1); //!don't use TIMER0 with softdevice
static const nrf_drv_timer_t timer_inst_freq = NRF_DRV_TIMER_INSTANCE(3); //!don't use TIMER0 with softdevice
static nrf_ppi_channel_t     m_ppi_channel;
uint16_t tone_member = 1;
uint32_t timer_5ms_counter = 0;
 * @brief Handler for timer events.
void t5ms_timer_event_handler(nrf_timer_event_t event_type, void *p_context)
    switch (event_type)
    case NRF_TIMER_EVENT_COMPARE0:
        nrf_gpio_pin_toggle(3);
        fm_set_duty(tone_array[tone_member]);
        //**********tone_member table go up
        if (tone_member < TONE_TABLE_MEMBERS)
           tone_member++;
        else if (tone_member >= TONE_TABLE_MEMBERS)
           tone_member = 0;
           nrf_drv_timer_disable(&timer_inst_t5ms);
           nrf_drv_timer_disable(&timer_inst_freq);
           nrf_drv_ppi_channel_disable(m_ppi_channel);
           nrf_drv_gpiote_out_task_disable(GPIO_FREQ_OUT);
        //**********tone table go up
void fm_set_duty(uint32_t period)
    nrf_drv_timer_extended_compare(&timer_inst_freq,
                                 NRF_TIMER_CC_CHANNEL0,
                                 period,
                                 NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                 false);
    uint32_t time_ticks;
    uint32_t err_code = NRF_SUCCESS;
    //>>>GPIOTE init
    nrf_drv_gpiote_out_config_t config = GPIOTE_CONFIG_OUT_TASK_TOGGLE(false);
    err_code = nrf_drv_gpiote_out_init(GPIO_FREQ_OUT, &config);
    //<<<GPIOTE init
    ////>>>TIMER init
    timer_cfg.bit_width = NRF_TIMER_BIT_WIDTH_16;
    err_code = nrf_drv_timer_init(&timer_inst_freq, &timer_cfg, freq_timer_event_handler);
                                   tone_array[0],
                                   false);
    ////<<<<TIMER init
    //>>>PPI init
    uint32_t compare_evt_addr;
    uint32_t gpiote_task_addr;
    compare_evt_addr = nrf_drv_timer_event_address_get(&timer_inst_freq, NRF_TIMER_EVENT_COMPARE0);
    gpiote_task_addr = nrf_drv_gpiote_out_task_addr_get(GPIO_FREQ_OUT);
    err_code = nrf_drv_ppi_channel_assign(m_ppi_channel, compare_evt_addr, gpiote_task_addr);
    err_code = nrf_drv_ppi_channel_enable(m_ppi_channel);
    nrf_drv_gpiote_out_task_enable(GPIO_FREQ_OUT);
    //<<<PPI init
    ////>>>TIMER init
    err_code = nrf_drv_timer_init(&timer_inst_t5ms,
                                  &timer_cfg,
                                  t5ms_timer_event_handler);
    time_ticks = nrf_drv_timer_ms_to_ticks(&timer_inst_t5ms, 5);
    nrf_drv_timer_extended_compare(&timer_inst_t5ms,
                                   time_ticks,
                                   true);
    nrf_drv_timer_enable(&timer_inst_t5ms);
    ////<<<<TIMER init
    nrf_drv_timer_enable(&timer_inst_freq);
    //>>>GPIO init
    nrf_gpio_cfg_output(3);
    //<<<GPIO init
    while (1)
        __WFI();
const uint16_t tone_array[1024] = {
6400, 6398, 6395, 6393, 6390, 6388, 6385, 6383, 6380, 6378, 6375, 6373, 6370, 6368, 6365, 6363,
6360, 6358, 6356, 6353, 6351, 6348, 6346, 6343, 6341, 6338, 6336, 6333, 6331, 6329, 6326, 6324,
6321, 6319, 6316, 6314, 6311, 6309, 6307, 6304, 6302, 6299, 6297, 6295, 6292, 6290, 6287, 6285,
6282, 6280, 6278, 6275, 6273, 6270, 6268, 6266, 6263, 6261, 6258, 6256, 6254, 6251, 6249, 6247,
6244, 6242, 6239, 6237, 6235, 6232, 6230, 6228, 6225, 6223, 6220, 6218, 6216, 6213, 6211, 6209,
6206, 6204, 6202, 6199, 6197, 6195, 6192, 6190, 6188, 6185, 6183, 6181, 6178, 6176, 6174, 6171,
6169, 6167, 6164, 6162, 6160, 6157, 6155, 6153, 6150, 6148, 6146, 6143, 6141, 6139, 6137, 6134,
6132, 6130, 6127, 6125, 6123, 6121, 6118, 6116, 6114, 6111, 6109, 6107, 6105, 6102, 6100, 6098,
6095, 6093, 6091, 6089, 6086, 6084, 6082, 6080, 6077, 6075, 6073, 6071, 6068, 6066, 6064, 6062,
6059, 6057, 6055, 6053, 6050, 6048, 6046, 6044, 6042, 6039, 6037, 6035, 6033, 6030, 6028, 6026,
6024, 6022, 6019, 6017, 6015, 6013, 6011, 6008, 6006, 6004, 6002, 6000, 5997, 5995, 5993, 5991,
5989, 5986, 5984, 5982, 5980, 5978, 5975, 5973, 5971, 5969, 5967, 5965, 5962, 5960, 5958, 5956,
5954, 5952, 5949, 5947, 5945, 5943, 5941, 5939, 5936, 5934, 5932, 5930, 5928, 5926, 5924, 5921,
5919, 5917, 5915, 5913, 5911, 5909, 5907, 5904, 5902, 5900, 5898, 5896, 5894, 5892, 5890, 5887,
5885, 5883, 5881, 5879, 5877, 5875, 5873, 5871, 5868, 5866, 5864, 5862, 5860, 5858, 5856, 5854,
5852, 5850, 5848, 5845, 5843, 5841, 5839, 5837, 5835, 5833, 5831, 5829, 5827, 5825, 5823, 5820,
5818, 5816, 5814, 5812, 5810, 5808, 5806, 5804, 5802, 5800, 5798, 5796, 5794, 5792, 5790, 5788,
5786, 5784, 5781, 5779, 5777, 5775, 5773, 5771, 5769, 5767, 5765, 5763, 5761, 5759, 5757, 5755,
5753, 5751, 5749, 5747, 5745, 5743, 5741, 5739, 5737, 5735, 5733, 5731, 5729, 5727, 5725, 5723,
5721, 5719, 5717, 5715, 5713, 5711, 5709, 5707, 5705, 5703, 5701, 5699, 5697, 5695, 5693, 5691,
5689, 5687, 5685, 5683, 5681, 5679, 5677, 5675, 5673, 5671, 5669, 5667, 5666, 5664, 5662, 5660,
5658, 5656, 5654, 5652, 5650, 5648, 5646, 5644, 5642, 5640, 5638, 5636, 5634, 5632, 5630, 5629,
5627, 5625, 5623, 5621, 5619, 5617, 5615, 5613, 5611, 5609, 5607, 5605, 5604, 5602, 5600, 5598,
5596, 5594, 5592, 5590, 5588, 5586, 5584, 5583, 5581, 5579, 5577, 5575, 5573, 5571, 5569, 5567,
5565, 5564, 5562, 5560, 5558, 5556, 5554, 5552, 5550, 5549, 5547, 5545, 5543, 5541, 5539, 5537,
5535, 5534, 5532, 5530, 5528, 5526, 5524, 5522, 5520, 5519, 5517, 5515, 5513, 5511, 5509, 5507,
5506, 5504, 5502, 5500, 5498, 5496, 5495, 5493, 5491, 5489, 5487, 5485, 5484, 5482, 5480, 5478,
5476, 5474, 5473, 5471, 5469, 5467, 5465, 5463, 5462, 5460, 5458, 5456, 5454, 5452, 5451, 5449,
5447, 5445, 5443, 5442, 5440, 5438, 5436, 5434, 5433, 5431, 5429, 5427, 5425, 5424, 5422, 5420,
5418, 5416, 5415, 5413, 5411, 5409, 5408, 5406, 5404, 5402, 5400, 5399, 5397, 5395, 5393, 5391,
5390, 5388, 5386, 5384, 5383, 5381, 5379, 5377, 5376, 5374, 5372, 5370, 5369, 5367, 5365, 5363,
5362, 5360, 5358, 5356, 5354, 5353, 5351, 5349, 5348, 5346, 5344, 5342, 5341, 5339, 5337, 5335,
5334, 5332, 5330, 5328, 5327, 5325, 5323, 5321, 5320, 5318, 5316, 5315, 5313, 5311, 5309, 5308,
5306, 5304, 5302, 5301, 5299, 5297, 5296, 5294, 5292, 5290, 5289, 5287, 5285, 5284, 5282, 5280,
5278, 5277, 5275, 5273, 5272, 5270, 5268, 5267, 5265, 5263, 5262, 5260, 5258, 5256, 5255, 5253,
5251, 5250, 5248, 5246, 5245, 5243, 5241, 5240, 5238, 5236, 5235, 5233, 5231, 5230, 5228, 5226,
5225, 5223, 5221, 5220, 5218, 5216, 5215, 5213, 5211, 5210, 5208, 5206, 5205, 5203, 5201, 5200,
5198, 5196, 5195, 5193, 5191, 5190, 5188, 5186, 5185, 5183, 5181, 5180, 5178, 5177, 5175, 5173,
5172, 5170, 5168, 5167, 5165, 5163, 5162, 5160, 5159, 5157, 5155, 5154, 5152, 5150, 5149, 5147,
5146, 5144, 5142, 5141, 5139, 5138, 5136, 5134, 5133, 5131, 5129, 5128, 5126, 5125, 5123, 5121,
5120, 5118, 5117, 5115, 5113, 5112, 5110, 5109, 5107, 5105, 5104, 5102, 5101, 5099, 5098, 5096,
5094, 5093, 5091, 5090, 5088, 5086, 5085, 5083, 5082, 5080, 5079, 5077, 5075, 5074, 5072, 5071,
5069, 5067, 5066, 5064, 5063, 5061, 5060, 5058, 5057, 5055, 5053, 5052, 5050, 5049, 5047, 5046,
5044, 5042, 5041, 5039, 5038, 5036, 5035, 5033, 5032, 5030, 5029, 5027, 5025, 5024, 5022, 5021,
5019, 5018, 5016, 5015, 5013, 5012, 5010, 5009, 5007, 5005, 5004, 5002, 5001, 4999, 4998, 4996,
4995, 4993, 4992, 4990, 4989, 4987, 4986, 4984, 4983, 4981, 4980, 4978, 4977, 4975, 4973, 4972,
4970, 4969, 4967, 4966, 4964, 4963, 4961, 4960, 4958, 4957, 4955, 4954, 4952, 4951, 4949, 4948,
4946, 4945, 4943, 4942, 4940, 4939, 4937, 4936, 4934, 4933, 4931, 4930, 4929, 4927, 4926, 4924,
4923, 4921, 4920, 4918, 4917, 4915, 4914, 4912, 4911, 4909, 4908, 4906, 4905, 4903, 4902, 4900,
4899, 4898, 4896, 4895, 4893, 4892, 4890, 4889, 4887, 4886, 4884, 4883, 4881, 4880, 4879, 4877,
4876, 4874, 4873, 4871, 4870, 4868, 4867, 4865, 4864, 4863, 4861, 4860, 4858, 4857, 4855, 4854,
4852, 4851, 4850, 4848, 4847, 4845, 4844, 4842, 4841, 4840, 4838, 4837, 4835, 4834, 4832, 4831,
4830, 4828, 4827, 4825, 4824, 4822, 4821, 4820, 4818, 4817, 4815, 4814, 4812, 4811, 4810, 4808,
4807, 4805, 4804, 4803, 4801, 4800, 4798, 4797, 4796, 4794, 4793, 4791, 4790, 4789, 4787, 4786,
4784, 4783, 4782, 4780, 4779, 4777, 4776, 4775, 4773, 4772, 4770, 4769, 4768, 4766, 4765, 4763,
4762, 4761, 4759, 4758, 4757, 4755, 4754, 4752, 4751, 4750, 4748, 4747, 4745, 4744, 4743, 4741,
4740, 4739, 4737, 4736, 4734, 4733, 4732, 4730, 4729, 4728, 4726, 4725, 4724, 4722, 4721, 4719,
4718, 4717, 4715, 4714, 4713, 4711, 4710, 4709, 4707, 4706, 4705, 4703, 4702, 4700, 4699, 4698,
4696, 4695, 4694, 4692, 4691, 4690, 4688, 4687, 4686, 4684, 4683, 4682, 4680, 4679, 4678, 4676,
4675, 4674, 4672, 4671, 4670, 4668, 4667, 4666, 4664, 4663, 4662, 4660, 4659, 4658, 4656, 4655,
4654, 4652, 4651, 4650, 4648, 4647, 4646, 4644, 4643, 4642, 4640, 4639, 4638, 4636, 4635, 4634,
4633, 4631, 4630, 4629, 4627, 4626, 4625, 4623, 4622, 4621, 4619, 4618, 4617, 4616, 4614, 4613,
4612, 4610, 4609, 4608, 4606, 4605, 4604, 4603, 4601, 4600, 4599, 4597, 4596, 4595, 4594, 4592,
4591, 4590, 4588, 4587, 4586, 4584, 4583, 4582, 4581, 4579, 4578, 4577, 4576, 4574, 4573, 4572
My setup:
nRF52832 (NRF52 DK)
SDK 17.0.2
SES 5.5
SoftDevice none (but in future this code must with it)
Logic analyzer screenshots (bottom channel is a visualization of the 5ms timer)
Hope you can help me. I'm out of ideas.
  • 1x000 said:
    I tested with correct bounds and if I didn't perform a CLEAR task there are 4ms pauses.
    1x000 said:
    They are caused by Counter overflow? Also, I noticed that pauses only appear when both timers are triggered at the same time. Why this is so?
    No, not overflow, but nrf_drv_timer_extended_compare() disables the shorts briefly, in order to set the new shorts mask specified in nrf_drv_timer_extended_compare(), so then there is a chance that the CC event triggers at the same time the shorts are disabled, and if that happens, then it's not cleared automatically, so you should therefore trigger the clear task manually.
    1x000 said:
    This time there are no 4ms pauses, which is good. But as before we got a little pause on each 5ms tick.
    Was this with disabling the timer and clearing, or is this with only clearing?
  • This capture from my previous post was taken with the only CLEAR task.
    I've just tried it with both nrf_drv_timer_disable(&timer_inst_freq) and nrf_drv_timer_clear(&timer_inst_freq)
    Here is the result
    The pauses are still present. But they are getting longer and shorter. On this screen on the left side pauses are about 625μs long (when normal wave must be about 310μs). On the right side, pauses are about 316μs (almost invisible)
    You could try to simply use nrfx_timer_compare(), and see if that helps with the pauses:
    nrfx_timer_compare(&timer_inst_freq,
    period,
    false);
    #include <stdbool.h>
    #include <stdint.h>
    #include "nrf.h"
    #include "nrf_drv_timer.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_gpiote.h"
    #include "nrf_gpiote.h"
    #include "nrf_gpio.h"
    #include "app_error.h"
    //#include "nrf_pwr_mgmt.h"
    //#include "tone_array.h"
    #define TONE_TABLE_MEMBERS 1024
    const uint32_t tone_array[1024] = {
                         period,
                        false);
        switch (event_type)
                if (tone_member < (TONE_TABLE_MEMBERS-1))
                    tone_member++;
                else if (tone_member >= (TONE_TABLE_MEMBERS-1))
                    tone_member = 0;
                    // nrf_drv_timer_disable(&timer_inst_t5ms);
                    // nrf_drv_timer_disable(&timer_inst_freq);
                    // nrf_drv_ppi_channel_disable(m_ppi_channel);
                    // nrf_drv_gpiote_out_task_disable(GPIO_FREQ_OUT);
                //************30 sec ramp from tone table******
                if (timer_5ms_counter >= 6000)
                timer_5ms_counter++;
    void freq_timer_event_handler(nrf_timer_event_t event_type, void *p_context)
        //>>>GPIOTE init
        //<<<GPIOTE init
        ////>>>TIMER init
        //nrf_drv_timer_extended_compare(&timer_inst_freq,
        //                               NRF_TIMER_CC_CHANNEL0,
        //                               tone_array[0],
        //                               NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
        //                               false);
       // fm_set_duty(tone_array[0]); // MOVED
        ////<<<<TIMER init
        //>>>PPI init
        //<<<PPI init
        ////>>>TIMER init
                                      &timer_cfg,
                                       time_ticks,
                                       true);
        ////<<<<TIMER init
         //fm_set_duty(tone_array[tone_member]);
         tone_member++;
        //>>>GPIO init
      nrf_drv_timer_clear(&timer_inst_freq);
                                     tone_array[tone_member],
                                     false);
        //<<<GPIO init
        while (1)
            __WFI();
