Can't receive bytes sent via ByteArray in nRFConnect App
I created a custom BLE service following this tutorial and I am able to connect to the BLE service and write data to it, but ideally, I want to send character bytes as opposed to just decimal values.
In the nRFConnect app, seemingly ByteArray is a field to enter character bytes but when I enter a character, on_write is invoked and p_evt_write->len remains 0, and so is p_evt_write->data
But when I send in an Unsigned field, I receive the expected data and so does the length.
Also can we not send multiple bytes at once? because otherwise p_evt_write->len would always remain 1 hence no actual use.
Am I using the ByteArray field correctly?
  • Okay, so I tried again and despite having max_len at sizeof(uint8_t) * 5, I can send/receive < 5 bytes. Do you see why would that be? (p_evt_write->len < 5)
    Secondly, there's no way for you to send string bytes? Would you have to consult to the ASCII table to make sure you're sending the expected chars?
    Can you share your code so that I can see?
    When you have selected ByteArray, then yes. If you select UTF8, you can enter a string and it will be automatically converted to ASCII for you.
  • static uint32_t custom_value_char_add(BleCust * p_cus, const BleCustInit_t * p_cus_init)
        uint32_t            err_code;
        ble_gatts_char_md_t char_md;
        ble_gatts_attr_md_t cccd_md;
        ble_gatts_attr_t    attr_char_value;
        ble_uuid_t          ble_uuid;
        ble_gatts_attr_md_t attr_md;
        memset(&char_md, 0, sizeof(char_md));
        char_md.char_props.read   = 1;
        char_md.char_props.write  = 1;
        char_md.char_props.notify = 0;
        char_md.p_char_user_desc  = NULL;
        char_md.p_char_pf         = NULL;
        char_md.p_user_desc_md    = NULL;
        char_md.p_cccd_md         = NULL;
        char_md.p_sccd_md         = NULL;
        memset(&attr_md, 0, sizeof(attr_md));
        attr_md.read_perm  = p_cus_init->customCharAttr.read_perm;
        attr_md.write_perm = p_cus_init->customCharAttr.write_perm;
        attr_md.vloc       = BLE_GATTS_VLOC_STACK;
        attr_md.rd_auth    = 0;
        attr_md.wr_auth    = 0;
        attr_md.vlen       = 0;
        ble_uuid.type = p_cus->uuidType;
        ble_uuid.uuid = CUSTOM_VALUE_CHAR_UUID;
        memset(&attr_char_value, 0, sizeof(attr_char_value));
        attr_char_value.p_uuid    = &ble_uuid;
        attr_char_value.p_attr_md = &attr_md;
        attr_char_value.init_len  = sizeof(uint8_t);
        attr_char_value.init_offs = 0;
        attr_char_value.max_len   = sizeof(uint8_t) * 5;
        err_code = sd_ble_gatts_characteristic_add(p_cus->serviceHandle, &char_md,
                                                   &attr_char_value,
                                                   &p_cus->customValueHandle);
        if (err_code != NRF_SUCCESS)
            return err_code;
        return NRF_SUCCESS;
  • This looks OK for writing up to 5 bytes. Does it not work if you use ByteArray with hex or UTF8 with characters?
  • is it UP TO or neither more nor less which you indicated earlier? Unless I'm misinterpreting
