Eliminate BLE_HCI_INSTANT_PASSED 0x28 BLE disconnection
Hello Nordic Team,
We are developing a wearable device. We noticed spontaneous BLE disconnections every 1-2 hours. The error code is BLE_HCI_INSTANT_PASSED. I have checked all related questions in devzone, this one was especially useful. According to it, there are 3 root causes: LFCK inaccuracy, Radio Interference, and software that blocks BLE operations.
The problem appears mostly when the device is worn, i.e. the interference is increased from human body, clothing, and other obstacles (e.g. chair). Otherwise when the device is on the table, the issue is very hard to reproduce. That's why, I believe that the root cause is radio interference and probably signal weakness because of distance.
In any case, regarding LFCK, we chose external capacitors according to guidelines provided by Nordic. We also tried to use capacitors calculated with another formula given by the crystal manufacturer (it slightly differs from Nordic formula, and results in ~5pF difference). Also, we tried to increase LFCK accuracy from 20 to 250, and it didn't help.
Regarding software, we have priority 2 for TWI and PWM. PWM calls have been specifically disabled throughout the tests, so it shouldn't have any effect. TWI is used, but in blocking mode. If I am not mistaken, it should not interfere with Softdevice. Please correct me if I am wrong.
My understanding of this error is following: For example, Master is at 10th connection event. When it sends commands to update communication channels or to update connection parameters (the "special requests"), Slave has to respond within 6 next connection events. So, if we increase the connection interval, the overall time-window covering these 6 connection events will increase, thus if there was a noisy/blocking environment, by prolonging the time, we have higher chances that the problem will disappear before the connection is lost. Furthermore, when we increase the slave latency from 0 to lets say 5, then the wait window is increased to 11 instead of 6 connection events. Can you confirm that my understanding is correct?
Hoping that it will help, I did following modifications:
Old configuration:
  • Min. Interval: 20 ms
  • Max. Interval: 75 ms
  • Latency: 0
  • Timeout: 15 sec
New configuration:
  • Min. Interval: 30 ms
  • Max. Interval: 90 ms
  • Latency: 5
  • Timeout: 15 sec
But it didn't help.
I want to ask following:
  1. If my understanding about help of latency to this issue is correct, can I increase the latency to much higher value such as 30, 40? This would mean that if packets are lost 40 times in a row, the connection would be still alive, right?
  2. Instant Passed occurs after 6th connection event. Can we increase this "6" somewhere? Can central modify it? Our central is a smartphone.
  3. What would you recommend for starters to use for connection interval min/max values?
Please let me know if there are any other ideas that come to your mind.
I would greatly appreciate your assistance.
  • Ok here are the initial results:
    Firstly, I updated connection parameters to the following:
    • Min/Max connection interval: 60ms
    • Latency: 30
    • Timeout: 15 seconds
    Beyond these I would be out of specs for Apple Design guidelines regarding connection parameters (actually I am beyond the guidelines for the timeout, but haven't noticed any issues with it yet). I tried to increase these parameters further, but master wouldn't allow them and would override parameters with lesser values. Anyway, the 0x28 error occurred again with these parameters.
    Then, I increased the Tx power from 0dBm to 4dBm, and this time we got 0x8 error, which is timeout.
    I checked the sniffer logs, and saw that slave replies to master every 30th time due to latency. In other words, slave replies every ~2 seconds. Given 15 seconds timeout, if the slave doesn't reply 7 times in a row, it will get disconnected. Since 7 packets it pretty low number for timeout, I believe it is normal behavior.
    Now if we go back to the first test results, where power was 0dBm with latency 30, it would have taken 30+6 = 36 consecutive lost packets for the 0x28 error to happen. I doubt that it is possible due to radio interference. To elaborate, we have a test setup with a person wearing the device, sitting on the chair, and phone on the table right in front of the person. The distance is small. During this setup, when I check the sniffer logs, overall packet loss ratio is pretty satisfying, max 2-3 consecutive lost packets. When disconnection occurs, this would mean that now the device has 36 lost packets. But the testing conditions are the same. I highly doubt that same radio interference conditions would result in such high different loss rate.
    Perhaps then problem is in software, and after 1-2 hours master and slave somehow get out of sync in BLE communication. If you remember, I told that we had priority 2 TWI in our code. I forgot to mention that this TWI is called inside app_timer interrupt, not in the main context. We plan to use to scheduler, but haven't done it yet. This interrupt takes ~250ms. And it is called every second. May it be possible that it somehow disturbs the timing of BLE so that after some time communication is out of sync?
  • We did additional test with following parameters:
    Min/Max con. interval: 45ms
    Latency: 9
    Timeout: 15s
    Tx power: +4dBm
    We still received Instant Passed error approximately in 2 hours. I believe problem is not in connection parameters.
    We now decided to test with different phone model (all previous tests were conducted with Redmi Note 8T). Perhaps the problem is phone's clock accuracy or something else. I will let you know the results.
  • Hi there,
    Thanks for the update. I have some suggestions below:
    Can you clarify this part. How is the TWI implemented? It's a bit confusing that you use both interrupt priority and you run the TWI in blocking mode which doesn't use interrupts. Could you share this part of your code? I'm guessing that you're spinning in a loop in the app timer interrupt handler waiting for a flag to be set by the TWI interrupt handler as we do in our examples?
    Either way, running high priority TWI communication from interrupt context is definitely not recommended. As previously mentioned, timing critical events should not be blocked, but I'm suspecting that Softdevice operation is indirectly affected since Softdevice application events will be blocked. I'm not exactly sure what events, but I have a suggestion that will highlight if this is the issue or not:
    Could you try to move the TWI communication to main context? You can do this by setting a flag in the app timer interrupt handler that signalizes to the main loop that it can start the TWI transaction. You can then reset this flag when the transaction has ended in the TWI handler. Also try lowering the TWI priority.
    Also 250 ms is a lot. Is there a specific reason for this, file transfers?
    regards
    Jared
  • Hi Jared,
    Sorry for confusing. It is indeed blocking mode, I mentioned priority 2 just in case it had some internal use inside TWI. But as I understand, it doesn't have any effect. (We don't pass event handler to initialization).
    To test, we completely disabled TWI related activities in our software, we disabled the timers that were working every second, and in result our application was not doing anything except keeping up BLE communication, and some active GPIOTEs to which it was listening (no fired interrupts).
    We still got disconnection with code 0x28. We also tried with other LFCK which is 9pF, and put 12pF external capacitors (as in reference design) during this test.
    So, it seems issue is neither application, nor clock.
    During this test we had following parameters:
    Min/max interval: 45ms
    Latency: 6
    Timeout: 15
    Error happened ~15 minutes after start of test. The phone was the old phone that we used in our tests previously (Redmi Note 8T). I will try increasing LFCK accuracy to 250 or 500 again to see if it helps.
  • Also, I wanted to ask you about the nRF52 module that we use (BMD-350). It has very small physical size. Actually it is one of smallest nRF52 modules I have ever saw. May it be that its antenna is weak somehow because of such dimensions?
