How does the peripherals reconnect to central board when the BLE connection lost
Hello everyone, I am developing a system with multiple peripherals to a central board. How many peripherals can keep connecting with central at one time? I made some peripherals connected to a central board but after several hours, the connection of some peripherals lost and cannot reconnect to the BLE network. How can the peripherals reconnected to the central board? I have enlarge the timeout to 20s but it doesn't work. Any help will be appreciated.
  • Hi Jared, the peripherals in my project send data at a 20ms interval. The data should be sent to central during the connection interval. Here is the detailed code below.
    For peripherals:
    #define SAADC_SAMPLE_RATE               20                                         /**< SAADC sample rate in ms. */
    // BLE connection parameter.
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64  //3000  //64                                  /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             //10 /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */ // VersionINote1: Purpose: change MIN_CONN_INTERVAL to 10ms and MAX_CONN_INTERVAL to 250. change the timing of the BLE transmission.
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)            //1900  /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(20000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    16   //3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    // Initialize saadc
    void saadc_init(void)
        ret_code_t err_code;
        nrf_drv_saadc_config_t saadc_config = NRF_DRV_SAADC_DEFAULT_CONFIG;
        saadc_config.resolution = NRF_SAADC_RESOLUTION_12BIT;
        nrf_saadc_channel_config_t channel_0_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN4);
        channel_0_config.gain = NRF_SAADC_GAIN1_4;
        channel_0_config.reference = NRF_SAADC_REFERENCE_VDD4;
        nrf_saadc_channel_config_t channel_1_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN5);
        channel_1_config.gain = NRF_SAADC_GAIN1_4;
        channel_1_config.reference = NRF_SAADC_REFERENCE_VDD4;
        nrf_saadc_channel_config_t channel_2_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN6);
        channel_2_config.gain = NRF_SAADC_GAIN1_4;
        channel_2_config.reference = NRF_SAADC_REFERENCE_VDD4;
        nrf_saadc_channel_config_t channel_3_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN7);
        channel_3_config.gain = NRF_SAADC_GAIN1_4;
        channel_3_config.reference = NRF_SAADC_REFERENCE_VDD4;
        err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
        err_code = nrf_drv_saadc_channel_init(0, &channel_0_config);
        err_code = nrf_drv_saadc_channel_init(1, &channel_1_config);
        err_code = nrf_drv_saadc_channel_init(2, &channel_2_config);
        err_code = nrf_drv_saadc_channel_init(3, &channel_3_config);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0],SAADC_SAMPLES_IN_BUFFER);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1],SAADC_SAMPLES_IN_BUFFER);
    // Transmit data in SAADC function
            uint16_t adc_value;
            uint8_t value[SAADC_SAMPLES_IN_BUFFER*2];
            uint16_t bytes_to_send;
            // set buffers
            err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAADC_SAMPLES_IN_BUFFER);
            err_code = ble_nus_data_send(&m_nus, d_tx_buf_1, &nus_length, m_conn_handle);       // VersionFNote1: Purpose: decrease the transfer array by 2. Remove the checking sum.
            if ((err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_NOT_FOUND))
    For central:
    //BLE Timing in sdk_config.h
    // <o> NRF_BLE_SCAN_SCAN_INTERVAL - Scanning interval. Determines the scan interval in units of 0.625 millisecond.
    #ifndef NRF_BLE_SCAN_SCAN_INTERVAL
    #define NRF_BLE_SCAN_SCAN_INTERVAL 400      //160
    // <o> NRF_BLE_SCAN_SCAN_DURATION - Duration of a scanning session in units of 10 ms. Range: 0x0001 - 0xFFFF (10 ms to 10.9225 ms). If set to 0x0000, the scanning continues until it is explicitly disabled.
    #ifndef NRF_BLE_SCAN_SCAN_DURATION
    #define NRF_BLE_SCAN_SCAN_DURATION 0
    // <o> NRF_BLE_SCAN_SCAN_WINDOW - Scanning window. Determines the scanning window in units of 0.625 millisecond.
    #ifndef NRF_BLE_SCAN_SCAN_WINDOW
    #define NRF_BLE_SCAN_SCAN_WINDOW 200      // 80
    // <o> NRF_BLE_SCAN_MIN_CONNECTION_INTERVAL - Determines minimum connection interval in milliseconds.
    #ifndef NRF_BLE_SCAN_MIN_CONNECTION_INTERVAL
    #define NRF_BLE_SCAN_MIN_CONNECTION_INTERVAL 7.5       //7.5
    // <o> NRF_BLE_SCAN_MAX_CONNECTION_INTERVAL - Determines maximum connection interval in milliseconds.
    #ifndef NRF_BLE_SCAN_MAX_CONNECTION_INTERVAL
    #define NRF_BLE_SCAN_MAX_CONNECTION_INTERVAL 180      //30
    // <o> NRF_BLE_SCAN_SLAVE_LATENCY - Determines the slave latency in counts of connection events.
    #ifndef NRF_BLE_SCAN_SLAVE_LATENCY
    #define NRF_BLE_SCAN_SLAVE_LATENCY 0
    // <o> NRF_BLE_SCAN_SUPERVISION_TIMEOUT - Determines the supervision time-out in units of 10 millisecond.
    #ifndef NRF_BLE_SCAN_SUPERVISION_TIMEOUT
    #define NRF_BLE_SCAN_SUPERVISION_TIMEOUT 4000
        static uint16_t index = 0;
        uint32_t ret_val;
        switch (p_event->evt_type)
            /**@snippet [Handling data from UART] */
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= (m_ble_nus_max_data_len)))
                if (index >= (m_ble_nus_max_data_len))
                    NRF_LOG_INFO("Ready to send data over BLE NUS");
                    for(int c = 0; c < NRF_SDH_BLE_CENTRAL_LINK_COUNT; c++)
                        do
                            ret_val = ble_nus_c_string_send(&m_ble_nus_c[c], data_array, index);
                            if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
                                APP_ERROR_CHECK(ret_val);
                        } while (ret_val == NRF_ERROR_RESOURCES);
                    index = 0;
                NRF_LOG_ERROR("Communication error occurred while handling UART.");
            case APP_UART_FIFO_ERROR:
                NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
    /**@brief Function for handling characters received by the Nordic UART Service (NUS).
     * @details This function takes a list of characters of length data_len and prints the characters out on UART.
     *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
    static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
        for (uint32_t i = 0; i < packet; i++)
            app_uart_put( 0xAA );
            for(uint32_t j = 0; j < 16; j++ )
                app_uart_put(p_data[ i*16 + j ]);
            // nrf_gpio_pin_toggle(13);
    Are the parameter of my BLE connection correct?
    For the second question, when to reconnection to the BLE network, after the connection is timeout? Thanks.
    It depends on the number of peripherals that are going to be connected to the central. Did you try the multi-link central example that I linked in a previous reply?
    You can restart it after a disconnection event in the ble event handler
    best regards
    Jared
