Different Fail Points Building MCUBoot With Different Zephyr Sources
I've got the zephyr sources for https://github.com/nrfconnect/sdk-zephyr.git and https://github.com/zephyrproject-rtos/zephyr (everything I get is master/main)
$ west init -l zephyr/
 //zephyr-project version
$ west --verbose update -o=--depth=1 -n --fetch=smart --path-cache=. hal_nordic cmsis mcuboot mbedtls
$ ZEPHYR_TOOLCHAIN_VARIANT=zephyr ZEPHYR_SDK_INSTALL_DIR=<pathTo>/toolchain/ west build --build-dir ./build/mcuboot --board nrf52840dongle_nrf52840 --pristine=always bootloader/mcuboot/boot/zephyr/ -DCONFIG_USB_DEVICE_VID=<#> -DCONFIG_USB_DEVICE_PID=<#>
This fails with:
[58/280] Building C object zephyr/CMakeFiles/zephyr.dir/...rdic/bootloader/mcuboot/boot/zephyr/serial_adapter.c.obj
FAILED: zephyr/CMakeFiles/zephyr.dir<pathTo>/bootloader/mcuboot/boot/zephyr/serial_adapter.c.obj
<pathTo>/toolchain/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DBUILD_VERSION=a81f8af70173 -DKERNEL -DNRF52840_XXAA -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR__=1 -I<pathTo>/zephyr/kernel/include -I<pathTo>/zephyr/arch/arm/include -I<pathTo>/zephyr/include -I<pathTo>/build/mcuboot/zephyr/include/generated -I<pathTo>/zephyr/soc/arm/nordic_nrf/nrf52 -I<pathTo>/zephyr/subsys/usb -I<pathTo>/modules/hal/cmsis/CMSIS/Core/Include -I<pathTo>/modules/hal/nordic/nrfx -I<pathTo>/modules/hal/nordic/nrfx/drivers/include -I<pathTo>/modules/hal/nordic/nrfx/mdk -I<pathTo>/zephyr/modules/hal_nordic/nrfx/. -I<pathTo>/bootloader/mcuboot/boot/zephyr/include -I<pathTo>/bootloader/mcuboot/boot/bootutil/include -I<pathTo>/bootloader/mcuboot/boot/boot_serial/include -I<pathTo>/bootloader/mcuboot/boot/bootutil/src -I<pathTo>/bootloader/mcuboot/boot/bootutil/zephyr/.. -I<pathTo>/bootloader/mcuboot/boot/bootutil/zephyr/../include -I<pathTo>/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem <pathTo>/zephyr/lib/libc/minimal/include -isystem <pathTo>/toolchain/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/include -isystem <pathTo>/toolchain/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/include-fixed -Os -imacros <pathTo>/build/mcuboot/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee -imacros <pathTo>/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-address-of-packed-member -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=<pathTo>/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=<pathTo>/zephyr=ZEPHYR_BASE -fmacro-prefix-map=<pathTo>=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT zephyr/CMakeFiles/zephyr.dir<pathTo>/bootloader/mcuboot/boot/zephyr/serial_adapter.c.obj -MF zephyr/CMakeFiles/zephyr.dir<pathTo>/bootloader/mcuboot/boot/zephyr/serial_adapter.c.obj.d -o zephyr/CMakeFiles/zephyr.dir<pathTo>/bootloader/mcuboot/boot/zephyr/serial_adapter.c.obj -c <pathTo>/bootloader/mcuboot/boot/zephyr/serial_adapter.c
In file included from <pathTo>/zephyr/include/sys/util_macro.h:34,
from <pathTo>/zephyr/include/sys/util.h:17,
from <pathTo>/zephyr/include/kernel/sched_priq.h:9,
from <pathTo>/zephyr/include/kernel_includes.h:23,
from <pathTo>/zephyr/include/kernel.h:17,
from <pathTo>/zephyr/include/init.h:11,
from <pathTo>/zephyr/include/device.h:29,
from <pathTo>/zephyr/include/drivers/uart.h:26,
from <pathTo>/bootloader/mcuboot/boot/zephyr/serial_adapter.c:18:
<pathTo>/bootloader/mcuboot/boot/zephyr/serial_adapter.c: In function 'boot_uart_fifo_init':
<pathTo>/zephyr/include/sys/util.h:62:55: error: size of unnamed array is negative
62 | #define ZERO_OR_COMPILE_ERROR(cond) ((int) sizeof(char[1 - 2 * !(cond)]) - 1)
<pathTo>/zephyr/include/sys/util_internal.h:67:26: note: in definition of macro '__DEBRACKET'
67 | #define __DEBRACKET(...) __VA_ARGS__
<pathTo>/zephyr/include/sys/util_internal.h:59:2: note: in expansion of macro '__GET_ARG2_DEBRACKET'
59 | __GET_ARG2_DEBRACKET(one_or_two_args _if_code, _else_code)
<pathTo>/zephyr/include/sys/util_internal.h:54:2: note: in expansion of macro '__COND_CODE'
54 | __COND_CODE(_XXXX##_flag, _if_1_code, _else_code)
<pathTo>/zephyr/include/sys/util_macro.h:157:2: note: in expansion of macro 'Z_COND_CODE_1'
157 | Z_COND_CODE_1(_flag, _if_1_code, _else_code)
<pathTo>/zephyr/include/device.h:300:2: note: in expansion of macro 'COND_CODE_1'
300 | COND_CODE_1(DT_HAS_COMPAT_STATUS_OKAY(compat), \
<pathTo>/zephyr/include/device.h:302:8: note: in expansion of macro 'ZERO_OR_COMPILE_ERROR'
302 | (ZERO_OR_COMPILE_ERROR(0)))
<pathTo>/bootloader/mcuboot/boot/zephyr/serial_adapter.c:197:13: note: in expansion of macro 'DEVICE_DT_GET_ONE'
197 | uart_dev = DEVICE_DT_GET_ONE(zephyr_cdc_acm_uart);
[63/280] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/usb_device.c.obj
Okay, this freaking editor is torquing me off! I select text, set the format to "pre", go to start a new paragraph and change the format back to "paragraph" and it changes the previous "pre" as well.
It's inconsistent too as demonstrated by the changes between the texts at the top that are "paragraph/pre". It seems changing the "Font" by itself is enough. Nope. Changing the source-code it is then. Ah, finally!
Okay, after that error, I rename/move the zephyr directory and rename the sdk-zephyr directory to zephyr and run the same build command, resulting in:
-- Including generated dts.cmake file: <pathTo>/build/mcuboot/zephyr/dts.cmake
warning: CONSOLE_HANDLER (defined at drivers/console/Kconfig:39) was assigned the value 'y' but got
the value 'n'. Check these unsatisfied dependencies: UART_CONSOLE (=n). See
docs.zephyrproject.org/.../CONFIG_CONSOLE_HANDLER.html and/or look up
CONSOLE_HANDLER in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
warning: LOG_DEFAULT_LEVEL (defined at subsys/logging/Kconfig.filtering:13) was assigned the value
'0' but got the value ''. Check these unsatisfied dependencies: LOG (=n). See
docs.zephyrproject.org/.../CONFIG_LOG_DEFAULT_LEVEL.html and/or look up
LOG_DEFAULT_LEVEL in the menuconfig/guiconfig interface. The Application Development Primer, Setting
too.
warning: The choice symbol LOG_MODE_MINIMAL (defined at subsys/logging/Kconfig.mode:45) was selected
(set =y), but no symbol ended up as the choice selection. See
docs.zephyrproject.org/.../CONFIG_LOG_MODE_MINIMAL.html and/or look up
LOG_MODE_MINIMAL in the menuconfig/guiconfig interface. The Application Development Primer, Setting
too.
warning: USB_DEVICE_STACK (defined at boards/arm/nrf52840dongle_nrf52840/Kconfig.defconfig:32, subsys/usb/Kconfig:6) has direct dependencies (USB && BOARD_NRF52840DONGLE_NRF52840) || USB_DEVICE_DRIVER || ARCH_POSIX with value n, but is currently being y-selected by the following symbols:
- BOOT_SERIAL_CDC_ACM (defined at <pathTo>/bootloader/mcuboot/boot/zephyr/Kconfig:486), with value y, direct dependencies <choice> (value: y), and select condition <choice> (value: y)
Parsing <pathTo>/bootloader/mcuboot/boot/zephyr/Kconfig
Loaded configuration '<pathTo>/zephyr/boards/arm/nrf52840dongle_nrf52840/nrf52840dongle_nrf52840_defconfig'
Merged configuration '<pathTo>/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration '<pathTo>/bootloader/mcuboot/boot/zephyr/boards/nrf52840dongle_nrf52840.conf'
Merged configuration '<pathTo>/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
error: Aborting due to Kconfig warnings
Here we see it is also related to UART/CDC/ACM. Not quite sure why this is happening as doc/_build/html/boards/arm/nrf52840dongle_nrf52840/doc/index.html shows mcuboot being used in "Option 2".
EDIT0: I dropped west and went with custom attempts again and it's working for me now:
$ cmake -B./build -S./samples/zephyr/hello-world/ -GNinja -DBOARD=nrf52840dongle_nrf52840 -DCMAKE_C_FLAGS="--specs=nosys.specs" -DCMAKE_CXX_FLAGS="--specs=nosys.specs" -DZEPHYR_MODULES="<pathTo>/hal_nordic/;<pathTo>/zephyr_cmsis"
$ cmake --build ./build --target zephyr_final
EDIT1: Oh, and this was using mainline zephyr and hal_nordic from the zephyrproject-rtos repository. I tried building using mainline ARM CMSIS, but found that the zephyr CMSIS has a bunch of custom CMakeLists.txt and who knows what else, so I stuck with zephyr's version.
  • I had the identical error when trying to make MCUBOOT for the nrf52840 Dongle under Zephyr 2.7 and was able to fix the root problem.  I used the mcuboot disty that came with the Zephyr install (bootloader\mcuboot).
    After getting this error
      from /home/miked/proj/partworks/sw/zephyr/bootloader/mcuboot/boot/zephyr/serial_adapter.c:18:
    /home/miked/proj/partworks/sw/zephyr/bootloader/mcuboot/boot/zephyr/serial_adapter.c: In function 'boot_uart_fifo_init':
    /home/miked/proj/partworks/sw/zephyr/zephyr/include/sys/util.h:78:55: error: size of unnamed array is negative
    78 | #define ZERO_OR_COMPILE_ERROR(cond) ((int) sizeof(char[1 - 2 * !(cond)]) - 1)
    /home/miked/proj/partworks/sw/zephyr/zephyr/include/sys/util_internal.h:67:26: note: in definition of macro '__DEBRACKE
    /home/miked/proj/partworks/sw/zephyr/zephyr/include/sys/util_internal.h:59:2: note: in expansion of macro '__GET_ARG2_DEBRACKET'
    /home/miked/proj/partworks/sw/zephyr/zephyr/include/sys/util_internal.h:54:2: note: in expansion of macro '__COND_CODE'
    /home/miked/proj/partworks/sw/zephyr/zephyr/include/sys/util_macro.h:157:2: note: in expansion of macro 'Z_COND_CODE_1'
    /home/miked/proj/partworks/sw/zephyr/zephyr/include/device.h:368:2: note: in expansion of macro 'COND_CODE_1'
    368 | COND_CODE_1(DT_HAS_COMPAT_STATUS_OKAY(compat), \
    /home/miked/proj/partworks/sw/zephyr/zephyr/include/device.h:370:8: note: in expansion of macro 'ZERO_OR_COMPILE_ERROR'
    370 | (ZERO_OR_COMPILE_ERROR(0)))
    /home/miked/proj/partworks/sw/zephyr/bootloader/mcuboot/boot/zephyr/serial_adapter.c:197:13: note: in expansion of macro 'DEVICE_DT_GET_ONE'
    [118/285] Building C object zephyr/arch/arch/arm/core/aarc...CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    I found a clue at https://github.com/mcu-tools/mcuboot/issues/1127 that said that with Zephyr >= 2.7 they moved the cdc acm uart from the config files to devicetree.  So I added a nrf52840dongle_nrf52840.overlay file with the following (see https://github.com/mcu-tools/mcuboot/blob/main/boot/zephyr/usb_cdc_acm.overlay)
    &zephyr_udc0 {
      cdc_acm_uart0 {
      compatible = "zephyr,cdc-acm-uart";
      label = "CDC_ACM_0";
    That allowed me to compile and use MCUBOOT on Zephyr with the nrf52840 Dongle.
