Is it possible to send additional data in eddystone protocol ?
If yes please do share a snap of code with me.
basically i want to advertise customized data packet for that i need to form a packet which contains the data i want to advertise and then advertise it
How to do that
I see. Then I suggest you refer to the Beacon Transmitter Sample Application. This essentially shows you how to make a simple advertising packet using manufacturer specific data (you can remove all the iBeacon related stuff).
If you want you can also add a scan response packet, which is generated in the same way as the advertising packet, and in that case set the scan_rsp_data fields in the ble_gap_adv_data_t instead off leaving it NULL.
I am doing the same sending manufacturing data and scan response data in eddystone template but its not showing while advertising that is why i got stuck can you please share the code or steps if how you had done this
The BLE app uart example in nRF5 SDK demonstrates using scan response data (search for srdata in examples/ble_peripheral/ble_app_uart/main.c).
Perhaps you can show what you have done and how you have tested and debugged, and then I may be able to spot the issue.
I am attaching Snap of my code how i had tried implementing to advertise scan response and manufacturing specific data in eddystone but it's not showing this data while advertising
