FOTA with NB-IoT failing
Hi community
I'm trying to evaluate the possibilities of an application update over the air via NB-Iot. According to this post this should be possible.
I'm using the application_update example with the nRF9160-DK (B1).
The example works fine with LTE-M and is able to download the update.
In the prj.conf I changed the defaults for the fragment size (2048 B) and the network mode (LTE-M) to 512 B and NB-IoT by adding the following lines:
CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_512=y
CONFIG_LTE_NETWORK_MODE_NBIOT=y
The code compiles and the LTE Link does connect. It also connects to the server but then it fails with the error 116, see below:
*** Booting Zephyr OS build v2.6.99-ncs1  ***
HTTP application update sample started
LTE Link Connecting ...
LTE Link Connected!
Press Button 1 to perform application firmware update
I: Configuring socket timeout (30 s)
I: Connecting to hidden-url.com
I: Downloading: FOTA/app_update.bin [0]
E: Error in recv(), errno 116
E: Download client error
Received error from fota_download
Does anyone have an idea whats wrong here?
Thanks!
Simon
  • Hi Simon,
    The iBasis SIM card does not support our local NB-IoT network in Norway, so I did not have a chance to test it myself.
     I check with my colleague who has done FOTA over NB-IoT, here is his impression:
    I've tested FOTA over nb-iot with SLM.
    It works, but it is slow and prone for retries. (so download stops, and resumes when the connection is stable again)
    FOTA over nb-iot takes a long time and is power-hungry, but it should work. (however, recommended to use LTE-M if available)
    Charlie
  • Hi Charlie,
    thanks for your reply and your help. It seems like it won't work in Switzerland with Swisscom. So I think this thread can be closed.
    Best wishes,
    Simon
