nrfx_saadc_abort in SAADC API V2
I'm using nrfx_saadc V2 in nRF5 SDK 17.0.2. In nrfx_saadc_abort nrf_saadc_task_trigger(NRF_SAADC_TASK_STOP); is called regardless of if the ADC is currently running. If the ADC is not running this pending task causes several mA of current consumption. It is worth noting that nrfx_saadc_abort is called in nrfx_saadc_uninit, so trying to stop or uninit the SAADC causes excessive current consumption if the ADC was not running.
  • Thank you for elaborating.
    nrbrook said:
    When I added the busy check current consumption doesn't get that high for extended periods of time (only during radio or CPU active)
    That is interesting! How long would these extended periods of time be?
    nrbrook said:
    Current consumption after calling abort is constant at 4.7mA until power off (because the CPU is stopped) with the existing code.
    You say that this goes on from the _abort call until power off because the CPU is stopped, could you elaborate on this? If you mean that the CPU is in SYSTEM_ON sleep (idle) it should not have gone halfway through the _abort call before entering the SYSTEM_ON sleep. When you say until power off, does this mean that you require a power cycle or device reset in order to see the current consumption go down again? If I am understanding what you are saying here correctly it does indeed not sound right at all.
    Have you based your application on a specific example, or do you have a minimal project that demonstrates this behavior?
    Karl
  • That is interesting! How long would these extended periods of time be?
    With the task pending (existing implementation) – ~4.7mA constantly until system off (when I call nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_STAY_IN_SYSOFF);). Resetting will reduce power consumption as task will not be pending.
    Without task pending (checking for busy before starting STOP task) – ~50uA average current, with small peaks during radio or CPU activity (as normal)
    I think if you use the standard SAADC v2 example it will exhibit the behaviour, but I haven't tested it.
  • Hello again,
    Thank you for your patience with this.
    It is the pending task + idling CPU = increased power consumption that I am having trouble understanding. The 4.7 mA constant current consumption indicates that the CPU is running constantly, but at the same time it is not clearing the pending task?
    I would then suspect that the CPU is busy with some other task - or perhaps even busy-waiting - somewhere with a higher-priority for the duration of the increased power consumption. Could there be a possibility for this at all in your application?
    I will have to test this on my end, to see if I am able to replicate the behavior you are seeing.
    Could you be specific about which example you are referring to here? The nRF5 SDK does not contain an example using the SAADC v2 driver.
    You also mentioned that your application is in a BLE connection when this happens.
    Is it necessary to be in a connection to see the behavior?
    If so, would you think that a SAADC v2 + BLE UART example combination should suffice to replicate it?
    Karl
  • Hi Karl, here is some example code but no I don't think there is an example project:
    https://github.com/NordicSemiconductor/nrfx/wiki/SAADC-Advanced-mode-with-IRQs
    I haven't tested this myself but I do not think I am doing anything particularly unique that would trigger this issue, I think it is likely to occur whenever the ADC is already stopped and the stop task is triggered. I assume that the task can't be completed because the ADC is not running, so the CPU continues to run (I don't know how the internal mechanisms of the tasks and CPU operate).
    I don't think it is necessary for the BLE connection to be active (or even the radio at all). I am fairly sure this condition occurred without the radio active, but my current measurement was from after the connection occurred.
    If you have difficulty reproducing the issue I can look in to what I might be doing differently.
  • Hello again,
    Thank you for your patience.
    I think this sounds unlikely, since we have a lot of functionality implemented to get the CPU to idle as soon as possible, and avoid these kinds of hangups, but I will have to test this myself before I can say this for sure.
    This suffices as a working hypothesis that I may test out on my end, thank you for elaborating.
    Thank you. With this information I can do a test to try to replicate it on my end. I will update you as soon as I have had the chance to do so.
    Karl
