Good way to measure distance between two falling edges on one input pin?
I understand I'd be using 16MHz timer for this and it worked on Arduino nano.
I'm trying to measure the distance above with nRF52840 dongle.
Those two edges come in every 10ms(100Hz)
The timer value would have to be captured and subtracted to between 1 and 1100 approximately.
This distance value would have to be converted in to 8bit data and when the dongle receives 10 of these, it should send them over bluetooth(BLE).
I'm struggling to get collect the data correctly. Here's my work done so far.
example of ble_app_uart i added this.
uint32_t time1=0;
uint32_t time2=0;
uint32_t distance_1=0;
uint8_t data_high=0;
uint8_t data_array[BLE_NUS_MAX_DATA_LEN];
uint8_t index1 = 0;
bool time_flag = true;
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
    uint32_t       err_code;
    if (time_flag){
        time1 = nrfx_timer_capture(&m_timer_capture, NRF_TIMER_CC_CHANNEL0);
    }else{
        time2 = nrfx_timer_capture(&m_timer_capture, NRF_TIMER_CC_CHANNEL0);;
    time_flag = !time_flag;
    NRF_LOG_INFO("time1 = %d, time2 = %d", time1, time2);
    distance_1 = app_timer_cnt_diff_compute(time2,time1);
    NRF_LOG_INFO("%d", distance_1);
    if (distance_1 < 1200){
        data_high = fmin( fmax(round((distance_1 - 16.0 - 52.0 - 16.0 + 4.0) / 4.0), 0.0), 255.0);
        data_array[index1]=data_high;
        index1++;
        if (index1 >= 10)
            if (index1 >= 0)
                do
                    NRF_LOG_INFO("H");
                    uint16_t length = 10;
                } while (err_code == NRF_ERROR_RESOURCES);
            index1 = 0;
 * @brief Function for configuring: PIN_IN pin for input sensing
static void gpiote_init(void)
    ret_code_t err_code;
    nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
    in_config.pull = NRF_GPIO_PIN_PULLDOWN;
    err_code = nrf_drv_gpiote_in_init(PIN_IN, &in_config, in_pin_handler);
    nrf_drv_gpiote_in_event_enable(PIN_IN, true);
/**@brief Function for initializing the timer module.
static void timers_init(void)
    err_code = nrfx_timer_init(&m_timer_capture, &timer_cfg, NULL);
    nrf_drv_timer_enable(&m_timer_capture);
Arduino uno runs this.
The log prints out like this as you can see in_pin_handler is not getting called fast enough and it's missing a lot of data. Too big values don't get sent.
but still once in a while the collected data reached 10 so it sends over bluetooth(BLE) and this is what I've got.
But this python data is running very slow because of all the missing data. 10data in approximately 2 minutes every time.
it seems it isn't impossible to measure such a short distance like 1078. Why is it happening so rarely?
What's the best way?
  • I've figured out how to use ppi for this purposes in a smaller scale ppi peripheral example.
    The following code works.
     * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
    * @defgroup ppi_example_main main.c
    * @ingroup ppi_example
    * @brief PPI Example Application main file.
    * This file contains the source code for a sample application using PPI to communicate between timers.
    #include <stdint.h>
    #include "nrf_delay.h"
    #include "app_error.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_timer.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_drv_gpiote.h"
    #include "nrfx_gpiote.h"
    #include <math.h>
    #define PIN_IN  29
    static const nrf_drv_timer_t m_timer_capture = NRFX_TIMER_INSTANCE(1);
    static const nrf_drv_timer_t m_timer_compare = NRFX_TIMER_INSTANCE(0);
    void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action){
        int distance_1;
        uint8_t data_high;
        distance_1 = nrfx_timer_capture(&m_timer_capture, NRF_TIMER_CC_CHANNEL0);
        nrfx_timer_clear(&m_timer_capture);
        //NRF_LOG_INFO("%d", distance_1);
        if (distance_1 < 1200 && distance_1 > 70){
            NRF_LOG_INFO("%d", data_high);
    void timer_handler_read(nrf_timer_event_t event_type, void * p_context)
    void timer_handler_compare(nrf_timer_event_t event_type, void * p_context)
        int distance_1;
        uint8_t data_high;
        distance_1 = nrfx_timer_capture_get(&m_timer_capture, NRF_TIMER_CC_CHANNEL0);
        //nrfx_timer_clear(&m_timer_capture);
        //if(true){
            //data_high = fmin( fmax(round((distance_1 - 16.0 - 52.0 - 16.0 + 4.0) / 4.0), 0.0), 255.0);
        nrf_drv_gpiote_in_event_enable(PIN_IN, false);
        err_code = nrfx_timer_init(&m_timer_capture, &timer_cfg, timer_handler_read);
        err_code = nrfx_timer_init(&m_timer_compare, &timer_cfg, timer_handler_compare);
        uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer_compare, 10);
        nrf_drv_timer_extended_compare(&m_timer_compare,
                                       NRF_TIMER_CC_CHANNEL0,
                                       ticks,
                                       NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                       true);
        nrf_drv_timer_enable(&m_timer_compare);
    nrf_ppi_channel_t ppi_channel_1, ppi_channel_2;
    void ppi_init()
        err_code = nrf_drv_ppi_channel_alloc(&ppi_channel_1);
        err_code = nrf_drv_ppi_channel_alloc(&ppi_channel_2);
        uint32_t gpiote_evt_addr_1              = nrf_drv_gpiote_in_event_addr_get(PIN_IN);
        uint32_t timer_capture_task_addr  = nrf_drv_timer_task_address_get(&m_timer_capture, NRF_TIMER_TASK_CAPTURE0);
        uint32_t timer_clear_task_addr    = nrf_drv_timer_task_address_get(&m_timer_capture, NRF_TIMER_TASK_CLEAR);
        uint32_t timer_read_compare_event_addr  = nrf_drv_timer_event_address_get(&m_timer_capture, NRF_TIMER_EVENT_COMPARE0);
        err_code = nrf_drv_ppi_channel_assign(ppi_channel_1, gpiote_evt_addr_1, timer_capture_task_addr);
        err_code = nrf_drv_ppi_channel_fork_assign(ppi_channel_1, timer_clear_task_addr);
        err_code = nrf_drv_ppi_channel_enable(ppi_channel_1);
        //err_code = nrf_drv_ppi_channel_enable(ppi_channel_2);
     * @brief Function for application main entry.
        uint32_t err_code;
        err_code = NRF_LOG_INIT(NULL);
        gpiote_init();
        timers_init();
        ppi_init();
        NRF_LOG_INFO("PPI example started.");
        while (true)
                __WFE();
                __SEV();
                __WFE();
    But now the problem is how I can send this data over ble.
    The data is distance_1 in timer_handler_compare(), which data will be scaled down to 8 bit data.
    I was trying to move the code above to ble_app_uart but I'm getting a fatal error. error code is 0x00001001
  • I've eventually merged the code above(ppi) and ble_app_uart successfully.
    strangely using timer2 instead of timer0 worked for me.
    This is the main.c file
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include <math.h>
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "Nordic_PPI_BLE"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    #define PIN_IN  29
    static const nrf_drv_timer_t m_timer_compare = NRFX_TIMER_INSTANCE(2);
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    uint8_t index1 = 0;
        int distance_1;
        uint8_t data_high;
            index1++;
            if (index1 >= 10)
                if (index1 >= 0)
                    do
                        //NRF_LOG_INFO("H");
                index1 = 0;
                                       ticks,
                                       true);
    nrf_ppi_channel_t ppi_channel_1;
    void ppi_init()
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
        ble_gap_conn_params_t conn_params;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                sd_ble_gap_ppcp_get(&conn_params);
                err_code = ble_conn_params_change_conn_params(m_conn_handle, &conn_params);
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
            nrf_pwr_mgmt_run();
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        gpiote_init();
        timers_init();
        ppi_init();
        //buttons_leds_init(&erase_bonds);
        power_management_init();
        ble_stack_init();
        sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        advertising_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
     for others to look at, but sdk_config would have to be adjusted accordingly.
    So this is the final answer to my question from the beginning.
