Problems with VS Code
Hi
I've been having issues with this since the first time I installed VS Code and ncs for VS Code. I've used the Nordic's official YT setup guide while installing.
The problem is shown in the following picture:
When I "Create new application from sample" this does not happen at first. But after I close the VS Code and I reopen it, this sometimes occur.
Can anyone help me with this?
Thanks!
  • Hi Emir
    Could you send the output from the command:  "nRF Connect: Generate Support Information" and  "C/C++: Log Diagnostics"?
    When reloading VS Code, loading the extension can sometimes be slow. Do you still have the issue if you build a after a short wait?
    Sigurd Hellesvik
  • Hi Sigurd,
    Following is the required ouput:
    IMPORTANT: The data below could contain sensitive or confidential information about your environment.
    For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
      "platform": {
        "os": "win32",
        "osVersion": "Windows 10 Pro",
        "osKernel": "10.0.19042",
        "vscode": "1.61.1",
        "electron": "13.5.1",
        "node": "v14.16.0"
      "system": {
        "date": "2021-10-18T07:32:48.317Z",
        "vscodeRoot": "c:\\Users\\N\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
        "vscodeUptime": "00:01:58",
        "osUptime": "57:32:13",
        "cpu": {
          "model": "Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz",
          "speed": "3193 MHz",
          "count": 2
        "memory": {
          "total": "7.96 GB",
          "free": "3.31 GB"
      "workspace": {
        "name": "ncs150 (Workspace)",
        "workspaceFile": "c:\\ncsproj\\ncs150.code-workspace",
        "folders": [
          "c:\\ncsproj\\ncs150t",
          "c:\\ncsproj\\ncs_custom_service"
      "extensions": {
        "internal": {
            "version": "2021.10.103",
            "path": "c:\\Users\\N\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2021.10.103",
            "isActive": true
            "version": "2021.9.26",
            "path": "c:\\Users\\N\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2021.9.26",
            "isActive": true
          "nordic-semiconductor.devicetree": null,
          "nordic-semiconductor.kconfig": null
        "external": {
          "marus25.cortex-debug": "0.4.7",
          "ms-vscode.cpptools": "1.7.0",
          "ms-vscode-remote.remote-wsl-recommender": "0.0.11",
          "ms-vscode.js-debug": "1.61.0",
          "ms-vscode.js-debug-companion": "1.0.15",
          "ms-vscode.references-view": "0.0.81",
          "ms-vscode.vscode-js-profile-table": "0.0.18",
          "espressif.esp-idf-extension": "1.2.0",
          "twxs.cmake": "0.0.17"
      "tools": {
        "jlink": "Not found",
        "C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.10.0",
        "c:\\Users\\N\\ncs\\v1.5.0\\toolchain\\opt\\bin\\cmake.exe": "3.17.3",
        "c:\\Users\\N\\ncs\\v1.5.0\\toolchain\\opt\\bin\\Scripts\\west.exe": "0.9.0",
        "c:\\Users\\N\\ncs\\v1.5.0\\toolchain\\opt\\bin\\python.exe": "3.8.2",
        "c:\\Users\\N\\ncs\\v1.5.0\\toolchain\\opt\\bin\\ninja.exe": "1.9.0",
        "c:\\Users\\N\\ncs\\v1.5.0\\toolchain\\opt\\bin\\gperf.exe": "3.1",
        "c:\\Users\\N\\ncs\\v1.5.0\\toolchain\\opt\\bin\\dtc.exe": "1.4.7",
        "gnuarmemb": "Not found",
        "c:\\Users\\N\\ncs\\v1.5.0\\toolchain\\opt\\bin\\gn.exe": "1891"
      "config": {
          "topdir": "c:\\Users\\N\\ncs\\v1.5.0",
          "toolchain": {
            "path": "c:\\Users\\N\\ncs\\v1.5.0\\toolchain"
          "ozonePath": "",
          "applications": [
          "jlink": {
            "rtosPlugin": ""
          "kconfig": {
            "interface": null
          "welcome": {
            "showOnStartup": false
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": []
          "terminalMode": "character"
        "nordic-semiconductor.devicetree": {
          "modules": [
            "${zephyrBase}",
            "${zephyrBase}/../nrf",
          "zephyr": "",
          "ctxFile": "",
          "defaultBoard": ""
        "nordic-semiconductor.kconfig": {
          "root": "",
          "env": {},
          "cfiles": true,
          "disable": false,
          "zephyr": {
            "board": {},
            "west": "",
            "base": "C:\\Users\\N\\ncs\\v1.5.0\\zephyr",
            "soc_roots": []
        "marus25.cortex-debug": {
          "armToolchainPath": null,
          "armToolchainPrefix": "arm-none-eabi",
          "gdbPath": null,
          "JLinkGDBServerPath": null,
          "openocdPath": null,
          "pyocdPath": null,
          "PEGDBServerPath": null,
          "stutilPath": null,
          "stlinkPath": null,
          "stm32cubeprogrammer": null,
          "enableTelemetry": true,
          "flattenAnonymous": false,
          "registerUseNaturalFormat": true,
          "variableUseNaturalFormat": true
      "environment": {
        "westExe": "c:\\Users\\N\\ncs\\v1.5.0\\toolchain\\opt\\bin\\Scripts\\west.exe",
        "westEnv": {
          "ELECTRON_RUN_AS_NODE": "1",
          "HOMEDRIVE": "C:",
          "HOMEPATH": "\\Users\\N",
          "Path": "c:\\Users\\N\\ncs\\v1.5.0\\toolchain\\mingw64\\bin;c:\\Users\\N\\ncs\\v1.5.0\\toolchain\\mingw64\\libexec\\git-core;c:\\Users\\N\\ncs\\v1.5.0\\toolchain\\opt\\bin;c:\\Users\\N\\ncs\\v1.5.0\\toolchain\\opt\\bin\\Scripts;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\PowerShell\\7\\;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\dotnet\\;C:\\Program Files\\PuTTY\\;C:\\Program Files (x86)\\ATI Technologies\\ATI.ACE\\Core-Static;C:\\Program Files\\Git\\cmd;C:\\Users\\N\\AppData\\Local\\Programs\\Python\\Python38-32\\Scripts\\;C:\\Users\\N\\AppData\\Local\\Programs\\Python\\Python38-32\\;C:\\Program Files (x86)\\GNU Tools Arm Embedded\\7 2018-q2-update\\bin;C:\\Users\\N\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\N\\AppData\\Local\\GitHubDesktop\\bin;C:\\Users\\N\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;",
          "ZEPHYR_BASE": "c:\\Users\\N\\ncs\\v1.5.0\\zephyr",
          "GNUARMEMB_TOOLCHAIN_PATH": "c:\\Users\\N\\ncs\\v1.5.0\\toolchain\\opt",
          "ZEPHYR_TOOLCHAIN_VARIANT": "gnuarmemb",
          "PYTHONPATH": "c:\\Users\\N\\ncs\\v1.5.0\\toolchain\\opt\\bin;c:\\Users\\N\\ncs\\v1.5.0\\toolchain\\opt\\bin\\Lib;c:\\Users\\N\\ncs\\v1.5.0\\toolchain\\opt\\bin\\Lib\\site-packages",
          "Python3_ROOT": "c:\\Users\\N\\ncs\\v1.5.0\\toolchain\\opt\\bin"
        "toolchainPath": "c:\\Users\\N\\ncs\\v1.5.0\\toolchain",
        "toolchainBinPath": "c:\\Users\\N\\ncs\\v1.5.0\\toolchain\\opt\\bin",
        "toolchainVersion": "1.5.0"
      "terminal": {
        "shell": null,
        "defaultProfile": null
    I think I may have found solution to this problem over the weekend:
    I've changed the following settings:
    Intelli Sense Mode: windows-gcc-arm
    and after reloading the window, the problem disappeared.
  • Hi
    Good job on finding a solution!
    An additional solution could be the following:
    (DISCLAIMER: The error is likely due to an error during the install of nRF Connect for Visual Studio Code. The fix explained here is a temporary fix, and does not fix the root cause. In later versions of nRF connect for Visual Studio Code, when this have been resolved, it would be a good idea to undo this temporary fix.)
    If the include path is not set in VS Code C/C++, you can not use "go to declaration" among other functionalities:
    To fix it, go to the VS Code settings, find C/C++ "includePath", and add the path to directories you want to add.
    For example: "C:\Users\username\ncs\v1.7.0\**"
    ("**" is to include all sub-directories.)
    Also see this StackOverflow post.
    Sigurd Hellesvik
  • I'm sorry, but I can't access this link.
    Could you help me with that? This is the message that I get:
    Also, I can confirm that I didn't have further problems with this.
    After adding a new build configuration or after opening VS Code for the first time, I sometimes get the same problem, but all I do is "Reload Window" and I guess it reloads these dependencies also.
  • Hi
    My bad. Thank you for pointing out that the link is void.
    I have now edited the last comment do describe an alternative fix for the includePath issue, both for you, and for others who find this later.
    Sigurd Hellesvik
