Use I2C0 instead of UART0 (nRF5340)
I work with the nRF5340 and want to use I2C0 (1-3 is reserved for other sensors in my project ). I already use I2C2 for a sensor and this works fine.
To use the I2C0, I must deactivate the UART0 because you can only use one of them. I deactivated UART0 to use I2C0. Because UART0 is necessary for the terminal output (printk-functions) I switched to RTT instead.
The problem is, when I run the program in debug mode, it won’t reach the main function. When I use “step over” the program works and the program reaches the main-function. Also the function “device_get_binding(“I2C_0”)” is successful.
This is my prj.conf:
CONFIG_PRINTK=y
CONFIG_CONSOLE=y
CONFIG_SERIAL=n     #disable logging (serial)
CONFIG_STDOUT_CONSOLE=y
CONFIG_UART_CONSOLE=n
CONFIG_RTT_CONSOLE=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_DEBUG_OPTIMIZATIONS=y
#Buttons and LEDs configuration
CONFIG_DK_LIBRARY=y
#I2C
CONFIG_I2C=y
CONFIG_NRFX_TWIM=y
This is my overlay file:
&uart0 {
                status = "disabled";
&i2c0 {
        status = "okay";
        sda-pin = < 0x0D >;
        scl-pin = < 0x0E >;
 Below I listed some functions that are called when I run the program. The functions are always the same.
nrfx_twim_0_irq_handler
twim_irq_handler
z_impl_k_sem_give
z_unpend_first_thread
Why is there a difference between running the program and only use “step-over”?
Thank you very much for your help!
