nRF9160-DK , Modem_shell demo , ppp unable to access the Internet
Hello,guys
I build nrf9160-dk modem_shell demo as cmd '$ west build -b nrf9160dk_nrf9160ns ' and then '$ west flash ', after the system running up, I try to ping baidu website,it works as follow picture.
And then I rebuild the Modem_shell demo with cmd ' $ west build -p -b nrf9160dk_nrf9160_ns -d build -- -DOVERLAY_CONFIG=overlay-ppp.conf' for supporting ppp function. After the system running up, I try to ping baidu website again,it works as follow picture and it work failed.
I can capture any data from another serial, I guess VCOM0 serial is shell and VCOM2 serial is ppp channel.
To test my guess,I plugged nrf9160-DK board into my Ubuntu virtual machine and disable Ubuntu network. Use minicom tool to connect VCOM0 and open nrf9160-DK shell in A terminal, set the custom configuration for PPP uart with cmd 'ppp uartconf -b 115200' . New B terminal for ppp connection , type cmd ' $sudo pppd -detach /dev/ttyACM2 115200 DK-ip:Ubuntu-ip noauth nocrtscts local ' , then A terminal return "Dial up connection up" . New C terminal and type cmd ' ifconfig ' , I can see ppp0 and it's ip ,I try to ping baidu website,it work as follow picture.
it can't access the Internet ? why ? Did I operate wrong? Please point out my mistakes.
The version of modem_fw I use is 1.3.0 , ncs version is 1.7.0.
  • Oh, I forget "ppp up"...
    Now I enter “ppp up” and then "pppd ..." ,  ppp0 still no working in the PC...
    I
    Are you still able to ping locally in the modem_shell application?
    What I see is that your application does not populate the MTU size, while mine does:
    *** Booting Zephyr OS build v2.6.99-ncs1-13-g20ac60fb9670  ***
    MOSH version:       v1.7.0-325-gea83b7edbce1
    MOSH build id:      custom
    MOSH build variant: dev
    Initializing modemlib...
    mosh:~$ Initialized modemlib
    Network registration status: searching
    LTE cell changed: Cell ID: 21679616, Tracking area: 30401
    Currently active system mode: LTE-M
    RRC mode: Connected
    Network registration status: Connected - home network
    PSM parameter update: TAU: 3600, Active time: 0 seconds
    mosh:~$ ppp up
    modem data socket 4 created for modem data
    PPP data socket 5 created
    PPP net if up.
    Modem config for system mode: LTE-M
    Modem config for LTE preference: No preference, automatically selected by the modem
    Modem FW version:      mfw_nrf9160_1.3.1
    Operator PLMN:        "24201"
    Current cell id:       21679616 (0x014ACE00)
    Current band:          20
    Current rsrp:          37: -104dBm
    Current snr:           20: -5dB
    Mobile network time and date: 21/11/05,14:24:47+04
    PDP context info 1:
      CID:                0
      PDN ID:             0
      PDP context active: yes
      PDP type:           IPV4V6
      APN:                telenor.smart
      IPv4 MTU:           1500
      IPv4 address:       10.48.219.218
      IPv6 address:       2a02:2121:6b5:afad::ace:7717
      IPv4 DNS address:   193.213.112.4, 130.67.15.198
      IPv6 DNS address:   2001:4600:4:fff::52, 2001:4600:4:1fff::52
    System time updated from cellular network
    Here's the ping time to baidu.com via interface ppp0:
    ping -I ppp0 baidu.com
    PING baidu.com (220.181.38.251) from 10.48.219.218 ppp0: 56(84) bytes of data.
    64 bytes from 220.181.38.251 (220.181.38.251): icmp_seq=1 ttl=44 time=357 ms
    64 bytes from 220.181.38.251 (220.181.38.251): icmp_seq=2 ttl=44 time=396 ms
    64 bytes from 220.181.38.251 (220.181.38.251): icmp_seq=3 ttl=44 time=368 ms
    64 bytes from 220.181.38.251 (220.181.38.251): icmp_seq=4 ttl=44 time=406 ms
    Håkon
