DFU for external BLE Sensor
  I have a current project that is based on the nRf52840.  This project acts both as a peripheral and a central.  I have a need to update the firmware on a remote BLE sensor using DFU, i.e., I need to do exactly what the nRfConnect application does when it updates a peripheral firmware via DFU.  My thought was to use the nRf52840 dongle and develop this code on my PC and then port it to my embedded system.  I also thought the best starting point would be the source code for the nRfConnect application which I would port it but I see from user comments that nordic did not release the source code for this.  Is it possible to get this source code or is there another example that demonstrates what I need to accomplish?
Thanks!
      Is there a tutorial or other information available to show me how to make a SMP GATT client service?  I have never made a GATT client service before.
    Dave
    There are some tutorials here you can take a look at: https://devzone.nordicsemi.com/nordic/short-range-guides/b/bluetooth-low-energy. The "Bluetooth low energy central tutorial" is likely the most relevant one for what you're trying to do.
    You may also use the Client implementation in the nRF connect sdk as a reference for your implementation: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.1.0/nrf/include/bluetooth/services/dfu_smp_c.html
    Vidar
      I have my app scanning the BT610 which in fact a Zephyr RTOS based device.  I have attached a screen shot of the connection that nRfConnect app makes to this sensor.
    I have successfully scanned and made a connection to this BT610 sensor from my application but I am not seeing the characteristics and UUID that I am expecting during the discovery phase.  I have added a bunch of print statements in the discovery handler as shown here:
    static void db_disc_handler(ble_db_discovery_evt_t *p_evt)
    	ble_gatt_db_char_t * p_chars = p_evt->params.discovered_db.charateristics;
    	print_trace("call to ble_lbs_on_db_disc_evt for instance %d and link 0x%x!", p_evt->conn_handle, p_evt->conn_handle);
    	print_trace("p_evt->evt_type: %d", p_evt->evt_type);
    	print_trace("p_evt->params.discovered_db.srv_uuid.uuid: 0x%X", p_evt->params.discovered_db.srv_uuid.uuid);
    	print_trace("p_evt->params.discovered_db.srv_uuid: 0x%X", p_evt->params.discovered_db.srv_uuid.type);
    	for (uint32_t ii = 0; ii < p_evt->params.discovered_db.char_count; ii++) {
    		print_trace("p_chars[%d].characteristic.uuid.uuid: 0x%X, Type: 0x%X", ii, p_chars[ii].characteristic.uuid.uuid, p_chars[ii].characteristic.uuid.type);
    This is what is being printed..
    <info> app: trace:1634844344:p_evt->evt_type: 2
    <info> app: trace:1634844344:p_evt->params.discovered_db.srv_uuid.uuid: 0x1
    <info> app: trace:1634844344:p_evt->params.discovered_db.srv_uuid: 0x3
    <info> app: trace:1634844344:call to ble_lbs_on_db_disc_evt for instance 0 and link 0x0!
    <info> app: trace:1634844344:p_evt->params.discovered_db.srv_uuid.uuid: 0x1523
    <info> app: trace:1634844344:p_evt->params.discovered_db.srv_uuid: 0x5
    <info> app: trace:1634844344:p_evt->params.discovered_db.srv_uuid: 0x6
    <info> app: trace:1634844344:p_evt->params.discovered_db.srv_uuid: 0x7
    The p_evt->evt_type: 2 indicates BLE_DB_DISCOVERY_SRV_NOT_FOUND (Event indicating that the service was not found at the peer).  Can you shed some light on why I am getting BLE_DB_DISCOVERY_SRV_NOT_FOUND back?  I am expecting to get what the nRfConnect application sees?
  • Hi, you have to add the SMP service's based UUID through the sd_ble_uuid_vs_add() call before you start service discovery. You may take a look at the ble_app_uart_c example to see how it's done there for the the NUS client service.
      I am doing that, I am calling smp_c_init(); from my main, here is the code for that..
    static void smp_c_init(void)
    	ret_code_t  err_code;
    	ble_smp_c_init_t init;
    	init.evt_handler = ble_smp_c_evt_handler;
    	err_code = ble_smp_c_init(&m_ble_smp_c, &init);
    #define SMP_BASE_UUID                   {{0x84, 0xAA, 0x60, 0x74, 0x52, 0x8A, 0x8B, 0x86, 0xD3, 0x4C, 0xB7, 0x1D, 0x1D, 0xDC, 0x53, 0x8D}} /**< Used vendor specific UUID. */
    #define BLE_UUID_SMP_SERVICE            0x0001
    uint32_t ble_smp_c_init(ble_smp_c_t * p_ble_smp_c, ble_smp_c_init_t * p_ble_smp_c_init)
        uint32_t      err_code;
        ble_uuid_t    smp_uuid;
        ble_uuid128_t smp_base_uuid = SMP_BASE_UUID;
        VERIFY_PARAM_NOT_NULL(p_ble_smp_c);
        VERIFY_PARAM_NOT_NULL(p_ble_smp_c_init);
        err_code = sd_ble_uuid_vs_add(&smp_base_uuid, &p_ble_smp_c->uuid_type);
        VERIFY_SUCCESS(err_code);
        smp_uuid.type = p_ble_smp_c->uuid_type;
        smp_uuid.uuid = BLE_UUID_SMP_SERVICE;
        p_ble_smp_c->conn_handle           = BLE_CONN_HANDLE_INVALID;
        p_ble_smp_c->evt_handler           = p_ble_smp_c_init->evt_handler;
        p_ble_smp_c->handles.smp_tx_handle = BLE_GATT_HANDLE_INVALID;
        p_ble_smp_c->handles.smp_status_handle = BLE_GATT_HANDLE_INVALID;
        p_ble_smp_c->handles.smp_buffer_handle = BLE_GATT_HANDLE_INVALID;
        p_ble_smp_c->handles.smp_rx_handle = BLE_GATT_HANDLE_INVALID;
        return ble_db_discovery_evt_register(&smp_uuid);
    Also, here is the page that specifies the SMP UUID:  https://github.com/apache/mynewt-mcumgr/blob/master/transport/smp-bluetooth.md
    I think I have this initial part correct but I am not seeing what the nRFConnect app is seeing.
