to compile built in openthread library files for nrf52833 in windows
how to compile openthread library files for nrf52833,
i followed the procedure as below
  1. start with a fresh copy of the SDK, and make sure you place it as close to the ROOT of the hard drive as possible.
  2. Open a command line and go to [nRF5 SDK for Thread and Zigbee v4.1.0 ROOT]\external\openthread\project.
  3. Enter the following commands:
  4. git clone github.com/.../openthread.git
b.cdopenthread
c.git checkout c6a258e3a5bd90aa26d8245c435c0ae5797027f4
  1. Modify the UART pin config in [nRF5 SDK for Thread and Zigbee v4.1.0 ROOT]\external\openthread\project\openthread\examples\platforms\nrf528xx\nrf52833\transport-config.h per your requirements.
  2. Go back to [nRF5 SDK for Thread and Zigbee v4.1.0 ROOT]\external\openthread\project and run "py -3 build_gcc_libs.py" from the command line.
  3. When that is done, run "py -3 import_libs.py gcc" from the command line.
for nrf52833 , but found only nrf52840 get compiled
  • Hi
    These error messages seem to be due to the path to where you put the Thread and Zigbee SDK being too long, as multiple "no such file or directory" generally points to this. Especially when the paths to these files are deep within the SDK. I put it just 3 "steps" in from the C:\\ drive on my end without getting these errors. Please try moving the entire SDK "down a few pegs".
    Simon
