app_ZDebugB0.conf of nrf_desktop in NCS
Hi all:
About with the nrf_desktop example in NCS ,
would like to modify the CONFIG_BT_HIDS_MAX_CLIENT_COUNT to '2' ,
so I add below command at "app_ZDebugB0.conf"
CONFIG_BT_HIDS_MAX_CLIENT_COUNT=2
But when I use Serrger_Embeded_Studio to open project ,it always shows "create_nordic_project.py failed".
Could  I write this command at "app_ZDebugB0.conf"? or another file?
condition:
nrf connect SDK 1.7.0
board name:nrf52kbd_nrf52832
project: nrf_desktop
best regards,
Joe
  • Hi Joe,
    As you can see here,
    joe said:
    warning: BT_HIDS_MAX_CLIENT_COUNT (defined at
    C:/ncs/v1.7.0/nrf\subsys\bluetooth\services\Kconfig.hids:17) was assigned the value '2' but got the
    value '1'. See
    The device count assigned is still 1, which may be because you should also set the BT_MAX_CONN. You can refer here regarding the direct dependency.
    What you can do is, enable the CONFIG_BT_HIDS_MAX_CLIENT_COUNT and also set the CONFIG_BT_MAX_CONN to 2.
    Then try building and let me know how it goes Slight smile
    Kind Regards,
    PK
  • Hi PK:
    thanks for your information,
    I add the below commands into app_ZDebugB0.conf,it can solve the "create_nordic_project.py failed"
    CONFIG_BT_MAX_CONN=2
    but It appears an error when I build the code.
    It seems I can't set the CONFIG_BT_HIDS_MAX_CLIENT_COUNT or  CONFIG_BT_MAX_CONN to 2.
    I try to  enable CONFIG_BT_HIDS_MAX_CLIENT_COUNT  ,so I add below commands into app_ZDebugB0.conf.
    CONFIG_BT_HIDS=y
    It appears the same error after building code.
    best regards,
    Joe
  • Hi Joe,
    Try checking the line 23 in ble_passkey.c and line 51 in ble_latency.c in the location nrf/applications/nrf_desktop/src/modules , as shown in the snippet
    There is a line BUILD_ASSERT(CONFIG_BT_MAX_CONN == 1);
    Hope this helps.
    PK
  • Hi PK:
    thanks for your suggestion,
    The error was solved.
    best regards,
    Joe
