Thingy91 https_client - getaddrinfo failed err 116 50% of the time
Hi All,
I got my hands on a Thingy91 and trying to do devlopment with it starting with a  basic https client sample app. I have registered my Sim and everything works ~50% of the time.
When it works, I found that the network connects and does the ip address query quickly. Though when it doesn't, its like it just timesout. I tried putting a retry counter on the getaddress function, though if 1 fails with a timeout, they will all do the same. Roughly 40s per fail, so 5 retries is around ~3.2min period.
Non-Working example:
*** Booting Zephyr OS build v2.6.99-ncs1  ***
Flash regions		Domain		Permissions
00 02 0x00000 0x18000 	Secure		rwxl
03 31 0x18000 0x100000 	Non-Secure	rwxl
Non-secure callable region 0 placed in flash region 2 with size 32.
SRAM region		Domain		Permissions
00 07 0x00000 0x10000 	Secure		rwxl
08 31 0x10000 0x40000 	Non-Secure	rwxl
Peripheral		Domain		Status
00 NRF_P0               Non-Secure	OK
01 NRF_CLOCK            Non-Secure	OK
02 NRF_RTC0             Non-Secure	OK
03 NRF_RTC1             Non-Secure	OK
04 NRF_NVMC             Non-Secure	OK
05 NRF_UARTE1           Non-Secure	OK
06 NRF_UARTE2           Secure		SKIP
07 NRF_TWIM2            Non-Secure	OK
08 NRF_SPIM3            Non-Secure	OK
09 NRF_TIMER0           Non-Secure	OK
10 NRF_TIMER1           Non-Secure	OK
11 NRF_TIMER2           Non-Secure	OK
12 NRF_SAADC            Non-Secure	OK
13 NRF_PWM0             Non-Secure	OK
14 NRF_PWM1             Non-Secure	OK
15 NRF_PWM2             Non-Secure	OK
16 NRF_PWM3             Non-Secure	OK
17 NRF_WDT              Non-Secure	OK
18 NRF_IPC              Non-Secure	OK
19 NRF_VMC              Non-Secure	OK
20 NRF_FPU              Non-Secure	OK
21 NRF_EGU1             Non-Secure	OK
22 NRF_EGU2             Non-Secure	OK
23 NRF_DPPIC            Non-Secure	OK
24 NRF_REGULATORS       Non-Secure	OK
25 NRF_PDM              Non-Secure	OK
26 NRF_I2S              Non-Secure	OK
27 NRF_GPIOTE1          Non-Secure	OK
SPM: NS image at 0x18200
SPM: NS MSP at 0x200192f8
SPM: NS reset vector at 0x1ad05
SPM: prepare to jump to Non-Secure image.
HTTPS client sample started
Waiting for network.. OK
Waiting for ip addr.. getaddrinfo() failed, err 116
coulnd't get ip over 5 retries
Working Example:
SPM: NS MSP at 0x2001a2f8
SPM: NS reset vector at 0x1ae29
Provisioning certificate
Waiting for ip addr.. OK
Connecting to example.com
Sent 61 bytes
Received 370 bytes
>	 HTTP/1.1 200 OK
Finished, closing socket.
I am not sure about the best way to approach this. The only visibility I have of my sim is from nrfcloud, so I cannot see what happens on the backend for failed connections to the network etc.
I also tried using my own DNS from this example. Though results in same as above, sometimes works, sometimes doesn't.
I played around with the at_cmd.c file and overrode the logging. So I got these 2 sets of logs instead, with more verbose information.
Working:
SPM: NS MSP at 0x2001a300
SPM: NS reset vector at 0x1ae41
Common AT socket created
Common AT socket processing thread created
Setting notification handler to 0x1d675
Sending command AT+CMEE?
AT socket thread started
Writing any pending command
Awaiting response for AT+CMEE?
Listening on socket
at_cmd_rx 15 bytes, +CMEE: 0
OK
Enqueueing response for sync call
Awaiting response for AT+CMEE=1
Sending command AT+CMEE=1
Listening on socket
at_cmd_rx 5 bytes, OK
Awaiting response for AT%CMNG=1,42,0
Sending command AT%CMNG=1,42,0
Listening on socket
at_cmd_rx 85 bytes, %CMNG: 42,0,"0000000000000000000000000000000000000000000000000000000000000000"
OK
Awaiting response for AT+CMEE=0
Sending command AT+CMEE=0
Listening on socket
Listening on socket
OK
Listening on socket
Awaiting response for AT%CMNG=3,42,0
Sending command AT%CMNG=3,42,0
Listening on socket
Listening on socket
Listening on socket
OK
Listening on socket
Awaiting response for AT%CMNG=0,42,0,"-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
Sending command AT%CMNG=0,42,0,"-----BEGIN CERTIFICATE-----
Listening on socket
Listening on socket
Writing any DNS set result 0
Waiting for network.. Sending command AT%XSYSTEMMODE?
pending command
Awaiting response for AT%XSYSTEMMODE?
Listening on socket
at_cmd_rx 28 bytes, %XSYSTEMMODE: 1,0,1,0
OK
Awaiting response for AT%XSYSTEMMODE=1,0,0,0
Sending command AT%XSYSTEMMODE=1,0,0,0
Listening on socket
Awaiting response for AT%XMAGPIO=1,1,1,7,1,746,803,2,698,748,2,1710,2200,3,824,894,4,880,960,5,791,849,7,1565,1586
Sending command AT%XMAGPIO=1,1,1,7,1,746,803,2,698,748,2,1710,2200,3,824,894,4,880,960,5,791,849,7,1565,1586
Listening on socket
Awaiting response for AT+CEREG=5
Sending command AT+CEREG=5
Listening on socket
Awaiting response for AT+CSCON=1
Sending command AT+CSCON=1
Listening on socket
Listening on socket
Listening on socket
Listening on socket
Awaiting response for AT+CFUN=1
Sending command AT+CFUN=1
Listening on socket
Listening on socket
at_cmd_rx 58 bytes, +CEREG: 2,"3060","0833070C",7,0,0,"11100000","11100000"
Listening on socket
at_cmd_rx 12 bytes, +CSCON: 1
Listening on socket
at_cmd_rx 56 bytes, +CEREG: 5,"3060","0833070C",7,,,"00001000","11100000"
OK
Waiting for ip addr.. Writing any pending command
Listening on socket
OK
Sent 61 bytes
Received 369 bytes
>	 HTTP/1.1 200 OK
at_cmd_rx 12 bytes, +CSCON: 0
Listening on socket
And finally, not working:
Listening on socket
OK
Listening on socket
Listening on socket
OK
Listening on socket
Listening on socket
OK
Listening on socket
Listening on socket
Listening on socket
Listening on socket
OK
Listening on socket
Listening on socket
Listening on socket
pending command
Listening on socket
OK
Listening on socket
Listening on socket
Listening on socket
Listening on socket
Listening on socket
Listening on socket
Listening on socket
Listening on socket
Listening on socket
Listening on socket
Listening on socket
Listening on socket
Listening on socket
OK
Listening on socket
Waiting for ip addr.. at_cmd_rx 58 bytes, +CEREG: 2,"3060","0833070C",7,0,0,"11100000","11100000"
Listening on socket
Listening on socket
getaddrinfo() failed, err 114
Listening on socket
Listening on socket
    If we decode the response from %CESQ:
    https://infocenter.nordicsemi.com/topic/ref_at_commands/REF/at_commands/mob_termination_ctrl_status/proc_cesq_set.html?cp=2_1_4_3_0
    We can see that the signal level is quite low in certain scenarios (less than -120 dBm).
    rfleming said:
    And finally, I set the device up back near a window in the office and installed the serial modem hex instead in order to try data connections since it wasn't supported with the at commands. To my dismay, I was unable to get any form of data connection throughout the day while the unit sat there. No pings, connections or dns looksup were successful :(
    I set this up in a custom serial terminal app, it made it easier to send a variety of commands and hold its history.
    The signal strength recorded in this position is very low (best case is -115 dBm, where as the receiver sensitivity is approx. -107 dBm depending on which band you use).
    I also noticed that you're using mfw v1.1.x, and it is recommended that you run ncs v1.7.0 with a newer modem fw. This should not have much to say in the scenario when the signal strength is low, but it will have an impact on the features available in the application space.
    Håkon
  • Unfortunately this webpage now appears to be broken, so I can only see the original post and I am replying based on your comments I read through my email.
    Yea I'll try work with the device at home and see if that helps at all for more consistent results with better reception.
    Where did you read that I was using "mfw 1.1.x" (manufacturer firmware)?. The assest tracker, at program and serial link apps I programmed these all from the latest pre-built binaries from the website. The https basic example was freshly programmed using the nrf v1.7.0 toolchain.
  • Sorry I don't know what order these posts are going in, I hope they are chronological, thread on website is still broken, so I am just replying to the main thread.
    I did some more testing at home today, I think I have a decent signal here. Same results using a new https basic app from nrf toolchain v1.7.1. ~50% failure chance. Once its working it works, but when it doesn't it really doesn't and doesn't seem recover either.
    This time I left my app trying to get an address constantly over the course of an hour or 2, cereg shows that I am connected and I got some cseq commands polling signal strength on each failure. The below happens every 2nd restart on average.
    On failure:
    *** Booting Zephyr OS build v2.6.99-ncs1-1  ***
    SPM: NS reset vector at 0x1aead
    Common AT socket createdCommon AT socket processing thread created
    Setting notification handler to 0x1d6e1
    Listening on socket
    OK
    Listening on socket
    Listening on socket
    OK
    Listening on socket
    Listening on socket
    OK
    Listening on socket
    Listening on socket
    Listening on socket
    Listening on socket
    OK
    Listening on socket
    Listening on socket
    Listening on socket
    ---------> Waiting for network..
    Listening on socket
    at_cmd_rx 28 bytes, %XSYSTEMMODE: 1,0,0,0
    OK
    System mode (1) and preference (0) are already configured
    Listening on socket
    Listening on socket
    Listening on socket
    Sending AT command to set system mode: AT%XSYSTEMMODE=1,0,0,0
    Listening on socket
    Listening on socket
    Listening on socket
    Listening on socket
    Listening on socket
    at_cmd_rx 58 bytes, +CEREG: 2,"3059","0818A60C",7,0,0,"11100000","11100000"
    +CEREG notification: +CEREG: 2,"3059","0818A60C",7,0,0,"11100000","11100000"
    Listening on socket
    +CSCON notification
    Listening on socket
    at_cmd_rx 56 bytes, +CEREG: 5,"3059","0818A60C",7,,,"11100000","11100000"
    +CEREG notification: +CEREG: 5,"3059","0818A60C",7,,,"11100000","11100000"
    ---------> OK
    ---------> getting address...
    Listening on socket
    ---------> getaddrinfo() failed, err 116
    Awaiting response for AT+CEREG?
    Sending command AT+CEREG?
    Listening on socket
    at_cmd_rx 62 bytes, +CEREG: 5,5,"3059","0818A60C",7,,,"11100000","11100000"
    OK
    ---------> reg status 5
    Awaiting response for AT+CESQ
    Sending command AT+CESQ
    Listening on socket
    at_cmd_rx 33 bytes, +CESQ: 99,99,255,255,14,33
    OK
    ---------> cesq status 5, val '+CESQ: 99,99,255,255,14,33
    Listening on socket
    Listening on socket
    OK
    Listening on socket
    OK
    Listening on socket
    Listening on socket
    OK
    Listening on socket
    at_cmd_rx 32 bytes, +CESQ: 99,99,255,255,9,33
    OK
    ---------> cesq status 5, val '+CESQ: 99,99,255,255,9,33
    Listening on socket
    In the at_client log:
    2021-10-27T22:54:52.359Z DEBUG modem >> AT+CGMR
    2021-10-27T22:54:52.367Z DEBUG modem << mfw_nrf9160_1.1.1
    Please see step 4 in the documentation on how to update the modem:
    https://infocenter.nordicsemi.com/topic/ug_thingy91_gsg/UG/thingy91_gsg/updating_fw_usb.html?cp=14_0_3_0
    Håkon
    I think you should update the modem to a newer version and try again. See my former response, linking to step 4 here:
    Håkon
