Thingy91 https_client - getaddrinfo failed err 116 50% of the time
Hi All,
I got my hands on a Thingy91 and trying to do devlopment with it starting with a  basic https client sample app. I have registered my Sim and everything works ~50% of the time.
When it works, I found that the network connects and does the ip address query quickly. Though when it doesn't, its like it just timesout. I tried putting a retry counter on the getaddress function, though if 1 fails with a timeout, they will all do the same. Roughly 40s per fail, so 5 retries is around ~3.2min period.
Non-Working example:
*** Booting Zephyr OS build v2.6.99-ncs1  ***
Flash regions		Domain		Permissions
00 02 0x00000 0x18000 	Secure		rwxl
03 31 0x18000 0x100000 	Non-Secure	rwxl
Non-secure callable region 0 placed in flash region 2 with size 32.
SRAM region		Domain		Permissions
00 07 0x00000 0x10000 	Secure		rwxl
08 31 0x10000 0x40000 	Non-Secure	rwxl
Peripheral		Domain		Status
00 NRF_P0               Non-Secure	OK
01 NRF_CLOCK            Non-Secure	OK
02 NRF_RTC0             Non-Secure	OK
03 NRF_RTC1             Non-Secure	OK
04 NRF_NVMC             Non-Secure	OK
05 NRF_UARTE1           Non-Secure	OK
06 NRF_UARTE2           Secure		SKIP
07 NRF_TWIM2            Non-Secure	OK
08 NRF_SPIM3            Non-Secure	OK
09 NRF_TIMER0           Non-Secure	OK
10 NRF_TIMER1           Non-Secure	OK
11 NRF_TIMER2           Non-Secure	OK
12 NRF_SAADC            Non-Secure	OK
13 NRF_PWM0             Non-Secure	OK
14 NRF_PWM1             Non-Secure	OK
15 NRF_PWM2             Non-Secure	OK
16 NRF_PWM3             Non-Secure	OK
17 NRF_WDT              Non-Secure	OK
18 NRF_IPC              Non-Secure	OK
19 NRF_VMC              Non-Secure	OK
20 NRF_FPU              Non-Secure	OK
21 NRF_EGU1             Non-Secure	OK
22 NRF_EGU2             Non-Secure	OK
23 NRF_DPPIC            Non-Secure	OK
24 NRF_REGULATORS       Non-Secure	OK
25 NRF_PDM              Non-Secure	OK
26 NRF_I2S              Non-Secure	OK
27 NRF_GPIOTE1          Non-Secure	OK
SPM: NS image at 0x18200
SPM: NS MSP at 0x200192f8
SPM: NS reset vector at 0x1ad05
SPM: prepare to jump to Non-Secure image.
HTTPS client sample started
Waiting for network.. OK
Waiting for ip addr.. getaddrinfo() failed, err 116
coulnd't get ip over 5 retries
Working Example:
SPM: NS MSP at 0x2001a2f8
SPM: NS reset vector at 0x1ae29
Provisioning certificate
Waiting for ip addr.. OK
Connecting to example.com
Sent 61 bytes
Received 370 bytes
>	 HTTP/1.1 200 OK
Finished, closing socket.
I am not sure about the best way to approach this. The only visibility I have of my sim is from nrfcloud, so I cannot see what happens on the backend for failed connections to the network etc.
I also tried using my own DNS from this example. Though results in same as above, sometimes works, sometimes doesn't.
I played around with the at_cmd.c file and overrode the logging. So I got these 2 sets of logs instead, with more verbose information.
Working:
SPM: NS MSP at 0x2001a300
SPM: NS reset vector at 0x1ae41
Common AT socket created
Common AT socket processing thread created
Setting notification handler to 0x1d675
Sending command AT+CMEE?
AT socket thread started
Writing any pending command
Awaiting response for AT+CMEE?
Listening on socket
at_cmd_rx 15 bytes, +CMEE: 0
OK
Enqueueing response for sync call
Awaiting response for AT+CMEE=1
Sending command AT+CMEE=1
Listening on socket
at_cmd_rx 5 bytes, OK
Awaiting response for AT%CMNG=1,42,0
Sending command AT%CMNG=1,42,0
Listening on socket
at_cmd_rx 85 bytes, %CMNG: 42,0,"0000000000000000000000000000000000000000000000000000000000000000"
OK
Awaiting response for AT+CMEE=0
Sending command AT+CMEE=0
Listening on socket
Listening on socket
OK
Listening on socket
Awaiting response for AT%CMNG=3,42,0
Sending command AT%CMNG=3,42,0
Listening on socket
Listening on socket
Listening on socket
OK
Listening on socket
Awaiting response for AT%CMNG=0,42,0,"-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
Sending command AT%CMNG=0,42,0,"-----BEGIN CERTIFICATE-----
Listening on socket
Listening on socket
Writing any DNS set result 0
Waiting for network.. Sending command AT%XSYSTEMMODE?
pending command
Awaiting response for AT%XSYSTEMMODE?
Listening on socket
at_cmd_rx 28 bytes, %XSYSTEMMODE: 1,0,1,0
OK
Awaiting response for AT%XSYSTEMMODE=1,0,0,0
Sending command AT%XSYSTEMMODE=1,0,0,0
Listening on socket
Awaiting response for AT%XMAGPIO=1,1,1,7,1,746,803,2,698,748,2,1710,2200,3,824,894,4,880,960,5,791,849,7,1565,1586
Sending command AT%XMAGPIO=1,1,1,7,1,746,803,2,698,748,2,1710,2200,3,824,894,4,880,960,5,791,849,7,1565,1586
Listening on socket
Awaiting response for AT+CEREG=5
Sending command AT+CEREG=5
Listening on socket
Awaiting response for AT+CSCON=1
Sending command AT+CSCON=1
Listening on socket
Listening on socket
Listening on socket
Listening on socket
Awaiting response for AT+CFUN=1
Sending command AT+CFUN=1
Listening on socket
Listening on socket
at_cmd_rx 58 bytes, +CEREG: 2,"3060","0833070C",7,0,0,"11100000","11100000"
Listening on socket
at_cmd_rx 12 bytes, +CSCON: 1
Listening on socket
at_cmd_rx 56 bytes, +CEREG: 5,"3060","0833070C",7,,,"00001000","11100000"
OK
Waiting for ip addr.. Writing any pending command
Listening on socket
OK
Sent 61 bytes
Received 369 bytes
>	 HTTP/1.1 200 OK
at_cmd_rx 12 bytes, +CSCON: 0
Listening on socket
And finally, not working:
Listening on socket
OK
Listening on socket
Listening on socket
OK
Listening on socket
Listening on socket
OK
Listening on socket
Listening on socket
Listening on socket
Listening on socket
OK
Listening on socket
Listening on socket
Listening on socket
pending command
Listening on socket
OK
Listening on socket
Listening on socket
Listening on socket
Listening on socket
Listening on socket
Listening on socket
Listening on socket
Listening on socket
Listening on socket
Listening on socket
Listening on socket
Listening on socket
Listening on socket
OK
Listening on socket
Waiting for ip addr.. at_cmd_rx 58 bytes, +CEREG: 2,"3060","0833070C",7,0,0,"11100000","11100000"
Listening on socket
Listening on socket
getaddrinfo() failed, err 114
Listening on socket
Listening on socket
  • Hi Hakon,
    I have reached out to iBasis and also to our provider in Australia that iBasis is roaming on to see if we can sort that issue out.
    In parallel I do still see the below sometimes. Since the CEREG is +5 and it has a decent signal, I am surprised I got the error 116. If you think its likely the network, I'll concentrate on heading down that path instead and wait to see what they get back to me with. Could a packet trace help with this at all?
    ---------> cesq status 5, val '+CESQ: 99,99,255,255,17,37
    ---------> getting address...
    Listening on socket
    ---------> getaddrinfo() failed, err 116
    Awaiting response for AT+CEREG?
    Sending command AT+CEREG?
    Listening on socket
    at_cmd_rx 62 bytes, +CEREG: 5,5,"3059","0818A60D",7,,,"11100000","11100000"
    OK
    Thanks again,
    Ryan.
  • Hi Ryan,
    Yes, all signs point towards network connectivity issues. I can look at a modem trace if you provide me one.
    Håkon
  • Hi Hakon,
    I got my hands on some local sim cards for our the network that iBasis was roaming on. These appear to work 100% of the time in high signal areas and 50% of the time in my office where I had really bad signal quality.
    I guess our local network, Telstra, doesn't handle roaming sims very well. Well at least not well for LTE-M.
    Thanks for all the help,
    Ryan.
