VTARGET showing 0 value while running JLinkExe on linux
hi, I am very new to ble and I am trying to download softdevice S110 to my Yunjia NRF51822 board. I am using J LINK connected to my linux PC to download the softdevice to the board. I have used following pins of the board for connection with the J Link : SWDIO, SWCLK, GND, VCC, TREF; out of which except for VCC which is connected to the 3.3v, all others are connection between Yunjia NRF51822 board and J Link(including a common ground). Following is the output obtained : Screenshot from 2015-07-10 18:12:29.png
as can be seen, the VTARGET comes out to be 0 and it is not displaying the details of the connected target device. Is it issue with my Yunjia NRF51822 board or some settings on the JLinkExe. I hope my connections are fine. Please correct me if any JLinkExe configuration fault or connection fault from my side.
following is the connections that I have used :
for J Link, pins are as follows :
image description
for nrf8122, pins are as follows:
image description
I have connected the VDD pin from nrf51822 to VTref pin on J Link.
Its my first post on this forum and I look forward to it. :) Thank you and regards, in advance.connection
  • @Stian @PrithviRaj Narendra, hi , ya, it got working. actually it was issue with the connection of Jlink. I was trying to connect JLink pins with wires to the nrf51822 module. I used the wrong column to connect to the JLink. I mean in the JLink connection, I was confused between the column containing Pin 1 and Pin 2 respectively of the J link. so connections were interchanged. thank you for your support.
