nRF9160 thingy91 - AWS IOT (sample): Connect errors -11 and -10
Hello All,
This is from an app I had working 1 1/2 months ago - when I've tried recently to get it connected again, I haven't been successful.
The latest asset tracker appears to work find and posts data to the nRF Cloud.
I've seen previous posts - DNS is working - or appears to be ok.
I'm getting the following:
+CSCON: 0
RRC mode: Idle
Next connection retry in 30 seconds
AWS_IOT_EVT_CONNECTING
+CSCON: 1
RRC mode: Connected
E: getaddrinfo, error -11
E: client_broker_init, error: -10
+CSCON: 0
RRC mode: Idle
+CSCON: 1
RRC mode: Connected
+CSCON: 0
RRC mode: Idle
I can reload the asset tracker and it'll work fine.  I'm running the AWS_IOT sample code.
Thanks in advance as to what -11 and -10 mean - it would appear getting the address fails - I tried to find error codes that make sense but not sure and wanted to ask in case something has changed in the last 1 1/2 months.  This app used to run without issue.
Thanks!
jwest
  • johnwest said:
    how do I install the nRF Code Connect applet that helps with the SDK samples like what's in v5.60 in the newly released version 5.66?
    The nRF Connec SDK has always used a custom version of Segger Embedded Studio (SES). The latest version of that "Nordic Edition" is v5.60.
    I expect that to be updated with NCS 1.8.0, currently scheduled for the end of this year.
    This is the way it has always been with NCS.
    If you have any problems with SES, we will do our best to help you.
    Speaking of which, I am not quite sure what you mean the current problem with SES is.
