nRF_SDK_17.1.0 s140 pca10056 BLE_UART
Hello all,
I am trying to develop an application where the user will input some specific commands i.e hex value of 0x01 via a mobile application and then via bluetooth this command will be passed to the computer using UART.
I have compiled the ble app uart on my nrf52840 but i am struggling to modify the code for my application.
Could someone help me with this ?
Thanks
Kleanthis
  • kleanthise said:
    Thanks a lot for your helpful guidance. I have tried once more to write my own services and characteristics based on UART to BLE example as you can see in the attached codes above. But now getting the following errors.
    kleanthise said:
    I do not understand what creates this issue. Could you help me to troubleshoot it ?
    Great, I am glad to see that you are finding the custom service tutorial useful!
    The error indicates that it is unable to find the on_hvx_tx_complete function being called in ble_cus_on_ble_evt event handler. Looking into your code, it seems you are calling it as part of your  case BLE_GATTS_EVT_HVN_TX_COMPLETE handling, but you do not actually have a function by this name (as opposed to your other event handlings, which calls on_write and on_connect, for example).
    So there could/should exist a on_hvx_tx_complete function that handles the event that your notification has been successfully sent. If no handling of this event is required by your application you may remove the handling of this event from the event handler.
    Karl
  • Dear Karl,
    I have solved all the issues. I have one final question though.
    whenever i pass the command activation i am starting an app_timer that does certain functions and sends some outputs via notifications in a new custom characteristic.
    however whenever this loop finishes the timer stops.
    If the user now reenters the command activation, i can see with NRF_LOG_INFO("p_data = %d", p_evt->params.rx_data.p_data[0]); that it receives the command however it does not restart the app_timer_handle
    Shall i add something else in my nus_data_handle ?
    Kleanthis
  • Hello Kleanthis,
    I am glad to hear that you have managed to solve all the issues - great!
    It is hard to say exactly what you need to do in order to fix this - did you perhaps attach the wrong picture at the end? Without having seen the code, I can only offer general advice, but it sounds to me that you should make sure that the activate command properly reactivates the device following a deactivation, and then follow that configuration to see how the execution might be different for a re-activation compared to a first-time activation.
    Could it be that you use the active state in a function that is only called upon connection, and so if the connection is kept while the state is deactivated and reactivated, the device never goes through the section of code it should at the start of a activation, or similar?
    Karl
  • Thanks a lot for the speedy response.
    I have added the two lines below err_code = (app_art_put(p_evt->params.rx.data.p_data[i])
    counter = 0;
    err_code = app_timer_start(m_notification_timer_id, COUNTER_INTERVAL, NULL);
    and now whenever i enter the activation command it goes through the function in the timer and at anytime if reenter the activation command it resets from start. that is exactly what i wanted it to do.
    Thank you very much for everything case closed :)
    It is no problem at all, Kleanthis - I am happy to help, and glad to hear that you have resolved your issues! :)
    counter = 0;
    I do not have a entirely clear picture of the fix you describe here, since I have not seen it in the context of the rest of the code, but if you have verified it to work for your application that is all that matters. It looks to me that you were able to pinpoint that the activation configuration was not being called upon re-activation, and to fix this issue.
    kleanthise said:
    case closed :)
    Alright - great! :)
    Please do not hesitate to open another ticket if you should encounter any other issues or questions in the future.
    Karl
