Debug Log issue in Adding UART in ble_app_template
1-I have successfully developed an app ...\nRF5SDK1702d674dde\nRF5_SDK_17.0.2_d674dde\examples\ble_peripheral\ble_app_template.
2-I have set a UART example to send data from Arduino and successfully send data from Arduino and receiving on nRF52840. I have used this example code:  ..\SDK\nRF5SDK1702d674dde\nRF5_SDK_17.0.2_d674dde\examples\peripheral\libuarte
When I add the following part in the main BLE stop adverting and am unable to receive data from UART. Also can't see any logs in the terminal when adding this part.
    err_code = NRF_LOG_INIT(app_timer_cnt_get);
    nrf_libuarte_async_config_t nrf_libuarte_async_config = {
            .tx_pin     = TX_PIN_NUMBER,
            .rx_pin     = RX_PIN_NUMBER,
            .baudrate   = NRF_UARTE_BAUDRATE_9600,
            .parity     = NRF_UARTE_PARITY_EXCLUDED,
            .hwfc       = NRF_UARTE_HWFC_DISABLED,
            .timeout_us = 100,
            .int_prio   = APP_IRQ_PRIORITY_LOW
    err_code = nrf_libuarte_async_init(&libuarte, &nrf_libuarte_async_config, uart_event_handler, (void *)&libuarte);
    nrf_libuarte_async_enable(&libuarte);
Here is my main file. Can you please mention where I am making mistakes while adding both projects as both are working fine separately?
587302.main.c
  • Please expand the "debug terminal" view so you can see the file name and the line number of where the invalid param error was returned.
  • Can you step through the async init function to see where the error gets returned?
  • Below are the changes I made to make your project run:
    diff --git a/pca10056/s140/config/sdk_config.h b/pca10056/s140/config/sdk_config.h
    index e27ddb1..765b89c 100644
    --- a/pca10056/s140/config/sdk_config.h
    +++ b/pca10056/s140/config/sdk_config.h
    @@ -5674,14 +5674,14 @@
     #ifndef TIMER0_ENABLED
    -#define TIMER0_ENABLED 1
    +#define TIMER0_ENABLED 0
     // <q> TIMER1_ENABLED  - Enable TIMER1 instance
     #ifndef TIMER1_ENABLED
    -#define TIMER1_ENABLED 0
    +#define TIMER1_ENABLED 1
     // <q> TIMER2_ENABLED  - Enable TIMER2 instance
    @@ -7715,7 +7715,7 @@
     // <e> NRF_LOG_BACKEND_UART_ENABLED - nrf_log_backend_uart - Log UART backend
     #ifndef NRF_LOG_BACKEND_UART_ENABLED
    -#define NRF_LOG_BACKEND_UART_ENABLED 1
    +#define NRF_LOG_BACKEND_UART_ENABLED 0
     // <o> NRF_LOG_BACKEND_UART_TX_PIN - UART TX pin
     #ifndef NRF_LOG_BACKEND_UART_TX_PIN
    diff --git a/main.c b/main.c
    index d908f1c..3acc34d 100644
    --- a/main.c
    +++ b/main.c
    @@ -94,7 +94,7 @@
     #include "nrf_fstorage_sd.h"
     // BEGIN Block Added for DFU
    -#include "C:\Nordic\SDK\nRF5SDK17009d13099\nRF5_SDK_17.0.0_9d13099\components\libraries\bootloader\nrf_bootloader_info.h"
    +#include "nrf_bootloader_info.h"
     #include "ble_dfu.h"
     #include "nrf_dfu_ble_svci_bond_sharing.h"
     #include "nrf_svci_async_function.h"
    @@ -177,7 +177,7 @@
     //UART
    -NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 0, 0, 0, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 3);
    +NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 0, 1, 0, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 3);
     static uint8_t text[] = "UART example started5.\r\nLoopback:\r\n";
     static uint8_t text_size = sizeof(text);
    @@ -3039,31 +3039,22 @@ int main(void) {
       rc = nrf_fstorage_init(&fstorage, p_fs_api, NULL);
       APP_ERROR_CHECK(rc);
    -    err_code = NRF_LOG_INIT(app_timer_cnt_get);
    -    APP_ERROR_CHECK(err_code);
    -    NRF_LOG_DEFAULT_BACKENDS_INIT();
    -    nrf_libuarte_async_config_t nrf_libuarte_async_config = {
    +  nrf_libuarte_async_config_t nrf_libuarte_async_config = {
                 .timeout_us = 100,
    -            .int_prio   = APP_IRQ_PRIORITY_LOW
    +            .int_prio   = APP_IRQ_PRIORITY_LOW_MID
    -    err_code = nrf_libuarte_async_init(&libuarte, &nrf_libuarte_async_config, uart_event_handler, (void *)&libuarte);
    +  err_code = nrf_libuarte_async_init(&libuarte, &nrf_libuarte_async_config, uart_event_handler, (void *)&libuarte);
    +  APP_ERROR_CHECK(err_code);
    -    nrf_libuarte_async_enable(&libuarte);
    +  nrf_libuarte_async_enable(&libuarte);
    NRF_LOG_BACKEND_UART_ENABLED was still enabled in the project you sent..
