DFU bootloader get stuck in SoftDevice at 0x0000C100 - 0x0000C0FC then jumps to 0x00016348 - 0x0001635E and loops forever in these code segments
We are using nRF52833 with DFU secure bootloader and implemented DFU master/host on ESP32 BLE. We observe that DFU bootloader get stuck in above locations in softdevice more frequently during OTA.
SDK used: nRF5_SDK_17.0.0_9d13099
SoftDevice used with version: s140_nrf52_7.0.1_softdevice
Following are some more details
1. nRF52833 is in central mode in our application code, and DFU works in peripheral(obviously) mode
2. DFU host is implemented on ESP32 which is on same board where nRF52833 is, so no issues on BLE range
3. nRF52833 always get stuck somewhere in the last steps, where it erases/writes something in flash like bootloader settings
4. As said, it gets stuck at the end, after power cycle we observed that OTA was successful, so the new application code is loaded and even bootloader settings are also altered to make new application active but then it got stuck somewhere
5. On notification from ESP32 over serial port, nRF52833 application code jumps to bootloader by writing GPREGRET register, we have used sd_ wrapper for it as we are using softdevice
6. OTA host activities from ESP32 works perfect every time and it does not get stuck anywhere in any state, so ESP32 completes OTA file transfer and restarts itself but nRF52833 get stuck sometimes
7. According to study of DFU protocol, after new application file transfer nRF52833 do not do any handshake after flash write activities at the end are completed (this is what we observed to RTT debug messages in DFU bootloader as well)
8. After whatever debugging we did so far, we suspect that, it is something related to flash APIs, because every time it gets stuck, we have seen some peer managers log where it said it has updated something in peer manager data. We have tried to find if we can disable peer manager, but there is no way, so we tried with sd_NVICSystemReset which is supposed to reset softdevice as well before going into DFU bootloader mode, but no luck
If you can help me to find/tell which APIs of Softdevice are located at above locations, then we can try to write something in application code before jumping to bootloader to avoid stuck situation.
Also, if you can provide .o of softdevice, which we can disassemble using objdump, that would be extremely helpful, so that we can see which APIs and instructions where it is getting stuck
Below is the jlink step log, when it get stuck
J-Link>h
PC = 0000C0F8, CycleCnt = 04C5F1A4
R0 = 00000000, R1 = 00000000, R2 = 80000000, R3 = 4001F014
R4 = 20000040, R5 = 40000000, R6 = 00000000, R7 = 20006FC9
R8 = 00000000, R9 = 0007C318, R10= 20010000, R11= 00000000
R12= 00070E35
SP(R13)= 2001FE38, MSP= 2001FE38, PSP= 00000000, R14(LR) = 0000C101
XPSR = 2100000B: APSR = nzCvq, EPSR = 01000000, IPSR = 00B (DebugMonitor)
CFBP = 00000001, CONTROL = 00, FAULTMASK = 00, BASEPRI = 00, PRIMASK = 01
FPS0 = 00F93AFB, FPS1 = DFDE7575, FPS2 = 46847A75, FPS3 = C2B9E2FE
FPS4 = FA78CE71, FPS5 = 3CBA2E2E, FPS6 = 40A70424, FPS7 = AB566C9C
FPS8 = C9DCB219, FPS9 = 490E4A11, FPS10= 4B6332CF, FPS11= 2FBBB72C
FPS12= 963BEA63, FPS13= 22B5A828, FPS14= 2D7FC343, FPS15= 2001FD80
FPS16= 00000000, FPS17= 00000000, FPS18= 00000000, FPS19= 00000000
FPS20= 00000000, FPS21= 00000000, FPS22= 00000000, FPS23= 00000000
FPS24= 00000000, FPS25= 00000000, FPS26= 00000000, FPS27= 00000000
FPS28= 00000000, FPS29= 00000000, FPS30= 00000000, FPS31= 00000000
FPSCR= 00000000
J-Link>s
0000C0F8: 20 B9 CBNZ R0, #+0x08
J-Link>s
0000C0FA: 00 20 MOVS R0, #0
J-Link>s
0000C0FC: 0A F0 24 F9 BL #+0xA248
J-Link>s
00016348: 07 49 LDR R1, [PC, #+0x1C]
J-Link>s
0001634A: 10 31 ADDS R1, #16
J-Link>s
0001634C: 0A 68 LDR R2, [R1]
J-Link>s
0001634E: D2 03 LSLS R2, R2, #15
J-Link>s
00016350: 06 D5 BPL #+0x0C
J-Link>s
00016352: 09 68 LDR R1, [R1]
J-Link>s
00016354: 01 F0 03 01 AND R1, R1, #0x03
J-Link>s
00016358: 81 42 CMP R1, R0
J-Link>s
0001635A: 01 D1 BNE #+0x02
J-Link>s
0001635C: 01 20 MOVS R0, #1
J-Link>s
0001635E: 70 47 BX LR
J-Link>s
0000C100: 00 28 CMP R0, #0
J-Link>s
0000C102: F7 D1 BNE #-0x12
J-Link>s
0000C0F4: D5 F8 0C 01 LDR R0, [R5, #+0x10C]
J-Link>s
J-Link>s
J-Link>s
J-Link>s
J-Link>s
J-Link>s
J-Link>s
J-Link>s
J-Link>s
J-Link>s
J-Link>s
J-Link>s
J-Link>s
J-Link>s
J-Link>s
  • Hi Vidar,
    We haven't kept the track/history of which board has failed as it was very random, but I can guarantee that there is no board which never failed. Because last time I needed to power cycle 21 devices out of 23 and I am sure remaining 2 were failed previously.
    Also, I can say that every device failed in similar number of counts as others, this is for sure.
    Alankar
  • Hi Alankar,
    That answers my question, thanks. As we are struggling to reproduce the issue on our side I wanted to make sure it didn't have anything to do with normal chip to chip variation.
    Vidar
  • Hi Alankar,
    Just an update: I have managed to reproduce the problem now by running a sd_enable() -> sd_disable() -> NVIC_Systemreset() cycle (hangs in sd_disable() on subsequent boot) . There appears to be some timing involved as well because the problem only occurs when I insert a delay between sd_disable() and reset.  I think the timing here may help explain why the problem is so intermittent in your case.
    The good news is that the issue does not occur after a WD reset. Also, the 52832 does not get stuck when I run the same test code indicating that either the 52832 or the s132 softdevice is not affected by this issue.
    Vidar
  • Hi Vidar,
    It's good to hear that, you could reproduce the issue now, which will help to debug further and find the solution. I am not sure about the timing and delay in my case!
    Also, good to hear that it does not occur after WD reset so my current work around should help in field and again thanks for confirmation on 52832, so I do not need to worry about it at this point...
    Thanks for updates, also please let me know if you find a solution on the issue with 52833/s140
    Alankar
  • Hi Alankar,
    I will definitely keep you updated. But I'm afraid it is going to take some time to get to the bottom of this as it seems to be more than just a SW bug.
    Vidar
