Hi I am trying to update the connection interval of a peripheral device (nRF52840 ) and I have followed the steps mentioned here.
After Enabling the ble on the device I read the connection interval at initialization by doing this
uint16_t max = p_ble_evt->evt.gap_evt.params.connected.conn_params.max_conn_interval;
uint16_t min = p_ble_evt->evt.gap_evt.params.connected.conn_params.min_conn_interval;
NRF_LOG_INFO("Conn.Interval Initialized. Max: 0x%X, Min: 0x%X, Max: %d, Min: %d", max, min, max, min);
Then I used the following code part to update the connection interval dynamically
memset(&m_gap_conn_params, 0, sizeof(m_gap_conn_params));
m_gap_conn_params.min_conn_interval = 30; //MSEC_TO_UNITS(30, UNIT_1_25_MS);
m_gap_conn_params.max_conn_interval = 40; //MSEC_TO_UNITS(40, UNIT_1_25_MS);
m_gap_conn_params.slave_latency = 0; // as init
m_gap_conn_params.conn_sup_timeout = MSEC_TO_UNITS(4000, UNIT_10_MS); // as init
err_code = sd_ble_gap_conn_param_update(*m_conn_handle_gen, &m_gap_conn_params);
NRF_LOG_INFO("Conn.Interval in function. Max: 0x%X, Min: 0x%X, Max: %d, Min: %d",
m_gap_conn_params.max_conn_interval, m_gap_conn_params.min_conn_interval,
m_gap_conn_params.max_conn_interval, m_gap_conn_params.min_conn_interval);
// NRF_LOG_INFO("Conn.Interval in function. Max: %d, Min: %d", m_gap_conn_params.max_conn_interval, m_gap_conn_params.min_conn_interval);
while(conn_params_updated == false && timeoutCnt > 0)
timeoutCnt--;
nrf_delay_ms(1);
NRF_WDT->RR[0] = WDT_RR_RR_Reload;
conn_params_updated = false;
if(timeoutCnt > 0) { result = COMM_RESPONSE_SUCCESS; }
*lenPtr++ = COMM_RESPONSE_START;
*lenPtr++ = COMM_CIUPDT;
*lenPtr++ = result;
*lenPtr++ = COMM_RESPONSE_END;
size = lenPtr - buffer;
err_code = ble_nus_data_send(m_nus_gen, buffer, &size , *m_conn_handle_gen);
in the BLE_GAP_EVT_CONN_PARAM_UPDATE event I read back the values like this
case BLE_GAP_EVT_CONN_PARAM_UPDATE:
if(userRequest == UR_CONNINUPDT)
NRF_LOG_INFO("Conn.Interval is updated. Max: 0x%X, Min: 0x%X, Max: %d, Min: %d", max, min, max, min);
conn_params_updated = true;
But I get the following resulting values.36 is correct in initialization then the numbers don't make sense
<info> app: BLE GAP Connected <info> app: Conn.Interval Initialized. Max: 0x24, Min: 0x24, Max: 36, Min: 36 <info> app: Data len is set to 0xF4(244) <info> app: Data len is set to 0xF4(244) <info> app: Conn.Interval in function. Max: 0x28, Min: 0x1E, Max: 40, Min: 30 <info> app: Conn.Interval is updated. Max: 0x2000, Min: 0xAF9, Max: 8192, Min: 2809 <info> app: Conn.Interval is updated. Max: 0x0, Min: 0x0, Max: 0, Min: 0
So I am doing something wrong but I cannot find out what
