Interrupt Callback nRF52805 ble_app_beacon
I working with the MDBT42Q-DB with the nRF52805 module.  I've started from the ble_app_beacon example in SDK 17.1.0.   I was able to compile and run the example in Segger Studio.  I wasn't able to get things to work with Keil.
I'm trying to modify the example to added button response for my onboard buttons.  Ultimately I'd like a button (input) to trigger a wake-up for several minutes (setting a timer) before allowing the beacon to go back into deep sleep.
I modified the pca10050.h to match the pin configuration of the development board:
#define LEDS_INV_MASK  LEDS_MASK
#define LEDS_LIST { LED_1, LED_2 }
#define BSP_LED_0      LED_1
#define BSP_LED_1      LED_2
#define BUTTONS_NUMBER 4
#define BUTTON_1       12
#define BUTTON_2       11
#define BUTTON_3       9
#define BUTTON_4       13
#define BUTTON_PULL    NRF_GPIO_PIN_PULLUP
#define BUTTONS_ACTIVE_STATE 0
#define BUTTONS_LIST { BUTTON_1, BUTTON_2, BUTTON_3, BUTTON_4 }
#define BSP_BUTTON_0   BUTTON_1
#define BSP_BUTTON_1   BUTTON_2
#define BSP_BUTTON_2   BUTTON_3
#define BSP_BUTTON_3   BUTTON_4
I added BSP_INIT_BUTTONS and a callback handler for button presses in the leds_init fucntion
    printf("Event");
    switch(event)
        case BSP_EVENT_KEY_0:
        case BSP_EVENT_KEY_1:
        case BSP_EVENT_KEY_2:
        case BSP_EVENT_KEY_3:
            printf("Event");
/**@brief Function for initializing LEDs. */
static void btn_leds_init(void)
    ret_code_t err_code = bsp_init( BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
 * @brief Function for application main entry.
    bsp_event_t startup_event;
    log_init();
    timers_init();
    btn_leds_init();
    power_management_init();
    ble_stack_init();
    advertising_init();
    // Start execution.
    NRF_LOG_INFO("Beacon example started.");
    advertising_start();
    // Enter main loop.
    for (;; )
        idle_state_handle();
I've enable logging which suggests everything got initialized properly.  The ble_beacon is advertising the custom UUID i've set at the interval I've set both of which I can modify.
<info> PRS: Function: nrfx_prs_acquire, error code: NRF_SUCCESS.
<info> app_timer: RTC: initialized.
<info> GPIOTE: Function: nrfx_gpiote_init, error code: NRF_SUCCESS.
<info> GPIOTE: Function: nrfx_gpiote_in_init, error code: NRF_SUCCESS.
<info> CLOCK: Function: nrfx_clock_init, error code: NRF_SUCCESS.
<info> clock: Function: nrf_drv_clock_init, error code: NRF_SUCCESS.
<info> app: Beacon example started.
I confirmed that the pull-up on SW3 (only default connected switch to pin 9) is being configured with a pull-up as expected.
The status LED is blinking as expected with the advertising indication so I at least modified the LED pins properly.
It's possible some of my configuration, porting the project from pca10040e to support the rNF52805 wasn't completely done properly.  I followed this guide as best I could, but as mentioned about I wasn't successful getting Keil to run, though it seemed to compile.  Segger studio is at least running with some working.
I was using this guide:
https://devzone.nordicsemi.com/guides/short-range-guides/b/getting-started/posts/developing-for-the-nrf52805-with-nrf5-sdk
I put the full project here:
https://github.com/soccerno16/ds
Can you perhaps provide some direction?  I cannot seem to get any sort of interrupt response from the board.
