Can not erase flash by nrf_fstorage_sd backend
I have a problom about using nrf_fstorage_erase won't call nrf_fstorage_sys_evt_handler.
The project is on nrf52832 and using SDK 15.3, Softdevice s132 6.1.1.
When I use nrf_fstorage_nvmc to be backend, everything is fine, but change backend to nrf_fstorage_sd, the erase seem like only finish 1page and never entery
nrf_fstorage_sys_evt_handler to trigger NRF_EVT_FLASH_OPERATION_SUCCESS or NRF_EVT_FLASH_OPERATION_ERROR.
I'm sure I include all file needed to be include, include nrf_sdh_soc.h and I also enable the softdevice by using nrf_sdh_enable_request.
The function which I used to erase flash is down below.
void MemoryOperation_Erase1(void)
	ret_code_t err_code;
	err_code = nrf_fstorage_erase(&m_fs, 0x71000, 2, NULL);
	if(err_code != NRF_SUCCESS)
		NRF_LOG_ERROR("MemoryOperation_Erase1 Error : %d", err_code);
	wait_for_flash_ready();
void MemoryOperation__Erase2(void)
	err_code = nrf_fstorage_erase(&m_fs, 0x73000, 11, NULL);
		NRF_LOG_ERROR("MemoryOperation__Erase2 Error : %d", err_code);
void wait_for_flash_ready(void)
    /* While fstorage is busy, sleep and wait for an event. */
    while (nrf_fstorage_is_busy(&m_fs))
       sd_app_evt_wait();
I also find a subject similar my problem : https://devzone.nordicsemi.com/f/nordic-q-a/63808/missing-softdevice-call-to-nrf_fstorage_sys_evt_handler
But I can't understand how to fix it.
Did I miss something to check?
if anyone know how to find the problem will be appreciated.
Many Thanks,
Marcus
  • Hi Kenneth
    Thanks for your reply and the documented you provide.
    Now the API can erase flash include the bootloader, but it still a little bit weird.
    When I used debug mode to check any wrong with erase process, everything is fine,
    the API can erase all address in flash include bootloader address 0x73000.
    But when I just download the program by using keil, it seems like never erase, the bootloader still in flash.
    What's different between debug mode and download program?
    should I check the any status before I erase?
    Many thanks,
    Marcus
  • Hi Kenneth
    I think I found the reason that why I can not erase the address after 0x73000 where my bootloader start at.
    The problem is in my own bootloader. Before jump into application, the bootloader will call nrf_bootloader_flash_protect to protect the bootloader area, so when application wants to erase bootloader, it trigger the cpu hardfault and the erase was failed of course.
    And because using debug tool will let DISABLEINDEBUG register disable the protect, that's also why
    I can erase the bootloader when using debug mode on application.
    Many thanks,
    Marcus
