Read / Write lwm2m resource instance
Hi all,
I'm implementing a lwm2m client on a NRF9160 and have a problem with read/write resource instances. I use Leshan demo server to test the object and a came across a problem on ‘Remote SIM Provisioning’ object 504. When I read ‘504/0/11’ it reads all instances of this resource, but when I try to read a single instance of this resource, got an error. See images blow
Read resource insntances OK
Read single resource instace NOK.
This is my first problem, because after i need to write.
Can anybody help?
  • Hi Charlie,
    Yes, the same happens to objects in LwM2M Client sample.
    I'm working on the changes needed to support Read/Write resource instances and then i'll post them here
  • Hi Charlie,
    The changes in order to read a specific resource instance are minor.
    In the file 'lwm2m_engine.c' function 'lwm2m_read_handler'
    Need to change 2 thing
    first <> from this
    for (i = 0; i < loop_max; i++) {
    		if (res->res_instances[i].res_inst_id ==
    		    RES_INSTANCE_NOT_CREATED) {
    			continue;
    		if (res->res_inst_count > 1) {
    			msg->path.res_inst_id =
    				res->res_instances[i].res_inst_id;
    		/* setup initial data elements */
    		data_ptr = res->res_instances[i].data_ptr;
    		data_len = res->res_instances[i].data_len;
    to this
    			continue;
                if ((msg->path.level > 3U) &&
                    (res->res_instances[i].res_inst_id != msg->path.res_inst_id)) {
                    continue;
    second <> From this
        if (res->multi_res_inst) {
            engine_put_end_ri(&msg->out, &msg->path);
    		msg->path.res_inst_id = res_inst_id_tmp;
    	return 0;
    To
            if (msg->path.level < 4U) {
    	return 0;
  • Hi ICM_UC,
    Looks like the source codes of lwm2m_enngine.c is from zephyr/lwm2m_engine.c at main · zephyrproject-rtos/zephyr (github.com).
    I think it would be better you create one issue report and proposal your solution to the Zephyr GitHub repository. It is a great honor to contribute to such a project. Wink
    Charlie
