PORT interrupts get stuck
I have three Pins which are used as Port event interrupt source.(low-accuracy)
In some cases If I generate some interrupts (maybe 2 every second but random on at least two of the pins) something happens and then no interrpt handler is called any more.
nrfx_gpiote_irq_handler which is the default handler is called until this error happens. Then there are no further calls.. The main loop still is running and can log to RTT Viewer. I wasn't able to get this error while debugging with Keil uVision.
I have also seen, that  additional traffic on SPI can produce this faster.
If I try to enable the interrupt again I got INVALID_STATE from nrfx_gpiote_in_init ( because  pin_in_use_by_gpiote is true) (Code below)
I also tried to ignore this and re-enable the interrupt anyway but that didn't work.
I read on the DevZone and manual, that if the pin is pulled during handler routine it may get lost or something. But I did not understand, that this means all following interrupts are lost too.
My Softdevice/SDK is 15.3
Any Ideas how to get around this?
	nrfx_gpiote_in_config_t gpiote_in_config;
	memset(&gpiote_in_config, 0, sizeof(gpiote_in_config));
	gpiote_in_config.hi_accuracy = false;
	gpiote_in_config.is_watcher = false;
	gpiote_in_config.pull = NRF_GPIO_PIN_PULLDOWN;
	gpiote_in_config.sense = NRF_GPIOTE_POLARITY_LOTOHI;
	err_code = nrfx_gpiote_in_init(LIS2DH_INT2, &gpiote_in_config,
	        lis2dh_INT2_gpiote_evt_handler_shake);
	nrfx_gpiote_in_event_enable(LIS2DH_INT2, true);
  • Hi, so porting back the nrfx_gptiote.c driver file from SDK 17.0 seams very promising.I can't get them to get stuck any longer.
    I didn't look into the errata though because the code doesn't switch off SPI. It's just on and it still uses that much current.
    As long as the interrupts from the pins come through mostly, the backport is enough I think.
    Thank you!
