Full modem firmware update for modem v1.3.0
I am working in a project where we want to be able to do full modem firmware update with FOTA for modem version 1.3.x. According to the release notes, in order to do this, we need to use the .cbor file in the zip from the release.
I have tried to follow the example in samples/nrf9160/http_update/full_modem_update. This sample however only uses v1.2.1 and v1.2.2. Can I follow the same steps for v1.3.x using the .cbor file? Or do I need to do something more? Like some digest?
I have modified the sample to fit my project. My hardware has a nrf9160 which downloads the firmware via LwM2M. The hardware also has an external flash memory which I use for the firmware update. I am currently using NCS version 1.6.1.
  • These are my configuration.
    Yes for delta version i used another .bin file  that worked.
     i had  also attached dfu_target.c file
    Thanks
    # AWS FOTA
    CONFIG_AWS_FOTA=y
    CONFIG_FOTA_DOWNLOAD=y
    CONFIG_DFU_TARGET=y
    CONFIG_DFU_TARGET_FULL_MODEM=y ##added by waqar for modem firmware full update
     * Copyright (c) 2019 Nordic Semiconductor ASA
    #include <zephyr.h>
    #include <logging/log.h>
    #include <dfu/mcuboot.h>
    #include <dfu/dfu_target.h>
    #define DEF_DFU_TARGET(name) \
    static const struct dfu_target dfu_target_ ## name  = { \
    	.init = dfu_target_ ## name ## _init, \
    	.offset_get = dfu_target_## name ##_offset_get, \
    	.write = dfu_target_ ## name ## _write, \
    	.done = dfu_target_ ## name ## _done, \
    #ifdef CONFIG_DFU_TARGET_MODEM_DELTA
    #include "dfu/dfu_target_modem_delta.h"
    DEF_DFU_TARGET(modem_delta);
    #ifdef CONFIG_DFU_TARGET_MCUBOOT
    #include "dfu/dfu_target_mcuboot.h"
    DEF_DFU_TARGET(mcuboot);
    #ifdef CONFIG_DFU_TARGET_FULL_MODEM
    #include "dfu/dfu_target_full_modem.h"
    DEF_DFU_TARGET(full_modem);
    #define MIN_SIZE_IDENTIFY_BUF 32
    LOG_MODULE_REGISTER(dfu_target, CONFIG_DFU_TARGET_LOG_LEVEL);
    static const struct dfu_target *current_target;
    int dfu_target_img_type(const void *const buf, size_t len)
    	if (len < MIN_SIZE_IDENTIFY_BUF) {
    		return -EAGAIN;
    	if (dfu_target_mcuboot_identify(buf)) {
    		return DFU_TARGET_IMAGE_TYPE_MCUBOOT;
    	if (dfu_target_modem_delta_identify(buf)) {
    		return DFU_TARGET_IMAGE_TYPE_MODEM_DELTA;
    	if (dfu_target_full_modem_identify(buf)) {
    		return DFU_TARGET_IMAGE_TYPE_FULL_MODEM;
    	LOG_ERR("No supported image type found");
    	return -ENOTSUP;
    int dfu_target_init(int img_type, size_t file_size, dfu_target_callback_t cb)
    	const struct dfu_target *new_target = NULL;
    	if (img_type == DFU_TARGET_IMAGE_TYPE_MCUBOOT) {
    		new_target = &dfu_target_mcuboot;
    	if (img_type == DFU_TARGET_IMAGE_TYPE_MODEM_DELTA) {
    		new_target = &dfu_target_modem_delta;
    	if (img_type == DFU_TARGET_IMAGE_TYPE_FULL_MODEM) {
    		new_target = &dfu_target_full_modem;
    	if (new_target == NULL) {
    		LOG_ERR("Unknown image type");
    		return -ENOTSUP;
    	/* The user is re-initializing with an previously aborted target.
    	 * Avoid re-initializing generally to ensure that the download can
    	 * continue where it left off. Re-initializing is required for
    	 * modem_delta upgrades to re-open the DFU socket that is closed on
    	 * abort.
    	if (new_target == current_target
    	   && img_type != DFU_TARGET_IMAGE_TYPE_MODEM_DELTA) {
    		return 0;
    	current_target = new_target;
    	return current_target->init(file_size, cb);
    int dfu_target_offset_get(size_t *offset)
    	if (current_target == NULL) {
    		return -EACCES;
    	return current_target->offset_get(offset);
    int dfu_target_write(const void *const buf, size_t len)
    	if (current_target == NULL || buf == NULL) {
    		return -EACCES;
    	return current_target->write(buf, len);
    int dfu_target_done(bool successful)
    	int err;
    		return -EACCES;
    	err = current_target->done(successful);
    	if (err != 0) {
    		LOG_ERR("Unable to clean up dfu_target");
    		return err;
    	if (successful) {
    		current_target = NULL;
    	return 0;
    int dfu_target_reset(void)
    	if (current_target != NULL) {
    		int err = current_target->done(false);
    		if (err != 0) {
    			return err;
    	return 0;
  • It would be more useful to get the "build_output/zephyr/.config" file, as that will hold your actual output for the configs. Because I think that you maybe don't actually get the FULL_MODEM set correctly, as that has several dependencies, for example FMFU_FDEV.
    (Also, are you sure that you have an external flash memory and has set that up correctly? That is required for FMFU.)
    By now this seems to go beyond the scope of this thread. I suggest you create a new thread for your specific usecase where you can get appropriate support.
