Questions regarding CONEVAL
Hi team,
i first of all want to thank you, for your support and help so far.
I have some questions regarding the values that are been given by the AT command %CONEVAL:
1. How are the values been measured?
2. How do they depend on each other?
3. Which of these values depend on the network quality?
4. Which of these values can i manually affect?
5. How do they affect the current consumption of the device (nrf9160 DK)?
I hope my questions are not too confusingly asked
Cedric
  • What are your intensions of the %CONEVAL usage?
     I want to use the values from %CONEVAL to determine the energy efficiency/ energy consumption estimation of data transmission before actual data transmission has started
    Is it possible?
  • But isn't that what the CONEVAL command does?
    "The Nordic-proprietary %CONEVAL command requests an evaluation of the LTE radio signal state and an estimation of the energy efficiency in a cell that the modem would use for data transmission. The information can be used to determine the energy efficiency of data transmission before actual data transmission is started. The %CONEVAL command is the most useful for a static or slow-moving device."
    <energy_estimate>Relative estimated energy consumption of data transmission compared to nominal consumption. A higher value means smaller energy consumption.
    5 – Bad conditions. Difficulties in setting up connections. Maximum number of repetitions might be needed for data.
    6 – Poor conditions. Setting up a connection might require retries and a higher number of repetitions for data.
    7 – Normal conditions for cIoT device. No repetitions for data or only a few repetitions in the worst case.
    8 – Good conditions. Possibly very good conditions for small amounts of data.
    9 – Excellent conditions. Efficient data transfer estimated also for larger amounts of data.
    sure Oyvind, which then brings up the question: how does each values from the command CONEVAL affect the energy consumption of the board?
    Sorry for the late reply.
    Cedric
