I use the ble-app-uart-c-multilink example with a nRF52840 DK and 5 custom nRF52840 peripheral devices.
For a test, I want to connect to only one of those peripherals with address {0xDF, 0xF8, 0x94, 0x2B, 0x7D, 0x70} so I need to implement a whitelist in the multilink example like in the ble_app_hrs_c example.
So far I have included the following code parts to multilink example main.c file
#define SCAN_DURATION_WITELIST 3000 /**< Duration of the scanning in units of 10 milliseconds. */
static uint16_t m_conn_handle; /**< Current connection handle. */
static bool m_whitelist_disabled; /**< True if whitelist has been temporarily disabled. */
static bool m_memory_access_in_progress; /**< Flag to keep track of ongoing operations on persistent memory. */
static ble_gap_scan_params_t const m_scan_param =
.active = 0x01,
.interval = NRF_BLE_SCAN_SCAN_INTERVAL,
.window = NRF_BLE_SCAN_SCAN_WINDOW,
.filter_policy = BLE_GAP_SCAN_FP_WHITELIST,
.timeout = SCAN_DURATION_WITELIST,
.scan_phys = BLE_GAP_PHY_1MBPS,
/**@brief Names which the central applications will scan for, and which will be advertised by the peripherals.
* if these are set to empty strings, the UUIDs defined below will be used
static char const m_target_periph_name[] = ""; /**< If you want to connect to a peripheral using a given advertising name, type its name here. */
static bool is_connect_per_addr = true; /**< If you want to connect to a peripheral with a given address, set this to true and put the correct address in the variable below. */
static ble_gap_addr_t const m_target_periph_addr =
/* Possible values for addr_type:
BLE_GAP_ADDR_TYPE_PUBLIC,
BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_RESOLVABLE,
BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_NON_RESOLVABLE. */
.addr_type = BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
.addr = {0xDF, 0xF8, 0x94, 0x2B, 0x7D, 0x70}
I also modified the scan_init() function like this
ret_code_t err_code;
nrf_ble_scan_init_t init_scan;
memset(&init_scan, 0, sizeof(init_scan));
init_scan.p_scan_param = &m_scan_param;
init_scan.connect_if_match = true;
init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_ADDR_FILTER, m_target_periph_addr.addr);
err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_ADDR_FILTER, false);
When I run the code on the central (DK) an error pops up : " ble_scan: sd_ble_gap_scan_start returned 0x7 "
What is this error?
Thank you
