BM833 energy saving
Dear forum,
I want to achive low energy consumption for a BM833 (with crystal).
From the following thread, I could deduct, that running the softdevice, an average of 300+ uA is required:
https://devzone.nordicsemi.com/f/nordic-q-a/10425/possible-to-shutdown-soft-device-or-ble-after-init-to-achieve-low-power
Now I could follow the instructions to shutdown the HF-Clock, as suggested, but I could read:
"The SoftDevice does not stop the LFCLK when it disables because other modules may use it (like app_timer)."
This, in reverse, could mean that stopping LFCLK might render the app_timer unusable?
I need to be able to "relaunch" the softdevice (S132) periodically to achieve periodic transmissions (send and/or receive) and currently, I'm using also timers to read from peripherals.
How would I have to proceed to achieve that goal when, at the same time, switching off the LFCLK to achieve 2uA consumption?
Can anyone give a code example?
Richard
  • Hello Vidar,
    Sorry to continue the thread from here, but the forum doesn't allow me to respond from your last suggestion ("enable the Softdevice and use the idle_state_handle().").
    If I do, as you suggest, with all LFRC clock-configuration as suggested, I see an average current of 300+ uA (the same 300+ uA that were observed, before I changed the clock settings in sdk_config.h for LFRC, as you suggested below).
    So, the question still is, how to get the current down to the famous 2.2uA (or at least significantly below 300+ uA)?
    Richard
  • If I do, as you suggest, with all LFRC clock-configuration as suggested, I see an average current of 300+ uA (the same 300+ uA that were observed, before I changed the clock settings in sdk_config.h for LFRC, as you suggested below).
    Which of the suggested clock configurations did you select, the LFXO or LFRC?
    It must be caused by something else if you selected one of the clock sources above.
