Buttonless DFU connect timeout issue on custom board
I followed the DFU to SDK example post on https://www.u-blox.com/en/docs/UBX-19050198 to add Buttonless DFU to an application (I modified \ble_peripheral\ble_app_hrs). The details of firmware updates and HEX file generation are in section 5. Then All the testing in section 6 is successful when I used nRF52832DK to test uploading new version hrs application though buttonless DFU (using nRFconnect and another DK). The SDK I used is 17.0.2.
Then I repeated everything on my custom nRF52832 board, with the same changes applied to my custom application.
I also updated the secure bootloader under “\examples\dfu\secure_bootloader” for my custom board to generate “secure_bootloader_ble_s132_custom.hex”. The main changes are (1) Replace board.c, board.h (remove all the buttons and unused LEDs related code, since my board has no button and only two LEDs), add custom_board.h. (2) Changed softdevice clock setting macros in sdk_config.h, since I do not use external 32MHz crystal.  The bootloader was tested successfully with my customer board. I can see “DfuTarg” as the advertising name. OTA firmware upload is successful with my custom application .zip file (generated with command “nrfutil pkg generate --application custom.hex --application-version-string "2.0.0" --hw-version 52 --sd-req 0x101 --key-file private.key app_v2.zip”)
However, after I generated the combined .hex following steps in section 5, (merge bl_setting.hex, such successfully tested bootloader, softdevice image, and my updated application), downloaded such combined .hex file to my custom board. Recycle power and connect my custom board and application through nRF connect, click DFU button and start OTA uploading, the DFU always gives a message says “dfu failed with error: connect time out” after about 10 seconds waiting.
The downloaded .hex file (bl_set_s132_app.hex) is generated as below
  • nrfutil settings generate --family NRF52 --application custom.hex --application-version-string "1.2.3" --bootloader-version 0 --bl-settings-version 2 bl_setting.hex
  • mergehex --merge bl_setting.hex secure_bootloader_ble_s132_custom.hex s132_nrf52_7.2.0_softdevice.hex --output bl_set_s132.hex
  • mergehex --merge bl_set_s132.hex custom.hex --output bl_set_s132_app.hex
Then I download to custom board though
  • nrfjprog -f nrf52 –recover
  • nrfjprog --program bl_set_s132_app.hex
The .zip file for uploading though buttonless DFU is generated as below.
Since I did exactly the same changes and everything is working on nRF52832DK, may I know what is the possible cause of such “connect time out” issue on my customer board? For example, does bootloader use a timer and accidently occupied by my customer application? It could explain why modified secure_bootloader can do OTA upload successfully, but DFU button on my application has time out error. If so, how to check that?
I already tried method (add “do while” to  sd_ble_gatts_hvx) following the link https://devzone.nordicsemi.com/f/nordic-q-a/38655/buttonless-dfu-sdk-14-2-dfu-failed-with-error
But it still does not working for me.
Appreciate all the helps and suggestions.
    gte938x said:
    If I run bootloader (debug version) alone on my custom board, everything is correct. OTA is successful.
    Ok, good. And if you now use the non-debug version, OTA fails ?
  • No, Both debug or non-debug version of bootloader alone work fine with OTA on my customer board. With bootloader alone, the advertiser name is "DfuTarg". I have time out problem for OTA only if I merge Bootloader, softdevice and application to one .hex and download to my customer board (then the advertiser name is my device name), following test steps in section 5 and 6 of https://www.u-blox.com/en/docs/UBX-19050198. However, everything is OK if I try hrs example with nRF52832DK.
    Since you have the app, bootloader settings page, SoftDevice and Bootloader flashed, the Bootloader will start application when the device is powered on.
    How did you enter DFU mode? Did you add buttonless DFU service to your application? or did you reset the board while holding down button 4(NRF_BL_DFU_ENTER_METHOD_BUTTON_PIN 16).
    Could you try the debug version of the bootloader + your app + bootloader settings page + SoftDevice ?
    Is it always 10 seconds?
  • Hi, I do not know how to describe my problem clearer? Please read through my post story again. I started my story with
    "I followed the DFU to SDK example post on https://www.u-blox.com/en/docs/UBX-19050198 to add Buttonless DFU to an application (I modified \ble_peripheral\ble_app_hrs). The details of firmware updates and HEX file generation are in section 5. Then All the testing in section 6 is successful when I used nRF52832DK to test uploading new version hrs application though buttonless DFU (using nRFconnect and another DK). The SDK I used is 17.0.2.
    Then I repeated everything on my custom nRF52832 board, with the same changes applied to my custom application......."
  • If you do not read APP note at https://www.u-blox.com/en/docs/UBX-19050198  section 5 and 6, we cannot discuss anything, since we are not on the same page.
    Everything in section 5 and 6 works for nRF52832 DK (I modified hrs example to add buttonless DFU service, instead of UART example in the APP note). But if I do buttonless DFU in my custom app (after the same code changes in section 5 to add buttonless DFU service to my application), and try step in section 6.2, I have time out issue for my custom app (on custom board). To you questions, yes, I add buttonless DFU service to my application (detail changes in section 5). To the question "Could you try the debug version of the bootloader + your app + bootloader settings page + SoftDevice", yes, I tried in the first day, and the same time out error. "Is it always 10 seconds". Yes, it is always 10 seconds.
