Uart corrupted when scanning with many advertisers in range
There seems to be a bug with scanning for many Bluetooth advertisements while simultaneously sending  data over uart in Nrf sdk v17.
I have tried to work around this issue by using the nrfx_uart/uarte library, and slowing the scanning rate. Both of these changes did not fix the issue, just made it take longer to show up. Also originally I was using nrf sdk v16, upgrading to v17 made the issue better but still shows up.
At the bottom of this post is a reproducible project that shows this bug.
If the code is programmed and the python script is pointing to the com port of the device, you will see that thereis a wild inconsistency with the data recieved.
If lines 166 and 167 are commented out (the nrf_ble_scan_start) and start the script again, the script will show that every 100 bytes received are in the same pattern
Note: this only seems to happen when there are a lot of advertisers around.
Can you please help find a solution to this problem?
Thanks
#include "nrfx_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_scan.h"
#include <nrfx.h>
#include "nrf_uarte.h"
#include "nrf_gpio.h"
#define APP_BLE_CONN_CFG_TAG 1
struct uart_config_t {
	uint32_t            pseltxd; ///< TXD pin number.
	uint32_t            pselrxd; ///< RXD pin number.
	uint32_t            pselcts; ///< CTS pin number.
	uint32_t            pselrts; ///< RTS pin number.
	void *              p_context; ///< Context passed to interrupt handler.
	nrf_uarte_hwfc_t     hwfc; ///< Flow control configuration.
	nrf_uarte_parity_t   parity; ///< Parity configuration.
	nrf_uarte_baudrate_t baudrate; ///< Baudrate.
	uint8_t             interrupt_priority; ///< Interrupt priority.
static nrf_ble_scan_t m_scan;
NRF_UARTE_Type * p_uart = NRF_UARTE0;
static void send_uart_payload();
static void ble_evt(ble_evt_t const * p_evt, void * p_context);
NRF_SDH_BLE_OBSERVER(m_ble_observer, 1, ble_evt, 0);
#define UART_PAYLOAD_SIZE 100
static uint8_t pl[UART_PAYLOAD_SIZE] = { 0 };
static void ble_evt(ble_evt_t const * p_evt, void * p_context) {
	if (p_evt->header.evt_id == BLE_GAP_EVT_ADV_REPORT) {
		ble_gap_evt_adv_report_t const * p_adv_report = &p_evt->evt.gap_evt.params.adv_report;
		NRFX_LOG_INFO("ADV");
	nrf_ble_scan_on_ble_evt(p_evt, &m_scan);
static void init_softdevice() {
	ret_code_t err_code = nrf_sdh_enable_request();
static void init_bluetooth() {
	uint32_t ram_start = 0;
	ret_code_t err_code = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start);
static void send_uart_payload() {
	nrf_uarte_tx_buffer_set(p_uart, pl, UART_PAYLOAD_SIZE);
	nrf_uarte_task_trigger(p_uart, NRF_UARTE_TASK_STARTTX);
void nrfx_uarte_0_irq_handler(void) {
	if (nrf_uarte_int_enable_check(p_uart, NRF_UARTE_INT_ERROR_MASK) && nrf_uarte_event_check(p_uart, NRF_UARTE_EVENT_ERROR)) {
		nrf_uarte_event_clear(p_uart, NRF_UARTE_EVENT_ERROR);
		nrf_uarte_int_disable(p_uart, NRF_UARTE_INT_RXDRDY_MASK | NRF_UARTE_INT_ERROR_MASK);
		NRFX_LOG_ERROR("uart error!");
	if (nrf_uarte_event_check(p_uart, NRF_UARTE_EVENT_ENDTX)) {
		nrf_uarte_event_clear(p_uart, NRF_UARTE_EVENT_ENDTX);
		nrf_uarte_event_clear(p_uart, NRF_UARTE_EVENT_TXSTOPPED);
static void init_scanner() {
	nrf_ble_scan_init_t init_scan = {
			.connect_if_match = false,
		.conn_cfg_tag = APP_BLE_CONN_CFG_TAG
	ret_code_t err_code = nrf_ble_scan_init(&m_scan, &init_scan, 0);
	m_scan.scan_params.interval =  MSEC_TO_UNITS(100, UNIT_0_625_MS);
	m_scan.scan_params.window =  MSEC_TO_UNITS(100, UNIT_0_625_MS);
	m_scan.scan_params.timeout =  MSEC_TO_UNITS(0, UNIT_10_MS);
static void apply_uart_config(const struct uart_config_t* p_config) {
	if (p_config->pseltxd != NRF_UARTE_PSEL_DISCONNECTED) {
		nrf_gpio_pin_set(p_config->pseltxd);
		nrf_gpio_cfg_output(p_config->pseltxd);
	if (p_config->pselrxd != NRF_UARTE_PSEL_DISCONNECTED) {
		nrf_gpio_cfg_input(p_config->pselrxd, NRF_GPIO_PIN_NOPULL);
	nrf_uarte_baudrate_set(p_uart, p_config->baudrate);
	nrf_uarte_configure(p_uart, p_config->parity, p_config->hwfc);
	nrf_uarte_txrx_pins_set(p_uart, p_config->pseltxd, p_config->pselrxd);
	if (p_config->hwfc == NRF_UARTE_HWFC_ENABLED) {
		if (p_config->pselcts != NRF_UARTE_PSEL_DISCONNECTED) {
			nrf_gpio_cfg_input(p_config->pselcts, NRF_GPIO_PIN_NOPULL);
		if (p_config->pselrts != NRF_UARTE_PSEL_DISCONNECTED) {
			nrf_gpio_pin_set(p_config->pselrts);
			nrf_gpio_cfg_output(p_config->pselrts);
		nrf_uarte_hwfc_pins_set(p_uart, p_config->pselrts, p_config->pselcts);
static void init_uart() {
	struct uart_config_t config = {
		.pseltxd = 6,
		.pselrxd = 5,
		.pselcts = NRF_UARTE_PSEL_DISCONNECTED,
		.pselrts = NRF_UARTE_PSEL_DISCONNECTED,
		.p_context = NULL,
		.hwfc = NRF_UARTE_HWFC_DISABLED,
		.parity = NRF_UARTE_PARITY_EXCLUDED,
		.baudrate = NRF_UARTE_BAUDRATE_9600,
		.interrupt_priority = NRFX_UART_DEFAULT_CONFIG_IRQ_PRIORITY,
	apply_uart_config(&config);
	nrf_uarte_event_clear(p_uart, NRF_UARTE_EVENT_TXDRDY);
	nrf_uarte_event_clear(p_uart, NRF_UARTE_EVENT_RXTO);
	nrf_uarte_int_enable(p_uart,
		NRF_UARTE_INT_TXDRDY_MASK |  NRF_UARTE_INT_RXTO_MASK | NRF_UARTE_INT_ERROR_MASK);
	NRFX_IRQ_PRIORITY_SET(nrfx_get_irq_number(p_uart),
		config.interrupt_priority);
	NRFX_IRQ_ENABLE(nrfx_get_irq_number(p_uart));
	nrf_uarte_enable(p_uart);
int main() {
	NRFX_LOG_INFO("Test started.");
	memset(pl, 0xAB, UART_PAYLOAD_SIZE);
	for (uint16_t i = 0; i < UART_PAYLOAD_SIZE; i++) {
		if (i % 2 == 0) {
			pl[i] = 0xAB;
		} else {
			pl[i] = 0xCD;
	init_softdevice();
	init_bluetooth();
	init_scanner();
	init_uart();
	err_code = nrf_ble_scan_start(&m_scan);
	for (;;) {
		if (!NRF_LOG_PROCESS()) {
			nrf_pwr_mgmt_run();
	return 0;
import serial
def main():
    with serial.Serial('COM17', baudrate=9600) as s:
        while True:
            p = []
            while len(p) < 100:
                p += s.read(100 - len(p))
            print(''.join(map('{:X}'.format, p)))
if __name__ == "__main__":
    main()
  • Im not sending the adverts over uart. It is just sending the same static buffer on txcomplete.
  • Sorry, yes the problem happens when scanning. I have updated the post.
    I have been trying to find a work around for this issue for about a week so I have done a lot of debugging around it.
    1) The uart buffers not corrupted when the broken data is received.
    2) the module is not resetting.
  • The example posted may not be the best.
    In the actual production project, the flow is
    advertisement event -> convert event to our protocol -> add to cyclic buffer -> start sending data over uart if not already.
    Then on uart tx complete, it will pop the next item off the cyclic buffer and send it.
    I have checked that the data taken out is the same as when the tx complete is received, so it is not a buffer corruption issue. This is very hard to reproduce, and only happens when there are a LOT of advertisers.
  • Sorry for the delayed response. I have been trying to come up with possible reasons for this behaviour, but I can't think of any. Nor have I been able to find any similiar reports in our ticket database.
    Can you try set the registers as below on startup to turn on the 64M clock domain as suggested in the errata 109 document ([109] DMA: DMA access transfers might be corrupted) to see if it makes any difference?
    /*Turn on the 64Mhz clock domain. Errata 109 WA */
    *(volatile uint32_t *)0x4006EC00 = 0x00009375;
    *(volatile uint32_t *)0x4006ED08 = 0x00000003;
  • this did not seem to fix the problem. I have also created a zephyr project to confirm it was not  an implementation issue but it still happens. Also it is not required that any Bluetooth activity to be happening for this bug to happen, it just makes it more likely.
    You can reproduce the issue with this zephyr project:
    #include <logging/log.h>
    #include <logging/log_ctrl.h>
    #include <drivers/uart.h>
    LOG_MODULE_REGISTER(main);
    struct k_sem tx_sem;
    const struct device *uart_inst;
    static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data) {
    	switch (evt->type) {
    	case UART_TX_DONE: {
    			LOG_INF("Sent %i bytes", evt->data.tx.len);
    			k_sem_give(&tx_sem);
    		}break;
    	default:break;
    int main() {
    	LOG_INF("Starting test\n");
    	uart_inst =  device_get_binding(DT_LABEL(DT_NODELABEL(uart0)));
    	k_sem_init(&tx_sem, 0, 1);
    	const struct uart_config cfg = {
    		.baudrate = 115200,
    		.parity =	UART_CFG_PARITY_NONE,
    		.stop_bits = UART_CFG_STOP_BITS_1,
    		.data_bits = UART_CFG_DATA_BITS_8,
    		.flow_ctrl = UART_CFG_FLOW_CTRL_NONE
    	int err = uart_configure(uart_inst, &cfg);
    	__ASSERT(err == 0, "failed to configure uart");
    	err = uart_callback_set(uart_inst, uart_cb, 0);
    	__ASSERT(err == 0, "failed to set uart callback");
    	return 0;
    extern void uart_tx_thread(void *p1, void *p2, void *p3) {
    	const uint16_t DATA_SIZE = 100;
    	uint8_t* data = k_malloc(DATA_SIZE);
    	for (uint16_t i = 0; i < DATA_SIZE; i++) {
    		data[i] = ((i % 2 == 0) ? 0xAB : 0xCD);
    	for (;;) {
    		if (k_sem_take(&tx_sem, K_FOREVER) != 0) {
    			LOG_ERR("Failed to take sem lock");
    		LOG_INF("Sending...");
    		int err = uart_tx(uart_inst, data, DATA_SIZE, 0);
    		if (err) {
    			LOG_ERR("failed to write uart message. %i", err);
    	k_free(data);
    K_THREAD_DEFINE(my_tid,
    	1024,
    	uart_tx_thread,
    	NULL,
    	NULL,
    	NULL,
    	5,
    	0,
    	1000);
