Hello
I am learning how to connect timers with gpio via PPI, i working on nrf52832dk.
So far I have connected the RTC 0 alarm channel to the LED no.3 (pin no.19) and its state changes every time the timer is called.
I tried to do the same with timer 1 and LED4 (pin no.20) , unfortunately this connection won't work.
I am enclosing the code that theoretically should work, can anyone check this problem?
#include <zephyr.h>
#include <debug/ppi_trace.h>
#include <drivers/counter.h>
#include <hal/nrf_rtc.h>
#include <hal/nrf_clock.h>
#include <hal/nrf_timer.h>
#include <nrfx_timer.h>
#include <device.h>
#include <logging/log.h>
LOG_MODULE_REGISTER(app);
#define ALARM_PERIOD_US 1000 * 1000
#define RTC NRF_RTC2
#define TIMER NRF_TIMER1
#define RTC_LABEL DT_LABEL(DT_NODELABEL(rtc2))
#define TIMER_LABEL DT_LABEL(DT_NODELABEL(timer1))
static void alarm_callback(const struct device *dev, uint8_t chan_id, uint32_t ticks,
void *user_data);
static void timer_callback(const struct device *dev, uint8_t chan_id, uint32_t ticks,
void *user_data);
static struct counter_alarm_cfg RTC_alarm_cfg = {
.callback = alarm_callback,
.flags = COUNTER_ALARM_CFG_ABSOLUTE,
static struct counter_alarm_cfg TIM0_alarm_cfg = {
.callback = timer_callback,
.flags = 0, //?
static void ppi_trace_pin_setup(uint32_t pin, uint32_t evt)
void *handle;
handle = ppi_trace_config(pin, evt);
__ASSERT(handle != NULL,
"Failed to initialize trace pin, no PPI or GPIOTE resources?");
ppi_trace_enable(handle);
static void ppi_trace_setup(void)
ppi_trace_pin_setup(19,
nrf_rtc_event_address_get(RTC, NRF_RTC_EVENT_COMPARE_0));
ppi_trace_pin_setup(20, nrf_timer_event_address_get(TIMER, NRF_TIMER_EVENT_COMPARE1));
LOG_INF("PPI trace setup done.");
uint32_t ticks, void *user_data)
int err;
uint32_t alarm_cnt = (uint32_t)user_data + 1;
RTC_alarm_cfg.ticks = ticks + counter_us_to_ticks(dev, ALARM_PERIOD_US);
RTC_alarm_cfg.user_data = (void *)alarm_cnt;
LOG_INF("alarm_callback");
err = counter_set_channel_alarm(dev, 0, &RTC_alarm_cfg);
__ASSERT_NO_MSG(err == 0);
(void)err;
int err;
TIM0_alarm_cfg.ticks = counter_us_to_ticks(dev, ALARM_PERIOD_US/2);
TIM0_alarm_cfg.user_data = (void *)alarm_cnt;
LOG_INF("timer_callback %d ",TIM0_alarm_cfg.ticks);
err = counter_set_channel_alarm(dev, 1, &TIM0_alarm_cfg);
(void)err;
static void counter_setup(void)
int err;
const struct device *dev = device_get_binding(RTC_LABEL);
__ASSERT(dev, "Sample cannot run on this board.");
RTC_alarm_cfg.ticks = counter_us_to_ticks(dev, ALARM_PERIOD_US);
err = counter_start(dev);
int err;
const struct device *dev = device_get_binding(TIMER_LABEL);
TIM0_alarm_cfg.ticks = counter_us_to_ticks(dev, ALARM_PERIOD_US);
void main(void)
ppi_trace_setup();
counter_setup();
while (1)
k_msleep(1000);
