Commission Matter accessory using the Android CHIPTool and then control it with the Python CHIP controller, and vice versa
I have been trying out the Matter samples as shown in this webinar. I have been following the instructions for version 1.7.0 of the SDK, specifically the ones in Configuring Matter development environment. In turn, the instructions pointed me to Thread border router, Working with Python CHIP controller, and Commissioning nRF Connect Accessory using Android CHIPTool.
After configuring the Thread Border Router using a Raspberry Pi and building the software for the radio co-processor, downloading the pre-built Python CHIP controller from GitHub, and installing the Android CHIPTool, I tried to follow the instructions in Using Python CHIP Controller for Matter accessory testing. I have managed to commission the Matter Accessory to the Thread network and toggle the LED on the device using the Python controller. However, I can only get the tool to work if I set the Node ID to 1. Furthermore, even though I have checked that the Fabric ID is (in this case) 1 using get-fabricid, I still need to use the hard-coded Fabric ID (5544332211) to Discover IPv6 address of the Matter accessory.
Once I have commissioned the accessory, I cannot discover it again using the known Fabric and Node ID values with the Android CHIPTool. That is, if I did the commissioning with the Python CHIP controller, I cannot use the Android tool to send CHIP commands as shown in these instructions. My first question: is this problem related to the issue mentioned in the known issues document (KRKNWK-11225: Android CHIPTool cannot communicate with a Matter device after the device reboots)?
Conversely, I have successfully commissioned and controlled the Matter accessory using the Android CHIPTool, but I cannot then use the Python CHIP controller to discover the IPv6 address of the accessory (even though I know the Fabric and Node IDs), and therefore, cannot control the accessory using the Python controller.
For reference, I have made sure to use the same version of the SDK (1.7.0) when building the Matter sample and the software for the OpenThread Border Router, the Python CHIP controller, and have used the specific version of the radio co-processor per the instructions in Installing OTBR manually (Raspberry Pi).
My second question: am I missing some steps in order to commission the Matter accessory with the Android CHIPTool, and then control it with the Python CHIP controller, and vice versa?
I will appreciate any information you can provide.
  • Hi Marjeris,
    I have another question: since the Fabric ID is automatically retrieved based on the Node ID, does that mean that the Node ID must be unique across all fabrics in the network? Or is it possible for two devices in different fabrics to have the same Node ID?
  • Hi David,
    So I guess I actually answered your last question as well. The fabric ID part of the DNS service was hardcoded back then. Using a proper fabric ID has now been implemented, so this won't be an issue in new versions of NCS.
    You can try commit bbd19d92f6d58ef79c98793fe0dfb2979db6336d which is the last commit that we upmerged to NCS which is tested pretty well.
    Marjeris
  • Hi Marjeris,
    Yes! This answers my question about the Fabric ID. But now I'm wondering: now that there's a proper Fabric ID, must the Node ID be unique across all fabrics in the network? Otherwise, how can a controller find a node if it only knows its Node ID but not the Fabric ID of the fabric it belongs to?
  • Hi David,
    Node ID must be unique withing a single fabric. Hence there can be two devices in different fabrics having the same node ID. The reason why it's not longer needed to specify the fabric ID in the Python CHIP Controller command is that the controller is in the same fabric (it created it), so it already knows the fabric ID.
  • Hi Marjeris,
    Thank you so much for your answers! With this, I think all my questions have been covered :)
