libuarte and sdcard spi ?
Dear Members,
I run 3 devices,
GPS on libuarte1
LCD on SPI2
Sdcard on SPI 1,
I'm using ANT and softdevice 340,
When I run LCD and SDcard outside the main loop, it's working ok,
by the time it's inside the main loop, it crashes with libuarte1,
Code :
									nrf_libuarte_async_config_t nrf_libuarte_async_config1 = {
            .tx_pin     = SER_APP_TX_PIN,
            .rx_pin     = SER_APP_RX_PIN,
            .baudrate   = NRF_UARTE_BAUDRATE_9600, //originally 28 Sept 2021
					  //.baudrate   = NRF_UARTE_BAUDRATE_38400,
            .parity     = NRF_UARTE_PARITY_EXCLUDED,
            .hwfc       = NRF_UARTE_HWFC_DISABLED,
            .timeout_us = 1000,
            .int_prio   = APP_IRQ_PRIORITY_LOW
		err_code=nrf_libuarte_async_init(&libuarte1, &nrf_libuarte_async_config1, uart_event_handler1, (void *)&libuarte1);
 /******************SDCARD  Sequence****************/
						NRF_SPI2->ENABLE = 0; //ILI9341 off
		          nrf_delay_ms(100);
			        NRF_SPI1->ENABLE = 1; //SDcard on
								fatfs_example();
								nrf_delay_ms(100);
            printf("\rRixtronix LAB GPS Query.... \r\n");
						 nrf_delay_ms(2000);
						GPSNeo_Process();
Debug :
nfo> app:
isting directory: /
   9550  RIXTRO.TXT<info> app: Writing to file RIXTRO.TXT...
nfo> app: 50 bytes written.
nfo> app: LOOP Rixtronix LAB.
rror> app: SOFTDEVICE: ASSERTION FAILED
nfo> app: Support us by subscribing,thanks...
nfo> app: Initializing disk 0 (SDC)...
nfo> app: Capacity: 30436 MB
nfo> app: Mounting volume...
<error> app: ERROR 0 [NRF_SUCCESS] at ..\..\..\..\..\..\..\..\components\librari
\libuarte\nrf_libuarte_async.c:230
 at: 0x0004877B
rror> app: End of error report
Any ideas on resolving it ? thanks
    I'm sorry for the late response. Jared is on vacation so I will take over the case.
    Please let us know if you managed to solve the issue or not ?
    Please note that the call nrf_libuarte_async_rx_free() is used after you have done with processing the data. This call is to return the buffer to the library so that it can receive more data.
    So it's the best if you can call the function after you process data, not by a periodically timer.
    I put it on my callback, and it's crashed, I'm using simple timer state machine now and still crashed,
    The sequence :
    1 .
      case NRF_LIBUARTE_ASYNC_EVT_RX_DATA:
                       GPS_CallBack(); //originally on 1 Dec 21 Rixtronix LAB
    2. in the call back :
    if(GPS.rxIndex < sizeof(GPS.rxBuffer)-2)
            GPS.rxBuffer[GPS.rxIndex] = GPS.rxTmp; //originally
            GPS.rxIndex++;
            memcpy((void *)line_buffer_GPS, (void *)GPS.rxBuffer, GPS.rxIndex);
      nrf_libuarte_async_rx_free(&libuarte1, (uint8_t *)&GPS.rxTmp, 1); //originally Rixtronix LAB
    3. GPS process :
    in main()
    if (GPS_flag_timer ==1)
                {//turn on LED
                        nrf_gpio_pin_set(15);
                     GPSNeo_Process();
    Do you reckon I put
    at the end of GPSNeo_Process(); ?
    Thanks
  • Hi Rixtronik,
    Could you explain why you call nrf_libuarte_async_rx_free() with the length = 1 ?
    I don't have an overview of how you transmit your data via UART, but basically when you receive data over UART in NRF_LIBUARTE_ASYNC_EVT_RX_DATA event, you will have the length of the number of bytes you receive in p_evt->data.rxtx.length. Then after you have copied the data or have processed the data you can free the same amount of data.
    If you receive 10 bytes but only free 1 byte you will receive the error at line 230 of nrf_libuarte_async.c as shown in your log in your first post.
  • so I need to put length = size of buffer, in my case 255 ? thanks
  • No, you should free the amount of byte equal to the amount of bytes you receive (or you have processed) in this case p_evt->data.rxtx.length
